enDuRo99
- AMD Ryzen 7 7700 & Thermalright Peerless Assassin 120
- Gigabyte B650M Aorus Elite AX rev. 1.3
- Kingston Fury Renegade 2×16GB DDR5 6000MT/s CL32
- Gigabyte Aorus RX 6800XT Master Type C 16G
- Kingston KC3000 1TB, ADATA SX8200 Pro 2TB
- Zvuk
- Realtek Integrale & Microlab FC570BT & White Shark WGH 2442 Butterfly
- Corsair RM750x (2021)
- NZXT H6 Flow (White)/Thermalright: TL-G12, TL-H12W-X28 ×3 + DeepCool SC790
- Monitor
- BenQ Mobiuz EX2710R
- Miš & tastatura
- Keychron M7 (White)/Royal Kludge RK-H81 + Leobog K21 (Chartreuse Switch)
- Ostale periferije
- Xbox Wireless Contro
- Mobilni telefon
- Xiaomi 13T (Black)
- Pametni uređaji
- Huawei Watch GT 4 (Green), Amazfit T-Rex 2 (Wild Green)
- Kablovski internet
1. Arctic P12 Max (Beli) - 2 komada
www.arctic.de
Korišćeni manje od 3 meseca. U garanciji do 03.03.2026.
1200 dinara komad
2. Alphacool Core 6x PWM/aRGB hub
shop.alphacool.com
U pakovanju jedino fali lepljiva čičak traka za montiranje na kućište.
U garanciji do 06.07.2025.
1500 dinara
3. Noctua NA-HC2 chromax.white
noctua.at
Poklopac hladnjaka za NH-U12S kulere.
800 dinara
4. Noctua NA-SYC1.red
noctua.at
PWM razdelnici, sa bužirom u crvenoj boji.
3 komada - 700 dinara
5. Jabra Talk 5
www.jabra.com
Blutut slušalica.
1200 dinara
Kontakt preko poruka ili na 069/701-425
P12 Max | 120 mm High-Speed PWM-Lüfter | White | ACFAN00293A | ARCTIC
ACFAN00293A | Der P12 Max in weiß ist ein High-Performance 120 mm PWM Lüfter | PWM Sharing Technologie (PST) | Kostenlose Lieferung in DE | Schnelle Abwicklung und Lieferung | ARCTIC Store
1200 dinara komad
25668 Alphacool Core 6x 4-pin PWM/DRGB splitter with SATA power connector
Alphacool's Core PWM/DRGB splitter has six 3-pin ports for controlling digitally addressable RGB elements and six 4-pin ports for controlling fans…
1500 dinara
The NA-HC2 chromax.white heatsink cover is an add-on accessory for Noctua’s award-winning NH-U12S, NH-U12S TR4-SP3, NH-U12S SE-AM4 and NH-U12S DX-3647 CPU coolers. Made from high-quality aluminium with white powder-coating finish, it allows users to give the cooler a sleek snow-white look that...
800 dinara
NA-SYC1 chromax.red
The NA-SYC1 chromax.red is a fan accessory set consisting of three NA-YC1 y-cables that make it possible to run two 4-pin PWM fans on a single fan header and to let the motherboard control the speed of both fans simultaneously. Multiple NA-YC1s can be daisy-chained to control more than two PWM...
5. Jabra Talk 5
Jabra Talk 5 Mono-Bluetooth-Kopfhörer
Jabra Talk 5 Mono-Bluetooth-Kopfhörer wurden für einfaches und müheloses Telefonieren entwickelt. Genießen Sie schnurlose Anrufe in höchster Qualität bei bis zu 9 Std. Akkulaufzeit.
1200 dinara
