Problem - Blue Screen
HighONE@ Hvala na odgovoru.Probacu da skinem novi driver za creative x-fi titanium pa cu videti kako ce se ponasati.U svakom slucaju javicu kako je proslo.
@safmaverick:
BSOD tokom Primea?
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e) dxgmms1.sys
Opet novi BSOD... Kod ovakvih problema, sa dosta različitih BSODova ja bih prvo proverio memoriju ali pošto su problemi počeli sa novim procesorom, možeš početi i od njega - hajde pusti https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=19792 da vidimo da li će Intelov utility imati šta da kaže. Imaš li negde još uvek stari CPU?
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff80181054574, The address that the exception occurred at
Arg3: ffffd00020d5e588, Exception Record Address
Arg4: ffffd00020d5dd90, Context Record Address
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+1a4
fffff801`81054574 8b4810 mov ecx,dword ptr [rax+10h]
EXCEPTION_RECORD: ffffd00020d5e588 -- (.exr 0xffffd00020d5e588)
ExceptionAddress: fffff80181054574 (dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+0x00000000000001a4)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT: ffffd00020d5dd90 -- (.cxr 0xffffd00020d5dd90;r)
rax=0008000000000000 rbx=ffffc0005aed9db0 rcx=00000000fffffffe
rdx=ffffe00163290800 rsi=0000000000000001 rdi=ffffe00163290800
rip=fffff80181054574 rsp=ffffd00020d5e7c0 rbp=0000000000000000
r8=0000000000000001 r9=0000000000000000 r10=ffffe001619bb000
r11=000000000000001f r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=ffffe00161b7e000
iopl=0 nv up ei pl nz na po nc
cs=0010 ss=0000 ds=002b es=002b fs=0053 gs=002b efl=00010206
dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+0x1a4:
fffff801`81054574 8b4810 mov ecx,dword ptr [rax+10h] ds:002b:00080000`00000010=????????
Last set context:
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: ffffffffffffffff
READ_ADDRESS: ffffffffffffffff
FOLLOWUP_IP:
BUGCHECK_STR: AV
ANALYSIS_VERSION: 6.3.9600.17029 (debuggers(dbg).140219-1702) amd64fre
LAST_CONTROL_TRANSFER: from fffff801810533c3 to fffff80181054574
STACK_TEXT:
ffffd000`20d5e7c0 fffff801`810533c3 : ffffe001`5f506088 ffffd000`20d5e910 00000000`0000000e ffff05bd`ecb04bbb : dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+0x1a4
ffffd000`20d5e810 fffff801`8105da6a : ffffe001`619b5880 ffffe001`619bb000 ffffe001`602f8cc0 ffffe001`619b5010 : dxgmms1!VIDMM_GLOBAL:😛repareDmaBuffer+0x443
ffffd000`20d5ea90 fffff801`8105fda5 : ffffe001`00000000 ffffe001`00000000 ffffe001`62c3ac70 ffffe001`00000000 : dxgmms1!VidSchiSubmitRenderCommand+0x20a
ffffd000`20d5ec70 fffff801`8105fd1d : ffffe001`619bb000 00000000`00000080 ffffe001`619e3500 ffffe001`00000000 : dxgmms1!VidSchiRun_PriorityTable+0x85
ffffd000`20d5ecc0 fffff802`c8144794 : fffff802`c83c2a00 ffffe001`619e3500 ffffd000`20d5ed90 fffff802`c81cc37d : dxgmms1!VidSchiWorkerThread+0x8d
ffffd000`20d5ed00 fffff802`c81cf5c6 : fffff802`c835b180 ffffe001`619e3500 fffff802`c83c2a00 ffffe001`5f1aa710 : nt!PspSystemThreadStartup+0x58
ffffd000`20d5ed60 00000000`00000000 : ffffd000`20d5f000 ffffd000`20d59000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation+1a4
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: dxgmms1
IMAGE_NAME: dxgmms1.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 53183e46
IMAGE_VERSION: 6.3.9600.17041
STACK_COMMAND: .cxr 0xffffd00020d5dd90 ; kb
BUCKET_ID_FUNC_OFFSET: 1a4
FAILURE_BUCKET_ID: AV_dxgmms1!VIDMM_GLOBAL::ReferenceAllocationForPreparation
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:av_dxgmms1!vidmm_global::referenceallocationforpreparation
FAILURE_ID_HASH: {eef1921e-cdce-0263-9e71-094ac58a4229}
Followup: MachineOwner
Nema na čemu. Javi da vidimo, mada sudeći po dampovima, jasno je da je on problem.
