Nije aktuelno Asus MX279H IPS 27" monitor
hamvas
Cenjen
Asus MX279H - u odličnom stanju, originalno pakovanje
125 eura
Poslednja ponuda i to zato što idem na put uskoro.
062/83-40-947
Panel Size (inch) : 27
Aspect Ratio : 16:9
Display Surface : Non-Glare
Backlight Type : LED
Panel Type : IPS
Viewing Angle (CR≧10, H/V) : 178° / 178°
Pixel Pitch : 0.311mm
Resolution : 1920x1080
Brightness (Typ. ) : 250cd/㎡
Contrast Ratio (Typ. ) : 1000:1
ASUS Smart Contrast Ratio (ASCR) : 80000000:1
Display Colors : 16.7M
Response Time : 5ms(GTG)
Refresh Rate (Max) : 60Hz
Flicker-free : Yes
Trace Free Technology : Yes
SPLENDID Technology : Yes
QuickFit : Yes
HDCP : Yes
Low Blue Light : Yes
HDMI(v1.4) x 2
VGA x 1
Earphone Jack : Yes
Digital Signal Frequency : 30~80 KHz (H) / 56~76 Hz (V)
Analog Signal Frequency : 30~80 KHz (H) / 56~76 Hz (V)
Tilt : Yes (+20° ~ -5° )
Kensington Lock : Yes
Phys. Dimension with Stand (W x H x D) : 622.6 x 441.3 x 225.2 mm
Box Dimension (W x H x D) : 700 x 537 x 114 mm
Net Weight with Stand : 5.2 Kg
Gross Weight : 8.0 Kg
HDMI cable
Power adapter
Power cord
VGA cable
    290 KB · Pregleda: 62
