Genius Eye 110.
http://www.geniusnet.com/Genius/wSite/ct?xItem=16738&ctNode=159
Evo bas pisu o mom problemu:
When I want to use the camera, I get an error message that the camera is not present or the camera is already in use. What should I do?
1. Verify that the camera has been loaded in the System Device Manager.
Please go to the System Device Manager and check if there is any device with marks. If yes, please right click the device and then refresh the driver. If the device can't be installed successfully, please disconnect the camera and then re-install the camera driver. Connect the camera to the USB port of your pc and follow on screen wizard to finish installing process.
2. Please install the latest version of DirectX.
Please uninstall the camera driver and download the latest version of DirectX via internet. Install the latest version of DirectX and then re-install the camera driver.
3. Verify that the camera has been loaded in the System Device Manager.
Jedino ovaj DirectX neznam kako stoje stvari u windowsu 10,mada sam isti problem imao i u win-u 8.1.