Da, tokom Primea. Imam stari CPU, videcu da ga stavim ovih dana, docekao sam zadnji trenutak pa sam sad malo u guzvi sa faxom. Javim ovde kakvo je stanje.
Prosao intelov test...
--- Testing Processor 1 ---
--- IPDT64 - rev 2.10.0.0.MP ---
--- Start Time: 06/10/2014 22:30:46---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 50 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core2 Duo E8400 3.00GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 3.00
Detected CPU Frequency is --> 3.00008
CPU Frequency Test Passed!!!
--- Reading FSB ---
Expected FSB : --> 1333
Detected) FSB : --> 1333
CPU FSB Test Passed!!!
--- Running Base Clock test ---
--- This CPU does not support base clock test ---
..QPI rate Test not supported..
..Skipping QPI rate Test..
--- Running Floating Point test ---
Million Floating Points per Second, MFLOPS --> 302.4
Floating Point Test Pass ---
--- Running Prime Number Generation Test ---
Operation Per Second--> 1.32916e+006
Prime Number Generation Test Pass ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 2 x 32
- Detected L1 Inst Cache Size --> 2 x 32
- Detected L2 Cache Size --> 6144
- Detected L3 Cache Size --> Not Detected.
Cache Size Test Passed!!!
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> No
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- Not Tested
MMX SSE Testing Passed !!
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> No
AVX OS Support - AVX Operating System Supported --> No ---> No Test Required
AES - Advanced Encryption Standard Supported --> No ---> No Test Required
PCLMULQDQ - Polys Carry-Less Multiply Supported --> No ---> No Test Required
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- Not Tested
AES Test Result --- Not Tested
PCLMULQDQ Test Result --- Not Tested
No AVX AES PCLMULQDQ Tests required
--- IMC NOT Supported on this Processor ---
..Platform Controller Hub Test not supported curent chipset..
..Skipping Platform Controller Hub Test..
..Query 4..
--- Querying for Intel(R) Integrated Graphics Device (IGD) ---
..Intel(R) Integrated Graphics Device not supported on this processor..
..Skipping Intel(R) Integrated Graphics Device Presence Test..
--- CPU Load ---
--- Load Level = 8
CPU Load Passed!!!
Temperature = 46 degrees C below maximum.
--- Test End Time: 06/10/2014 22:34:46---
System Information
Processor Name: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Processor Information: Intel64 Family 6 Model 23 Stepping 10
Number of Physical Cores: 2
Number of Logical Cores: 2
Installed System Memory: 4 GB
Operating System: Microsoft Windows 8.1 Pro 64-bit
Graphics Information: NVIDIA GeForce GTX 260
System Product: P5KC
System BIOS: 1203
PASS
Sacu probati sa Burn In testom.
Prosao i burn in intelov test... Od jutros od ~pola 9 nije ni jednom BSODOvao... da onaj dxgmms ili sta vec nema veze sa DirectXom?
--- Start Time: 06/11/2014 08:28:20---
Temperature = 59 degrees C below maximum.
Detected CPU Frequency is --> 2.99514
--- Reading FSB ---
Million Floating Points per Second, MFLOPS --> 345.6
--- MMX SSE ---
..Query 4..
