Password... Help?
  • Začetnik teme Začetnik teme golub
golub
Na XP instaliran pre nekoliko nedelja - pojavljuje mi se upozorenje, prilikom ukljucivanja kompjutera:
"Your password will expire in 14 days! Do you want to change it now?"
O cemu se tu radi ?
Ima li neko savet kako da iskljucim to cudo ?
Help...
:trust:
Moram da priznam da mi se to nikad nije desavalo ali pretpostavljam da ces se resiti toga tako sto odes na Users u Control Panel-u, izaberes svoj profil i tamo chekiras nesto shto lici na "Password never expires".. mozda negde gresim, ne koristim XP vec par meseci ali u sustini to bi trebalo da zavrsi posao.
Nasao sam u CP samo "User Accounts" ali nigde ne mogu da nadjem pomenutu opciju...
***... sad mi broji jos 13 dana ?
:type:
Nasao sam na Google-u:
1.. Go to Start > Run and in the Open: box type control userpasswords2
2.. Select the Advanced tab in the User Accounts window
3.. Press the Advanced button below the Advanced user management header
4.. Select Users in the Local Users and Groups
5.. In the right pane, right-click the user name for which you want to
change the setting, and select Properties
6.. On the General tab, check Password never expires
7.. Click Apply and OK (all the way out)
Hvala Wabbit😉
