napisao sam skriptu u PHP-u koja otprilike izgleda ovako:
$dbconn=pg_connect("host=moja_adresa port=moj_port dbname=moja_baza user=moj_user password=moja_sifra")
or die('Ne mogu da se konektujem: '. pg_last_error());
$upit = "select radnik_id from radnik";
$podaci = pg_query($upit);
while($podatak = pg_fetch_row($podaci))
$upit_prezime = "select prezime from radnik where radnik_id = \"$podatak[0]\"";
$prezime=pg_query($dbconn, $upit_prezime);
echo "$prezime\n";
prilikom izvrsavanja dobijam sledeci odgovor:
Warning: pg_query(): Query failed: ERROR: column "1" does not exist in ..... pa putanja do skripte
Warning: pg_query(): Query failed: ERROR: column "2" does not exist in ..... pa putanja do skripte
Warning: pg_query(): Query failed: ERROR: column "3" does not exist in ..... pa putanja do skripte
Warning: pg_query(): Query failed: ERROR: column "4" does not exist in ..... pa putanja do skripte
Warning: pg_query(): Query failed: ERROR: column "5" does not exist in ..... pa putanja do skripte
Kolone 1,2,3,4,5 zaista ne postoje.
1,2,3,4,5 su vrednosti koje se nalaze u koloni radnik_id i za te vrednosti zelim da mi vrati odgovarajuce prezime...
Nikako ne mogu da provalim u cemu je ovde problem.....
echo "$prezime\n";
