Doom 3 problem
  • Začetnik teme Začetnik teme stoske
stoske
Pristup internetu
  1. Optički internet
instalirao sam juce doom3.. sve je proteklo bez problema....
ali kada startujem igricu pojavi mi se ekran sa ovim textom:
DOOM 1.3.1302 win-x86 May 12 2005 10:40:52
2101 MHz AMD CPU with MMX & 3DNow! & SSE
1024 MB System Memory
128 MB Video Memory
Winsock Initialized
Found interface: {5A417CBA-CDE6-4546-93DD-DC2B55E546AB} VIA Rhine II Fast Ethernet Adapter - 192.168.254.3/255.255.255.0
Sys_InitNetworking: adding loopback interface
doom using MMX & SSE for SIMD processing
enabled Flush-To-Zero mode
------ Initializing File System ------
Loaded pk4 C:\Program Files\Doom 3\base\game00.pk4 with checksum 0xf07eb555
Loaded pk4 C:\Program Files\Doom 3\base\pak000.pk4 with checksum 0x28d208f1
Loaded pk4 C:\Program Files\Doom 3\base\pak001.pk4 with checksum 0x40244be0
Loaded pk4 C:\Program Files\Doom 3\base\pak002.pk4 with checksum 0xc51ecdcd
Loaded pk4 C:\Program Files\Doom 3\base\pak003.pk4 with checksum 0xcd79d028
Loaded pk4 C:\Program Files\Doom 3\base\pak004.pk4 with checksum 0x765e4f8b
Current search path:
C:\Program Files\Doom 3/base
C:\Program Files\Doom 3\base\pak004.pk4 (5137 files)
C:\Program Files\Doom 3\base\pak003.pk4 (4676 files)
C:\Program Files\Doom 3\base\pak002.pk4 (6120 files)
C:\Program Files\Doom 3\base\pak001.pk4 (8972 files)
C:\Program Files\Doom 3\base\pak000.pk4 (2698 files)
C:\Program Files\Doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
Addon pk4s:
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
4966 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
couldn't exec DoomConfig.cfg
couldn't exec autoexec.cfg
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...PIXELFORMAT 10 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
...using GL_ARB_multitexture
...using GL_ARB_texture_env_combine
...using GL_ARB_texture_cube_map
...using GL_ARB_texture_env_dot3
...using GL_ARB_texture_env_add
...using GL_ARB_texture_non_power_of_two
...using GL_ARB_texture_compression
...using GL_EXT_texture_compression_s3tc
...using GL_EXT_texture_filter_anisotropic
maxTextureAnisotropy: 16.000000
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
...using GL_EXT_texture3D
...using GL_EXT_stencil_wrap
...using GL_NV_register_combiners
...using GL_EXT_stencil_two_side
X..GL_ATI_fragment_shader not found
X..GL_ATI_text_fragment_shader not found
...using GL_ARB_vertex_buffer_object
...using GL_ARB_vertex_program
...using GL_ARB_fragment_program
...using EXT_depth_bounds_test
---------- R_NV20_Init ----------
----------- R200_Init -----------
Not available.
---------- R_ARB2_Init ----------
Available.
----- R_ReloadARBPrograms -----
glprogs/test.vfp
glprogs/test.vfp
glprogs/interaction.vfp
glprogs/bumpyEnvironment.vfp
glprogs/ambientLight.vfp
glprogs/shadow.vp
glprogs/R200_interaction.vp
glprogs/nv20_bumpAndLight.vp
glprogs/nv20_diffuseColor.vp
glprogs/nv20_specularColor.vp
glprogs/nv20_diffuseAndSpecularColor.vp
glprogs/environment.vfp
glprogs/arbVP_glasswarp.txt: File not found
glprogs/arbFP_glasswarp.txt: File not found
using ARB_vertex_buffer_object memory
using ARB2 renderSystem
found DLL in pak file: C:\Program Files\Doom 3\base\game00.pk4/gamex86.dll
copy gamex86.dll to C:\Program Files\Doom 3\base\gamex86.dll
3 22 640 480
Regenerated world, staticAllocCount = 0.
Shutting down sound hardware
idRenderSystem::Shutdown()
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...shutting down QGL
...unloading OpenGL DLL
wrong game DLL API version
da li neko zna o cemu se radi?
Reinstaliraj DX9, drivere za Atija (koliko vidim, on je u pitanju). Da li si do kraja zavrsio sa instalacijom igre? Aki si non-stop na internetu, otkaci se sa istog pre nego je startujes.
moguce da je zbog directx-a mada imam 6600gt.....
zavrsio sam instalaciju do kraja....igra startuje i onda ovo izbaci...
p.s jesam non stop na netu....
probao sam da se skinem sa net.... ista poruka...
sada cu da probam sa DirectX
...wrong game DLL API version
Da nisi pokusavao da patchujes igru, ili si nesto prckao po base direktorijumu?
i meni ovo lici na nesto sto se meni pojavilo kad sam patchovao Doom3 a ondak lupio stari c****.
igra je skinuta sa neta (u paketu) i stigla je sa kr**** ...ja sam je samo instalirao...
moguce da kr*** nije ispravan....
