The design of the OnePlus 3 really is a level above that of the OnePlus 2. The move to an aluminum unibody combined with reduced thickness and mass makes the device feel of a might higher quality than the OnePlus 2, and it sits more comfortably in the hand. The entire design also feels much more thought out. When you look at the OnePlus 2 the little island with the camera, flash, and IR module looks like it was just slapped on without any thought, while on the OnePlus 3 the camera is met by the antenna bands and has the LED flash set right underneath it. There's just a greater cohesiveness to the entire device, and really my only complaint comes back to the slightly misaligned 3.5mm jack, but that's quite a nitpick.
One thing worth noting is that our set of apps wouldn't come close to utilizing the OnePlus 3's 6GB of RAM. Unfortunately, no matter how many apps we added, this would actually still be the case. The reason is that OnePlus has implemented very aggressive app eviction from memory, which means that your 6GB of RAM is really just sitting there using energy, and in general the utilization is pretty low. This may be a holdover from when the OnePlus 2 shipped in a 3GB configuration, but it's something OnePlus needs to address in a future OTA update. I'd imagine the Android enthusiast community is already at work on, or has already created custom kernels to alter this behavior as well. With 6GB of RAM you should be able to comfortably keep all of a user's frequently used apps resident in memory.
According to comments made by OnePlus, a 1080p display was chosen as it provides superior battery life, and because resolutions above 1080p are not useful outside of VR. I have to respectfully disagree with both points, especially because this is a PenTile AMOLED display. It has been well demonstrated that good battery life is achievable not just with 1440p AMOLED smartphones, but with 1440p LCD smartphones. While I do feel 1080p is a good resolution to choose for a 5.5" RGB LCD panel, it is simply not adequate for a PenTile AMOLED display.
When you consider the effective resolution of red and blue on the OnePlus 3, you're really dealing with a display that is roughly equivalent to the iPhone 6s in chroma resolution, except on a 5.5" display instead of a 4.7" one. The resolution for green is equivalent to a 1080p display, and subpixel rendering is what allows you to make the claim that it's still a 1080p display, but for everything except pure green your effective resolution is going to be lower. In addition to that, the uneven size and spacing of the subpixels, along with their diamond pattern, makes them less than optimal for rendering the latin alphabet which contains many vertical lines. This kind of screen door effect has long been noticed on PenTile displays, and for the most part the push for 1440p AMOLED panels has mitigated those complaints.
Right out of the gate things are not looking good for the OnePlus 3. Peak brightness only hits 413 nits, which is a huge regression from the OnePlus 2’s 554 nits. The impact that this has on outdoor usability is very significant, with the display being much harder to use in the sun than the OnePlus 2. To make matters worse, there’s no brightness boost mode that activates when you have the auto-brightness on. At this point I really don’t think it’s acceptable to ship a phone that can’t hit 500 nits when you’re in the sun, and Samsung is pushing 600 nits on their AMOLED displays when they boost brightness so OnePlus is well behind the competition.
While Dash Charge is interesting in how it charges quickly and actually does manage to keep the phone cool while doing so, I'm not really sure if it's worth the trade-offs. If you lose your OnePlus cable you have to buy a new one from OnePlus, and you can't quick charge with the large number of Qualcomm Quick Charge accessories available on the market.
http://www.anandtech.com/show/10411/the-oneplus-3-review/7
samo mu se displej ne sviđa
a meni je zanimljivo što su Ipak uspeli da izvuku 410nits dok svi ostali koji nisu Samsung imaju oko 350nits.
baterija po njima bolja nego na 6p.
Edit:
najbolje što su retardi izbacili ovaj review a još nema za s7 i htc10. koji ludaci
Sent from my Nexus 5 using Tapatalk