--- CPU Load ---
--- Load Level = 8
CPU Load Passed!!!
Temperature = 37 degrees C below maximum.
--- Test End Time: 06/11/2014 10:28:19---
System Information
System BIOS: 1203
PASS
I Lynxa prosao... Digao sam rucno ram na 1333, mozda ga je ovaj neki nizi koji je automatski stojao gusio... Stvarno vise ne znam....
LinX je sličan Primeovom small FFTu, dakle Prime pri blendu je bolji za testiranje opšte stabilnosti, ali čim prolaziš LinX, mislim da možemo isključiti procesor... Ovakav skup BSODova je vrlo često problem sa RAMom - podesi ga na njegov default ako ga ploča ne detektuje i pusti Windows Memory Diagnostic ili Memtest+ preko noći.
Ram je na defaultu izgleda radio na 667Mhz, otkad sam digao ram na 1333 nema BSODova. Sta znaci ono u biosu nesto DRAM kad se prebaci na N2 (ili 2N)? To sam na YT video da svi tako stavljaju.
E jesu ga iskomplikovali... MSI ih bije sa logikom biosa 😛
Odradi ti system file check.
Na Command Prompt desni klik pa Run as administrator.
Kucaj sfc /scannow pa pritisni enter, sacekaj da odradi.
^A drajver ništa? 😀
Ono što Mike hoće da kaže je da je to DDR2 i da se brzina memorije ponegde prikazuje kao polovina brzine - recimo, CPU-Z će prikazati brzinu RAMa tako... Nebitno, problem je skoro sigurno bio tamo - veliki broj različith BSODova ukazuje na RAM, kao što sam i rekao. A što se tiče 2N settinga, to je verovatno command rate - što manje, to bolje - mada ne utiče preterano na performanse RAM kod Intela...
Bem li ga... Sad ni temp. nije ko pre, izmedju 38-45 se drzi... Mada nije vise vrucina... Ostavicu ga sad ovako neko vreme pa cemo videti sta ce biti...
Pogledajte prilog 143935
Ako su ti BSODovi prestali, možeš biti miran - loše podešen RAM je bio problem, a tako nešto se uglavnom i manifestuje raznovrsnim BSODovima. Pretpostavljam da jesu pošto ništa nisi uploadovao?
sfc /scannow proveri da li su ti svi sistemski fajlovi OK - nema skoro nikakvog smisla to raditi ako imaš svežu instalaciju Windowsa , što se naravno i pokazalo... Još jedan u nizu nebuloznih saveta.
Da, nista se ne desava vec par dana, mada nisam narocito aktivno koristio komp. Ako se neki ponovo desi, izvestavacu 😀
Hvala za pomoc u svakom slucaju.
Gde to vide, to podesavanje rama?
Ono kada je podesio sa 1333 na 1333mhz? :d
Verovatno je pomoglo tvoje besumucno postovanje BSODova.
Čovek je promenio podešavanja RAMa, i nije baš najsigurniji šta je uradio... BSODovi su odmah prestali, a raznolikost u njima je siguran pokazatelj gde je bio problem. To što je poslušao tvoje savete je siguran pokazatelj da nije baš najsigurniji u ono što radi...
Stani da ponovim tvoje savete:
Imas problem sa ACPI drajverom.
Idi na http://www.asus.com/Motherboards/P5K...Desk_Download/
Izaberi Vista 64 bit i pod stavkom ATK skini
ACPI driver for ATK 0110 virtual device for Windows XP(32bit and 64bit)/VISTA(32bit & 64bit)
Instaliraj i restartuj PC,trebalo bi da ti resi problem.
Evo šta sam ja zaključio na osnovu BSODova - opet ti preporučujem da bar letimično pogledaš šta piše u njima, i da probaš da razumeš nešto, kad si već umislio da treba da daješ savete nekom:
BSOD tokom Primea?
