filip83
- Monitor
- LG 65G3
- Ostale periferije
- PS5
- Laptop
- Asus ROG Zephyrus gx502gw
- Tablet
- Xiaomi pad 5
- Mobilni telefon
- S24 ultra
- Pametni uređaji
- Galaxy watch 5 pro
- Optički internet
Novi kuleri za azdaje
http://www.tweaktown.com/pressrelea..._unveils_accelero_xtreme_5970_5870/index.html
Tweaktown je napisao(la):Excellent cooling performance
Both models are equipped with three 92mm PWM fans running from 900 to 2,000 RPM, generating 81 CFM airflow for efficient heat dissipation from the core(s). The Accelero XTREME 5970 is designed with an 8-heatpipe and 119-fin architecture to achieve 300 watts cooling for the dual-GPU Radeon HD5970. Whereas the Accelero XTREME 5870 comes with 5 heatpipes and 84 fins, providing 250 watts cooling capacity for the Radeon HD5870. A layer of the ARCTIC MX-2 thermal compound is also pre-applied on the base of these two coolers. The results are very promising– the GPU temperature of Radeon HD5970 and HD5870 is now 40°C and 36°C lower respectively than using the stock cooler. This enhances not only the overclocking performance, but also extends the service life of your valuable VGA card.
