A wakelock, in layman’s terms, is just a way for an app to keep the CPU/screen/other things awake when the phone is idle in order to perform a specific background task. Some apps do legitimately need wakelocks in order to function properly, but the problem comes when some applications hold wakelocks repeatedly, hold them for a long time without dropping them, or do excessive/unnecessary network and CPU tasks taking advantage of these wakelocks.
Case in point: apps like Snapchat, Facebook, Messenger or other social media apps include misbehaving wakelocks. This tutorial is simply a way to stop these wakelocks from happening again without uninstalling the app. If, however, you notice that the app stops functioning correctly after using this ADB command, you can change things back to the way they were by re-running the command and changing “ignore” to “allow”, or by simply uninstalling then re-installing the app again.
Project Treble modularizes the Android OS framework to separate it from vendor code, allowing OEMs to work on new software updates without having to wait for vendors (like Qualcomm) to update their code. As part of the Vendor Test Suite (VTS), all Treble-enabled devices must be able to boot a raw, generic AOSP build. Project Treble support is required on any device shipping with Android Oreo,
Taj rad, muzi sirotinju do zadnjeg momentaZato note8 dolazi sa 7.1osećam da će 7.1 biti i na s9
Sent from my SM-G950F using Tapatalk
After 20 hours of work researching, developing, and debugging with me, phhusson created a system image that can be booted on multiple devices from different manufacturers and with completely different SoCs. For example, the same system image that I booted on my own Huawei Mate 9 also boots on the Honor 8 Pro, Honor 9, Sony Xperia XZ1 Compact, and the Essential Phone. That’s 3 different OEMs (Huawei/Honor, Sony, and Essential) and 2 different SoCs (HiSilicon Kirin 960 and Qualcomm Snapdragon 835) where this single system image can successfully boot.
It’s possible that in the future, we could be seeing a single system image that can work on dozens of different Android smartphones, much like how Microsoft Windows can run on nearly any computer hardware.
Cak su i potvrdili da ce S6 dobiti oreo [emoji4]Sad razmišljam, pošto će S7/edge dobiti isto oreo kao poslednji update, to znači da će i oni biti podržani u Project Treble?
To je onda odlična vest.
Tako je, čitaj neće biti podržani.Koliko sam ja razumeo svi telefoni koji izadju sa oreo podržavaće Treble, a oni koji dobiju update orea nije sigurno da li će ga podržavati.
Ne značiSad razmišljam, pošto će S7/edge dobiti isto oreo kao poslednji update, to znači da će i oni biti podržani u Project Treble?
[/B]Google Pixel
Google Pixel XL
Huawei Mate 9
Honor 8 Pro
Honor 9
Essential Phone
