fkloznica
Uticajan
Ima ovde malo o zvuku. Možda je neko već kacio ali zbog tt ne mogu da vidim.
https://youtu.be/i6LFVF9LTOI
Ma pljuvanje u prazno 😀Da mi je neko pricao pre jedno 5 godina da ce mana telefonu da bude to sto nema skener irisa, smejao bih se, ovako sad mogu da kazem samo no comment, kako li su ljudi do sad ziveli bez toga pitam se.
Key Specifications: 3
Chipset: Qualcomm® Snapdragon™ 820 Processor
Display: Main 5.7-inch QHD IPS Quantum Display (2560 x 1440 / 513ppi) /
Secondary IPS Quantum Display (160 x 1040 / 513ppi)
Memory: 4GB LPDDR4 RAM / 64GB UFS ROM / microSD (up to 2TB)
Camera: Front 5MP with F1.9 Aperture (Wide Angle) / Rear 16MP with F1.8 Aperture OIS (Standard Angle) and 8MP with F2.4 Aperture (Wide Angle)
Battery: 3200mAh (removable)
Operating System: Android 7.0 Nougat
Size: 159.7 x 78.1 x 7.6mm
Network: LTE-A 3 Band CA
Connectivity: X12 LTE (up to 600 Mbps LTE Category 12 with 3x Carrier Aggregation) / Wi-Fi (802.11 a, b, g, n, ac) / USB Type-C / Bluetooth 4.2 BLE / NFC
Colors: Titan / Silver / Pink
Others: Hi-Fi Video Recording / Steady Record 2.0 / HD Audio Recorder / Studio Mode / High AOP Mic / Second Screen / 32-bit Hi-Fi Quad DAC / In Apps / B&O Collaboration / Finger Print Scanner / Qualcomm® Quick Charge™ 3.0
To achieve both a sophisticated look and solid durability, LG uses lightweight aluminum, together with a new silicon-based material. AL6013 metal, found in aircraft, sailboats and mountain bikes, was selected to cover the back of the phone due to its sturdy but light properties. If dropped, the top and bottom of the phone are protected from damage by Silicone Polycarbonate (Si-PC). This innovative material, found in helmets, reduces shocks by more than 20 percent compared to conventional materials.
The LG V20 has also passed the MIL-STD 810G Transit Drop Test for durability conducted by an independent laboratory that conforms to U.S. military standards. The test determined that the V20 could withstand shocks and still function when dropped repeatedly from a height of four feet and landing in various positions, including the front, back, sides and corners.
Cekamo da ga neko upari sa V4A, na sta li ce to da lici 🙂@ Ivan I
Kazu da v20 ima brutalno jako pojacalo, DAC je takodje brutalan na papiru (dosta toga zavisi od implementacije, valjda to nece zayebati) tako da je ovo pravi smartfon za audiofile.
A tebe najvise interesuje jacina zvuka, dakle V20 sa pojacalom je za tebe.
Sent from my D6503
Ne znam sto bi instalirao v4a na ovakav dac.
