Pioneer 393 Firmware - Pomoc
How to burn and install the firmware:
BURNING CD:
1. Launch Nero.
2. In the "New Compilation" pannel:
- top left part, choose "CD" in the drop-down list
- bottom left part, choose "CD-ROM (ISO)" in the icon list
In tabs, choose following options:
"Multisession" tab
- "No Multisession" must be selected
"ISO" tab
- File name length: "Max of 11 = 8 +3 chars (ISO level 1)"
- Format: "Mode 1"
- Character set: "ISO 9660"
- "Joliet": this option should be unchecked
"Label" tab
- Volume label - ISO 9660: "PIONEER" (without quotes, all capiatl letters)
"Burn" tab
- "Write" must be checked
- "Finalize CD" MUST BE checked!!
- Write Speed: "please do not select the maximum speed but rather an other less fast if possible"!
- Write Method: "Disk-at-once"
3. Click on button "New".
4. In the right window, choose the file corresponding to firmware (f.e.: "Y1B01160.BIN") and drag&drop it in the window most to the left.
5. Choose the menu "Recorder\Burn Compilation..."
6. Launch burning using the "Burn" button.
7. When the burning is launched, please check the box "Verify written data", to be sure of the date written during this session.
UPGRADING:
1. Turn on the player, and open the disc tray.
2. Put the Firmware Update Disc on the tray, and close the tray.
3. A screen will be displayed inviting you to push the "play" button to start the update.
4. The player will load the data, and the tray will open again. Remove the Firmware Update Disc from the tray now. Leave the tray open, as it is. And do not even touch the player untill upgrade is completed. The update process will complete in few minutes.
5. Wait until the update process finishes and the DVD logo is shown on the screen.
6. If your player is coneceted to your TV with SCART (RGB) cable, you may see black screen. Default video output setting is composite. So you need to conect composite cable and switch to RGB.
Attention!!!!! DO NOT unplug the power cable or turn off the player during the update process.!!!!!!!!!!!!!!
Da li je neko instalirao ovaj poslednji firmware i kakvi su utisci?
da li doticni ide u Pioneer 393 S i K?
Nisam ga probao, samo znam da su ga radili poznati ljudi koji prave fimwere za pioneer već dugo, dugo. Ko prvi proba nadam se da će javiti.
Oznaka "S" označava da je boja Silver, a oznaka "K" da je BlacK i to sigurno nema veze sa fimverom.
Radi dobro promenjen je meni tako da se vide i titlovi, duzi naslovi pesama se vide,popravljen izbor titlova na dvd u pan screnu, po meni u div-x su titlovi postavljeni jako nisko (tako da u titlu slovo j u donjem redu je u zadnjoj tacki na ekranu) mozda zavisi od tv.
Sve u svemu bolji od predhodnog.
HVALA!
Ovaj fw sam skinuo i naprzio jos tad kad si postavio link, ali nisam petljao sa plejerom, mahom sam gledao dvd-ove, pa mi nije ni trebalo. Neki dan, medjutim, naletim na starog snabdevaca od kojeg sam pazario hrpicu divixa, i ili nije bilo titla, ili su falila nasa slova (mesto gde bi trebala da budu je prazno), sto prilicno odvlaci paznju.
Nakon sto sam prema tvojim uputstvima instalirao novi fw, svi diskovi pokazuju titl, sa svim potrebnim slovima.
HVALA jos jednom!
Da li ce mi 393 davati sliku preko komponentnog(Y,Pb,Pr)kabla nakon ubacivanja firmwarea?:trust:
Neko je na ES pisao da nece al ne mogu da nadjem taj post.
Nesto u fazonu: radice samo SKART i onaj sa tri cincha(AudioL,AudioR,Video)
?:wave: ?
koliko sam ja upoznat, po defaultu je namesteno da radi preko scarta pa je potrebno da povezes samo 1 preko njega i podesis da radi preko kompozitnog i onda ce biti sve ok.
Upravo sam ga digao na YDA6824A-mod_v.3.0-by_Dinderi-Serbian&Croatian
Sve je OK :)
:wave:
Da, firmware je OK, ali šteta što pojačavanje tona daljinskim nisu uradili malo bolje, već se to svodi na minimum
To je mnogo bolje reseno na 380-ici ali posto Guifak vise nece raditi, a izgleda dinderi ne zna kako to da odradi mislim da necemo to ni dobiti na modelu 393, s obzirom da je vec izasao noviji model.
Ja koristim Dinderi 2.0 koji ima mogucnost biranja razlicitih velicina fonta i radi sve sto treba, tako da nisam ni stavljao Dinderi 3.0.
Kolega je kupio ovaj dvd plejer pa me je zamolio da za njega postavim pitanje... Flešovao je dinderijevim FW 3.0 i kaže da je sve ok, ali ne zna kako da pusti divx sa titlom čiji naziv nije identičan nazivu filma. Da li je to moguće uraditi?
Drugo pitanje je - da li je neko probao Robertov FW iz jula 2007? U njegovom readme piše da koristi titlove različitog naziva.
