IvanziLLa
Kod:
The following folders do not require any changes:
blocks
db
images only requires uploading code.bg.jpg to the main images folder.
includes
language
themes
The following files require no changes:
backend.php
banners.php
config.php
header.php
index.php
robots.txt
ultramode.txt
The admin language file only requires a few lines added to the start of it right before:
Code:
define("_SEND","Send");
The New lines are:
Code:
define("_DOWNLOAD","Downloads");
define("_ENCYCLOPEDIA","Encyclopedia");
define("_FAQ","F.A.Q.");
define("_NEWS","News");
define("_REVIEWS","Reviews");
define("_ADMPOLLS","Survey / Polls");
define("_TOPICS","Topics");
define("_WEBLINKS","Web Links");
The following files must be deleted from the admin case, links and modules folder:
all files relating to content, faq, download, encyclopedia, links, polls, reviews, stories, topics and users.
The rest of the files in the case and links folders require no changes.
The following files are the only ones that need updating in the admin/modules folder:
authors.php
backup.php
forums.php
modules.php
newsletter.php
optimize.php
All module main files can remain as they are, the only change is that you will need to upload an admin folder into the following modules:
Content
Downloads
Encyclopedia
FAQ
News
Reviews
Surveys
Topics
Web_Links
Your_Account
The following file must be deleted:
auth.php
The upgrade74-75.php file must be run from the main directory (where mainfile.php and config.php are) and deleted once run. That's about it.
zainteresovan sam raditi upgrade ali se prvi put ovim bavim pa ne razumem sta je covek mislio sa ovim delom...
"....the only change is that you will need to upload an admin folder into the following modules:
Content
Downloads
Encyclopedia
FAQ
News
Reviews
Surveys
Topics
Web_Links
Your_Account ..."
ne razumem sta je heto da kaze... koji admin?
I da... ovi fajlovi dalje isto...
da li je mislio da se oni samo kopiraju preko njih novi ili????The following files are the only ones that need updating in the admin/modules folder:
authors.php
backup.php
forums.php
modules.php
newsletter.php
optimize.php
Thank You for your help,
Tane
