Wikipedia kaze:
With the 40-wire cable it was very common to implement cable select by simply cutting this wire between the two device connectors. This puts the slave device at the end of the cable, and the master on the "middle" connector. This arrangement eventually was standardized in later versions of the specification. If there is just one device on the cable, this results in an unused "stub" of cable. This is undesirable, both for physical convenience and electrical reasons: The stub causes signal reflections, particularly at higher transfer rates.
When the 80-wire cable was defined for use with UDMA4, these details were changed. The master device now goes at the end of the cable, so if there is only one device on the cable, there is no cable "stub" to cause reflections. Also, cable select is now implemented in the slave device connector, usually simply by omitting the contact from the connector body. Since 80-wire cables require special connectors anyway, this was a small additional effort. The standard also dictates color-coded connectors for easy identification by both installer and cable maker.
Da te malo ispravimSvaki 40-pinski IDE kabl je takav kakav trazis
Dobro, dobro. OK je ljudi. Bilo je nekad siguran sam. Ali mi nije bilo vazno.
Sada SVAKI koji ide uz ploce ili sta vec je pravljen master na kraj. Ako HDD stavis nisko, pa hoces samo sistemski da hladis, a slave da didnes iznad njega imaces problem.
A sad mi treba. Gde se moze naci?
Ja tebe ne razumem. Uzmi bilo koji ATA100 kabl i povezi uredjaje kako hoces. Naravno, jedan mora da bude master a drugi slave i to se namesta preko dzampera. To sto ti na jednom konektoru pise master a na drugom slave ti uopste nije bitno.
Jedan od kablova je kupljen prekjuče a jedan pre dve godine (ovaj sto je zamenjen je došao uz ploču, ali se razglavio od stavljanja/skidanja).@jddipqd E da, baš je uz tu generaciju ploča i BX dolazio takav kabl. Ono HDD master dole, a opt slave gore i taman.
Poslednjih godina nekako upravo suprotno, mada i nisam vodio narocito racuna.
Ma da...i kad ti zapadne WD pa se iscimash jer on tradi da radi bez dzumpera ako je sam na grani tj. single, Nece chak da radi i kad je setovan kao master iako je sam na grani.
Iscimah se prekljuche...ne mozesh da povezsh 4 uredjaja a da ti svi kablovi dohvate kako ti zelish. Epilog. HDD fioka u kompu je ostala nepovezana i cheka duzi IDE kabal.
Ziveo SATA..da umre PATA shta drugo reci ..![]()