Opet novi BSOD... Kod ovakvih problema, sa dosta različitih BSODova ja bih prvo proverio memoriju ali pošto su problemi počeli sa novim procesorom, možeš početi i od njega - hajde pusti https://downloadcenter.intel.com/Det...?DwnldID=19792 da vidimo da li će Intelov utility imati šta da kaže. Imaš li negde još uvek stari CPU?
Pročitaj još jednom čitav tred... Bilo bi dobro kad bi razumeo šta uopšte pišeš, ali što više gledam tvoje postove, vidim da samo ponavljaš ono što si negde pročitao, bez imalo razumevanja. Kao što rekoh, bilo bi dobro da se zaposliš u nekom od većih servisa - takvi se cene baš tamo. Eh da, i rekao i si da si me očekivao - reći ću ti i zašto treba da me očekuješ - kad vidim da si negde postovao, odem i pogledam šta si napisao i vidim opet neku glupost tipa "instaliraj drajver za ATK110 sa Viste na Windows 8 i rešićeš splet najraznovrsnijih BSODova" ili "pusti sfc /scannow na svež sistem" i pogledam koliko poruka imaš i shvatim da nećeš biti puno pametniji niti razumeti nešto više ni posle 3000 poruka... Šteta, trebalo bi da si to naučio još u osnovnoj školi - učenje napamet bez razumevanja je najuzaludniji i najtužniji oblik znanja. Eh, da - znam i gde si mi zapao za oko - u mom tredu o problemima sa MSI GTX 660 kartama gde si me savetovao da forsiram adaptive vsync, a ja dobijao TDRove na stock podešavanjima u Heavenu, gde frame rate ne prelazi 45 sa max podešavanjima i adaptive vsync nema nikakvog smisla. Kad sam te pitao odakle ti takva ideja, dao si potpuno nebulozno objašnjenje - verovatno iskustvo 😀. Pogledaj malo kako se završio taj tred, možda stvarno i stekneš neko iskustvo koje vredi nešto - ima dosta postova od ljudi koji razumeju problem.
Daj nesto novo, ponavljas se.
Kada ti ponestane agumenata, kreces sa "spletom" uvreda.
Nije to lepo...
Argumenti su ti napred, a istinu ne možeš nazvati uvredama. To što nije lepa za tebe, žao mi je...
Vuce, nije prvi put da prebrzo donosis zakljucke sta je resenje/problem, zaista nekad deluje kao da koristis prvo resenje na koje naletis preko google-a bez nekog dubljeg interesovanja za detalje.
Izvinjavam se MSI GTX 660 karti, ako ste imali neke neprijatnosti
u vezi mog nesmotrenog saveta.
To što ti daješ samo ti možeš nazvati savetima. Uostalom, da je bilo tad, dešava se - ali se to kod tebe dešava svaki put. Ja sam iskreno uveren da, pored toga što ne čitaš, ni ne razumeš ono što izguglaš baš najbolje - inače, ne bi uvek radio isto.
5x sam radio reinstalaciju windowsa, ali uzalud, nije u tome problem.
Slika se zamrzne, ili se odmah pojavi plavi ekran s onim ciframa. Nekad, pre nego se to desi, zacuje se na kratko neki zvuk u kucisti, kao da nesto zakrci i tad se umesto ciste zamrznute slike, slika po malo razmaze.
Testirao sam preko H-boot-a, HDD i on je ok, nema nijednu gresku.
Isto i RAM memorije sam testirao i one su ok. Jedna je Patriot (4gb) druga je Kingston (2gb).
Koliko se secam, kad sam ubacio ovu Patriot pre nedelju dana, poceo je komp da me zeza, kao da se nesto poremetilo. Pa sam pomisljao da nije problem jer se razlikuju memorije. Ispostavilo se da nije, jer posebno probam komp i sa jednom i sa drugom i opet mi se pojavi plavi ekran ili se zamrzne.
Maticna ploca je G41-P28M,
Procesor je E6600,
Graficka integrisana.
