8k rezolucija nije problem...
DisplayPort 1.3 kabl moze samo da pusta 8k mislim da preko HDMI ne moze , ustvari moze ali do 30hz!
1.3
DisplayPort version 1.3 was approved on September 15, 2014.[18] This standard increases overall transmission bandwidth to 32.4 Gbit/s with the new HBR3 mode featuring 8.1 Gbit/s per lane (up from 5.4 Gbit/s with HBR2 in version 1.2), totalling 25.92 Gbit/s with overhead removed. This bandwidth allows for 5K displays (5120×2880 px) in RGB mode, and UHD 8K television displays at 7680×4320 (16:9, 33.18 megapixels) using 4:2:0 subsampling at 60 Hz. The bandwidth also allows for two UHD (3840×2160 px) computer monitors at 60 Hz in 24-bit RGB mode using Coordinated Video Timing, a 4K stereo 3D display, or a combination of 4K display and USB 3.0 as allowed by DockPort. The new standard features HDMI 2.0 compatibility mode with HDCP 2.2 content protection. It also supports VESA Display Stream Compression, which uses a visually lossless low-latency algorithm to increase resolutions and color depths and reduce power consumption.[19]
Trebao si da napises text da mislis na ovo:Capture.PNG
Preko HTML5 na Mozili Firefox 38.0.5 hoce da mi pusti ali koci kao lud procesor je preslab , za novinu 8k na youtube je najbolje imati 8k monitor/tv sa DisplayPort 1.3 kablom i grafickom koja ima podrsku za 8k kao i cekati Windows 10 final da izadje cujem da ce 8k da podrzi! Naravno i7 i 8GB rama su pozeljni!
Na Chrome-u 8k prilično secka (4790k/8gb RAM).
^...zbog nepostojece softverske optimizacije, a ne zbog nedostatka sirove snage trenutnog hardware-a. Cisto da ne bude zabune. :)
Moze da pusta i7 5960x i GTX Titan uz 16GB rama pretpostavljam :D
Monitori nam trebaju, oštrina će biti fenomenalna.
Oštrina će biti sjajna, samo što će morati da postoji neko ozbiljnije skaliranje širom celog UI, jer je na 7680×4320 sve toliko sitno da ne možeš kako treba da klikneš :)
