koji gpu ima ovaj prestigio? treba ovih dana da uzmem neki tab, pada izbor na ovaj, ali sam našao i ovo:
http://goclever.com/rs/rs/goclever_tab_a93.2#description za iste novce. za ovaj goclever lepo piše da ima mali400 što je skroz ok za ovakav tab, ali ima lošiju rezoluciju ekrana, plus što je 16:9 a ne 4:3. mada ta lošija rezolucija i nije tolika mana s obzirom da ostatak hardvera nije preterano jak, pa će igre raditi bolje. prestigio mi više uliva poverenja od ovog goclevera. ako prestigio ima neki kršten gpu koji može da gura dungeon hunter 2 i 3 recimo na ovoj rezoluciji mislim da ću definitivno njega. negde sam čitao da 5097 i 5080c imaju isti hardver unutra. ako je tako ljudi u temi za 5097 prijavljuju kako su igrali neke 3d igre, a taj tab ima višu rezoluciju što bi značilo da će na ovom 5080c raditi još bolje.
edit:
IJAO PA OVO IMA QUAD CORE MALI 400??
molim vas da mi neko potvrdi!
hvala
edit2: i ja verujem sajtu prodavca hardvera u srbiji... ovo izgleda ima Vivante GC800
The Multipad PMP5080B calculates with a very interesting application processor or so-called system-on-a-chip (SoC) from the Chinese manufacturer, Fuzhou Rockchip Electronics Co. Ltd. The PMP5080B is based on a single core RK2918 from Rockchip instead of one of the popular dual core SoCs, OMAP4 from TI or Tegra 2 from Nvidia. In keeping with the motto: It doesn't always have to be a dual core, the RK2918 exploits the potential of the Android Gingerbread 2.3 in the test. The tablet runs very stably and quickly in the test. Here are the details:
The Rockchip RK 2918 is manufactured by TSMC in a 55 nm process. It incorporates a Vivante graphics processor IP, model GC800, as a 3D/2D GPU in addition to an ARM Cortex A8 CPU core with a NEON SIMD engine and a clock rate of up to 1.2 GHz (PMP5080B 1 GHz), 512 KB L2 cache. The graphics unit also bids hardware acceleration for Adobe Flash Player 10.1. The Rockchip RK 2918 however integrates hardware based 1080p HD decoding from Google's Open Source VP8 Videocodec as a feature. The codec VP8 is used by the open WebM video format. WebM Projects is also the provider of the G Series 1 Video Decoder IP Design that Rockchip uses in its RK2918.
That sounds exciting because WebM Projects' Video Decoder Hardware IP G Series 1 allegedly manages with a clock frequency of less than 100 MHz and is nevertheless able to decode a 1080p video with 30 frames/s. The G Series 1 manages a maximum of up to 60 frames/s according to WebM Projects. The G Series 1 also supports unlimited multi channel decoding, which should enable a simultaneous playback of up to 10 SD video streams on one chip. And all that at a very low power consumption of less than 50 milliwatts in HD video decoding and less than 10 milliwatts in SD videos. We'd like to take a closer look at that.
the Vivante GPU GC800 of the RK2918 doesn't compute as good as the PowerVR SGX 530 of the TI
to je onda mnogo lošo :/
jel ima neko info iz prve ruke kako se pokazao ovaj vivante?