Niceg vise nema.
Ja sad sumnjam na maticnu plocu, ali nisam siguran.
Da li moze problem da pravi i mrezni stepen, ako dolazi do javljanja plavog ekrana ili je ipak do maticne ploce, ili procesora?
Razmisljam da probam da kupim neku drugu maticnu plocu, jer mi je ova nekako nikakva.
Koju biste mi bolju maticnu plocu preporucili uz ovaj procesor, ili neku drugu kombinaciju maticne i procesora?
Graficku ne bih kupovao, jer ne igram ja igrice.
HighONE@ evo obrisao sa driver od creative x-fi titanium pre pet sest dana i instalirao sa creative sajta novi driver i za sada nemam blue screen-ove prilikom paljenja kompa.Videcu jos koji dan kako ce se komp ponasati prilikom paljenja ali po svemu sudeci je problem bio u creativ driverima.Inace nisam koristio zvanicne drivere za x-fi titanium nego sa nekog sajta sam skinuo.
PAX MASTER PCIe Titanium Driver Suite 2013 V1.05 Default .Mozda su i ovo zvanicni,ne znam.
I to je sve radilo dobro jedno odredjeno vreme i onda je pocelo povremeno sa plavim ekranima prilikom paljenja.
U svakom slucaju videcu sta ce se desavati u sledecih 10-20 dana.
@ asix koje napajanje imas?
Mirise na problem sa napajanjem, probaj sa nekim proverenim.
@Vuk40, hvala sto si se javio da pomognes.
Izgleda da sam nasao problem. Evo za sada, vec nekoliko sati nema blokade, zamrzavanja, plavog ekrana.
Ja sam testirao i jednu i drugu RAM memoriju, test je pokazao da su OK, ali izgleda da se ne podnose ove dve memorije Kingston i Patriot, bar ne ovde kod mene, na mojoj maticnoj ploci, ili se ova Patriot RAM memorija nesto ne slaze samo s mojom maticnom plocom.
Pre ce da bude ovo drugo, jer sam isprobavao da samo nju postavim (kingston sklonim) i opet mi se kom zamrzava ili mi pokazuje plavi ekran.
Moracu da uzmem Kingston i vise nikad ne postavljam 2 razlicte memorije.
Vala sam se namucio. Vec nekoliko dana se rvam s ovim kompom.
Mislio sam da nije do ram memorija, jer sam ranije isprobavao isto da postavim svaku od memorija samu, ali nije radilo ni tad, a sad proradilo samo s ovom Kingston. Tad kad sam isprobavao, nije bila uradjena reinstalacija Windowsa, pa je mozda i on nesto bio los.
Nadam se da je problem u memoriji.
Gledam ovu moju maticnu plocu (ne svidja mi se uopste), cena joj je kao cena RAM memorije od 4 Gb 😀
HighONE@ opet danas sam popio blue screen i opet onaj famozni 0x1000007e.Nije ih bilo od 15.06.2014 do danas i taman sam se ponadao da je problem resen kad ono danas da upalim komp i iznenedjenje,opet plavi ekran.Sta jos mogu da probam da uradim ili mi preostaje da instaliram novi win 7?Moguci problem su mi driveri za x-fi titanium,to su neki pax driveri koje sam skinuo sa nekog sajta.Njih sam u medjuvremenu obrisao ali su mozda ostali neki repovi u registy ili negde drugo pa mi sad prave problem prilikom paljenja racunara.Da napomenem da se problem javlja iskljucivo kod paljenja racunara,dovoljno je onda da uradim restart racunara i sistem se podigne normalno.
Evo okacio sam sta mi ispisuje kao problem.
Sta bi ovo moglo biti?
I ovo...
Da li si instalirao poslednji drajver http://support.creative.com/downloads/download.aspx?nDownloadId=13078? SYSTEM_THREAD_EXCEPTION_NOT_HANDLED opet pokazuje na ha20x22k.sys.
