Neobican(!?) ATA kabl
  • Začetnik teme Začetnik teme churla
churla
Dakle ima li negde da se nadje ATA kabl kod koga je na njegovom kraju slave konektor, a na serdini master?
Svaki 40-pinski IDE kabl je takav kakav trazis.
Ustanovljeni standard za ATA66 kablove (80-pinske) ne dozvoljava da master bude u sredini (ima veze sa odbijanjem signala od krajnjeg "konektora" ukoliko se ne koristi, a uredjaj je zakacen na "srednji" konektor - stvaraju se suvisne interferencije). Znaci, jedino ako neko pravi bas nestandardni kabl, ali mislim da neces imati srece da to nadjes....
@Ostoja: Jesi li siguran? Jesi li probao da povezes Master na srednji konektor a Slave na krajnji? :trust: Ne bih se slozio sa tobom. Tu je samo pitanje dzamperisanja uredjaja.
Meni su uvek (dok sam imao IDE diskove) bili masteri na srednjem konektoru, a "robovi" na krajnjem...?
Nisam nista rekao za dzamperisanje, samo za kabl 😉.
Wikipedia kaze:
With the 40-wire cable it was very common to implement cable select by simply cutting this wire between the two device connectors. This puts the slave device at the end of the cable, and the master on the "middle" connector. This arrangement eventually was standardized in later versions of the specification. If there is just one device on the cable, this results in an unused "stub" of cable. This is undesirable, both for physical convenience and electrical reasons: The stub causes signal reflections, particularly at higher transfer rates.
When the 80-wire cable was defined for use with UDMA4, these details were changed. The master device now goes at the end of the cable, so if there is only one device on the cable, there is no cable "stub" to cause reflections. Also, cable select is now implemented in the slave device connector, usually simply by omitting the contact from the connector body. Since 80-wire cables require special connectors anyway, this was a small additional effort. The standard also dictates color-coded connectors for easy identification by both installer and cable maker.
Da te malo ispravim😉
Nije svaki 40-pinski IDE kabl takav vec samo onaj kome je prekinut vod 28. pina izmedju master i slave konektora. U tom slucaju master i slave menjaju mesta.
Aj' da ne razglabam dalje😉
Dobro, dobro. OK je ljudi. Bilo je nekad siguran sam. Ali mi nije bilo vazno.
Sada SVAKI koji ide uz ploce ili sta vec je pravljen master na kraj. Ako HDD stavis nisko, pa hoces samo sistemski da hladis, a slave da didnes iznad njega imaces problem.
A sad mi treba. Gde se moze naci?
Ja tebe ne razumem. Uzmi bilo koji ATA100 kabl i povezi uredjaje kako hoces. Naravno, jedan mora da bude master a drugi slave i to se namesta preko dzampera. To sto ti na jednom konektoru pise master a na drugom slave ti uopste nije bitno.
U mašini imam 2 harda, svaki je master na svojoj grani i svaki se nalazi na srednjem konektoru. Jedan ima slave, jedan nema i nijedan ne pravi probleme.
Nije baš tako. Recimo secondary grana, hoces da uredhaj na vrhu kucista bude slave.
BTW Sad se setih da mozda negde imam ata66 jedan takav.
U svakom slučaju ne možeš džamperisti po želji.
Pa šta radi cs (cable select) onda!?
@jddipqd E da, baš je uz tu generaciju ploča i BX dolazio takav kabl. Ono HDD master dole, a opt slave gore i taman.
Poslednjih godina nekako upravo suprotno, mada i nisam vodio narocito racuna.
Ako stavis uredjaj na CS onda ako je na kraju kabla on je MASTER a ako je na sredini onda je SLAVE. Ako ga preko dzampera podesis da bude MASTER(/SLAVE) onda je taj uredjaj MASTER(/SLAVE) nebitno od pozicije na kablu. Naravno, ne mozes imati 2 master ili 2 slave uredjaja na istom kablu.
Jedan od kablova je kupljen prekjuče a jedan pre dve godine (ovaj sto je zamenjen je došao uz ploču, ali se razglavio od stavljanja/skidanja).
ako ne koristis opciju CS ili ti cable select sve jedno je koji ATA kabal koristis, tj to regulises dzamperima na samim HDDovima, ako koristis opciju CS (ja moram priznati da nikad u zivotu nisam imao potrebu da je koristim) onda zavisi od rasporedu na kablu koji ce biti master a koji slave, a za razliku izmedju ta dva kabla Xeg je vec postovao
Ma da...i kad ti zapadne WD pa se iscimash jer on tradi da radi bez dzumpera ako je sam na grani tj. single, Nece chak da radi i kad je setovan kao master iako je sam na grani.
Iscimah se prekljuche...ne mozesh da povezsh 4 uredjaja a da ti svi kablovi dohvate kako ti zelish. Epilog. HDD fioka u kompu je ostala nepovezana i cheka duzi IDE kabal.
Ziveo SATA..da umre PATA shta drugo reci ..😀
Pa ponekad treba procitati i uputstvo :d, imam WD na kom lepo pise dzamper na master samo ako je u paru inace ga ne stavljajte :-devil-:
Evo posto sam i zapoceo ovo ...
Dakle, nisam sada probao da samo dzampere prebacim i vidim sta ce se desiti jer znam da mi teac540 (ma sve cita!) nije radio nikako sa "slobodnim podesavanjem" dzampera (cak ni sa cs). Dopustam da neke kombinacije tako hoce OK da fukncionisu, ali se cesto desi da kad dodas drugi uredjaj na tu granu prosto vise ne funkcionise. Moguce da zavisi od uredjaj do uredjaja, a mozda je i do rtfm. Bas imam WD i nisam primetio ovu vaznu opasku koju je ZAP izneo.
nisam rekao da to vazi za svaki vec za jedan od onih koje ja imam 🙂
pogledaj
Ma definitivno Teac40x CDRW pravi problema drugim uredjajima ako se nadju na istoj grani, pogotovo HDD-ovi.
Ja sam moj izbacio oz mashine jer necu da mi gushi NEC-a bezveze, a cd-ove i ovako mogu da procitam i rezem sa NEC-om.
Shto se tiche WD. Pa kad nece da se mashina boot-uje ...zna se....WD u mashini i njegovo bezvezno jamperisanje.
Obichno i proche ako je setovan na master....a sam je na grani zavisno od mashine..ali mu treba vremena da bude detektovan.
mali off. Meni je Pioneer 109 pravio haos kada je jos neki uredjaj bio s njim na grani, bilo hard bilo druga optika, bilo master, bilo slave. ili sam, ili nikako! A za kablove, nikada nisam primetio bilo kakav problem sa polozajem master/slave-a. Da ne pricam sad napamet, morao bih da proverim kako su mi trenutno povezani...
