jddipqd
Napravio sam web servis, uz korišćenje AXIS 1.5, i sam servis radi bez problema. Međutim kada pokušam da generišem wsdl (sa http://www.example.org/WebService?wsdl) dobijem ovu grešku:
Kostur servisa je generisan pomoću WSDL2Java (wsdl je ručno napisan).
Da li je neko imao sličnih problema?
Kod:
Fault - makeTypeElement() was told to create a type "{http://www.example.org/WebService}>tip", with no containing element
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.generalException
faultSubcode:
faultString: makeTypeElement() was told to create a type "{http://www.example.org/WebService}>tip", with no containing element
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}hostname:HOST
