thedraganche
Cenjen
Pozdrav,
Hteo bih da napravim bass reflex kutiju za ovaj subwoofer,pa mi treba pomoc ,kako,sta,koji materijal,koliko bi me materijal izasao,itd, itd
Ovo je sub. :
http://www.autoaudio.wsc.cz/Woofer/RA/RA10W.jpg
Radical Audio Reference Series 10" / 25cm Subwoofer
ovo su jedini podaci koje sam iskopao na netu:
pecifications RA10W
* Frequency response 25-150 Hz
Rated power * 300 watts RMS
Music power handling 500 watts *
Impedance 4 Ohm
Voice coil diameter 2 "/ 51 mm
Mounting diameter 227 mm
Mounting depth 164 mm
Free-Air Resonance (Fs) 33.5 Hz
DC Resistance (Re) 4.3 Ohms
Electrical Damping (Qes) 00:45
Mechanical Damping (Qms) 4.9
Total Damping (Qts) 00:41
Equiv. Volume of Compliance (Vas) 30.5 liters
Effective Surface Cone (Sd) 346 cm ²
Elect. Lim Cone Excursion (Xmax) 8.8 mm
Displacement Volume of Cone (Vd) 752 cc
Efficiency (Ref) 86.0 dB/W/1m
Closed housing
Net volume of 25 l
Bass reflex enclosure
Net volume of 36 l
BR-diameter pipe 1 x 10 cm
BR-Pipe length 27 cm
Bandpass enclosure
Net volume vented chamber 25 l
Net volume enclosed chamber 22 l
Length BR-Pipe 14-17 cm
Subwoofer je sada u kompresionoj kutiji koja je naknadno pravljena i ni malo mi se ne svidja zvuk,lik od kojeg sam ga kupio kaze da je sub. dosao uz bass reflex kutiju fabricku,ali je covek to skinuo i bacio Moze li se sta iskopati iz ovih podataka o specifikacijama bass reflex kutije koja bi ovom zvucniku savrseno odgovarala?
Hvala
Ovo je sub. :
pecifications RA10W
Impedance 4 Ohm
Closed housing
Net volume of 25 l
Net volume of 36 l
Bandpass enclosure
Hvala
