kovacm
Pozdrav,
da li je neko zainteresovan za:
"It's a prototype of HID USB mouse adaptor to use with all ATARI and AMIGA computers. It emulates standard Atari mouse.
(Amiga mode wile be possible in near future - ovo vec funkcionise!)
It should work with almost ANY usb mouse. Has been tested with cheap OEM Acer optical mouse (wired), Logitech RX250 optical mouse (wired), Logitech Anywhere Mouse MX (wireless), Logitech VX Nano (wireless)."
dakle ovo nije kao dosadasnji stari PS2 adapteri sa fizickim USB prikljuckom vec adapter za sve nove HID miseve!
elem, kontaktirao sam willyvmm (autora ovog adaptera) i odgovorio mi je:
I just made 15pcs, and send them to tests (to this weekends small party in poland)
I found 2 small errors in layout, and I hope the Firmware is working well.
As soon as I get feedback from testers, I will start bigger batch.
If you want be a tester send me your adress, i can send one for you
The price for testers is only 10€, final price will be ca. 15-20€ (via
ebay). If you want i can send you 5 pcs (smallest batch is 5pcs
anyway), so you can distribute them to your friend and test
Joystick emulation is not implemented yet.
In meantime, You can check out the configuration .ini file. This speaks for itself:
kaze da ukoliko se odlucim za kupovinu, u utorak bi slao adaptere tako da bi mogli da stignu pre subote
da li ima zainteresovanih (10e. komad; ja bih sebi uzeo jedan, eventualno dva)?
;ini file example
;config version 1005
;included all available options.
;Config file located at X:\HID2ST\HID2ST.INI
;There is no support for long filenames !!!
[hid2st]
mode=0
; 0 - emulate atari mouse - default
; 1 - emulate amiga mouse
; 2 - emulate joystick in atari standard - could be autodetected.
txrate=2000
; transmit rate in pulses change/sec (STeps).
; default is 2000 STeps/sec.
; min 750, max 10000 (in theory 1000000)
microstep=1
;usefull with hires mouse. Indicates how many microsteps include one STep. Slows down the mouse.
;you can call it dpi divider if you wish
;min 1(max resolution), max 1000 (1000 micro steps, makes 1 STep)
dynamictx=1
;dynamic txrate
;speeds up the txrate when fast mouse moving detected.
:0 - disables the feature
dynamicth=16
;dynmictx threshold, threshold in STeps, when to speed up the mouse.
;warning: dynamicth*microstep < 0xffff , or expect unexpected.
turbotxr=4000
;turbo txrate, defines the txrate in STeps/sec when dynamictx enabled
; default is 4000 Steps/sec.
; min 750, max 10000, should be larger that txrat, but is not checked.
[hid2st]
mode=0
txrate=2000
microstep=1
dynamictx=1
;dynamic txrate
dynamicth=16
turbotxr=4000
