Kako otpakovati *.par arhivu?
mikihog
Pristup internetu
  1. Kablovski internet
sledeci fajl je .p01, p02...
probaj Quickpar. www.quickpar.org.uk
PAR / PAR2 files are "parity" files. These files are used to rebuild incomplete RAR or HJSplit file sequences when some of the needed files are missing. The program Quickpar can use the data in the PAR files to fill in the holes in the other files. WIth PAR files you usually need ALL the PAR parts to rebuild one missing RAR or 00X file, but with PAR2 files you can try downloading just a few of the PAR2 files and see if Quickpar can rebuild it, and if not, leep downloading a few more PAR2 files until there is enough to rebuild everything.
Nece s quickparom.
Jel ima neko resenje?
