Headers and Footers u word-u
miodrag
Imam jedan problem. U word-u 2003 sam napisao rad. E sada trebam da dodam 4 blanco strane na pocetku dokumenta. Problem je sto kada dodam na svakoj se pojavljuje "Headers and Footers" i broj strane. A broj i Headers and Footers trebaju da se pojavljuju tek na 5 strani. Hitno mi je :wall::wall:
You can use a calculated field for this. In your footer, create a field like this:
{ IF { PAGE } < 5 "" { PAGE } }
This will display nothing for page 1 and page 2 (i.e. page < 5), and then start displaying for page 5 and further.
To create it, use Alt-F9 to toggle the field code view. Type (or copy from here) the following:
IF PAGE < 5 "" PAGE
ukoliko ovo ne upali moze i pesacki ovako>
1. On the page you wish you start the numbering (let's say it's page 4 for this example), insert a "Next Page" section break.
2. From the View menu choose Header and Footer.
3. Click in the footer of page 4.
4. On the Header and Footer toolbar, click the "Link to Previous" button to break the link between page 4's footer and the footers on page 1-3. You'll notice that the note at the top of the footer that said "Same as Previous" has disappeared.
5. Click in the footer of page 4 to make sure your cursor is inside it.
6. From the Insert menu, choose Page Numbers.
7. Click the format button and select the radio button for Start At and enter 1 in the box. Click OK.
8. Counterintuitively, you'll need to leave the box for show number on first page checked, since technically you're starting the numbering on the first page of the new section, so click OK at this screen.
9. Your page numbering should now start at 1 on page 4 and will not appear on any previous pages, but will continue to appear on any subsequent pages
Uf nesto mi ne ide. Hvala ti svejedno. (Da li je ovo za word 2007, ili 2003.). Imam oba, ali me zanima?
Pozicioniraj se na početak sadašnje prve strane,ispred prve rečenice . Idi na Insert>Break>Next Page (znači obavezno "next page" to je četvrta opcija po redu, ne onu prvu opciju "page break")
Sada ti je napravio praznu stranu. Idi na drugu stranu, tj. onu gde ti je sada početak teksta. Klikni dva puta na područje headera ili idi na View>Header and Footer. Odčekiraj osmu ikonicu koja ima naziv "link to previous". Klikni na treću ikonicu "format page number". Kad ti se otvori prozor za formatiranje pod page numbering idi na "Start at" i stavi "1". Vrati se na prvu stranicu, onu koja je sada prazna. Istom procedurom uđi u Header and Footer i obriši iz njega sve što ti ne treba, uključujući i broj stranice. Sa enter ili Insert>break>page break napravi nove 3 prazne stranice. Kraj procedure. 🙂
HVALA BRATE. Spasao si me. Dugujem gajbu piva :bottle:
