raci je napisao(la):Moze li mi neko reci sta da radim sa Lily's bail bond,gde da idem.I jos jedna stvar Pisha(ona sto jede ljudsko meso) is downtouna mi je nalozila da nadjem dve items,jednu sam nasao u muzeju a gde da nadjem Giovanni Mension za drugu items?Ako neko zna...
borab je napisao(la):Kojem žanru pripada igra?
Na koliko je cd-a?
raci je napisao(la):Zna li ko resenje za leopold drustvo,igra mi stalno ispada posle skoka na camac,pocne da ucitava kraj nivoa i cvrc.
You may try this do escape from soc of Leopold
To enable the console for the game:
1) Right-click on the shortcut you use the launch the game
2) Select properties
3) Make sure you are on the shortcut tab
4) At the end of the target line add -console, add this outside of the quotes
5) The finished line should look like this if you have the game installed to
the default directory
"C:\Program Files\Activision\Vampire - Bloodlines\vampire.exe" -
console
6) Hit ok, make sure you launch the game using this shortcut
Once you have enabled the console load the saved game from this level
and do the following
1) Get to the boat and approach it, do not get into the boat, but get as close
as you can
2) Open the console using the tilde "~" key
3) Type the following commands in:
If you saved Johansen:
SaveJohansen()
Then to level transition if you're anybody but a Nosferatu:
changelevel2 la_hub_1 taxi_landmark
And if you're a Nosferatu, instead use:
changelevel2 la_hub_1 sewer_map_landmark
4) If you get to the next level and you do not have any items in your
inventory reload your previous save
(make sure you have a discreet save and are not just using the autosave)
and try it again, but stand
closer to the boat.
dok ne zavrsis!😉Majstor^Zivota je napisao(la):... igraj igraj ijrag lutaj lutaj lutaj igraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj lutaj lutajigraj igraj ijrag lutaj...
Roy Jones Jr. je napisao(la):Resenje:
Papss je napisao(la):A zasto imas potrebu da nas svakih 5 minuta obavestavas kako napredujes u igri? 😉 Mislim, koga to zanima? 😉
Da si rešavao i njegove kvestove, imao bi mogućnost na kraju da izabereš da se pridružiš njemu.. Ono, još jedan moguć kraj igre..Majstor^Zivota je napisao(la):I onaj Regent iz LA Downtown (onaj celavi sto lichi na Morfeusa) ko je taj baja? Nigde ga nema u prichi? Njegov quest takodje nisam ni pokusavao da resim, oko neke epidemije u LA-u.
