DNA mistery solved
djuka007
Molim modove da ne menjaju sadrzaj texta, da ne bi izgubio smisao...
Poz
For many years molecular biologists have been mystified by the fact that
very little of an organism's DNA seems to serve any useful function.
I have solved the mystery.
The reason why only 30% of human DNA performs any useful function is that
the rest of it is comments.
Once we decode a typical human genome, we see that the contents begin as
follows:
_/* HUMAN_DNA.H
* Human Genome
* Version 2.1
* (C) God
_/* Revision history:
* 0000-00-01 00:00 1.0 Adam.
* 0000-00-02 10:00 1.1 Eve.
* 0000-00-03 02:11 1.2 Added penis code to male version. A bit messy --
* will require a rewrite later on to make it neater.
* 0017-03-12 03:14 1.3 Added extra sex drive to male.h; took code from
* elephant-dna.c
* 0145-10-03 16:33 1.4 Removed tail.
* 1115-00-31 17:20 1.5 Shortened forearms, expanded brain case.
* 2091-08-20 13:56 1.6 Opposable thumbs added to hand() routine.
* 2501-04-09 14:04 1.7 Minor cosmetic improvements -- skin colour made
* darker to match my own image.
* 2909-07-12 02:21 1.8 Dentition inadequate; added extra 'wisdom' teeth.
* Must remember to make mouth bigger to compensate.
* 4501-12-31 14:18 1.9 Increase average height.
* 5533-02-12 17:09 2.0 Added gay option, triggered by high population
* density, to try and slow the overpopulation problem
* 6004-11-04 16:11 2.1 Made forefinger narrower to fit hole in centre of
* CD.
_/* Standard definitions
#define SEX male
#define HEIGHT 1.84
#define MASS 68
_/* Include inherited traits from parent DNA files.
* Files must be pre-processed with MENDEL program to provide proper
* inheritance features.
#include "mother.h"
#include "father.h"
#infndef FATHER
#warn("Father unknown -- guessingn")
#include "bastard.h"
#endif
_/* Set up sex-specific functions and variables
#include <sex.h>
_/* Kludged code -- I'll re-design this lot and re-write it as a proper
* library sometime soon.
struct genitals
#ifdef MALE
Penis *jt;
#endif
_/* G_spot *g; Removed for debugging purposes */
#ifdef FEMALE
Vagina *p;
#endif
_/* Initialization bootstrap routine -- called before DNA duplication.
* Allocates buffers and sets up protein file pointers
DNA *zygote_initialize(Sperm *, Ovum *);
_/* MAIN INITIALIZATION CODE
* Returns structures containing pre-processed phenotypes for the organism
* to display at birth.
* Will be improved later to make output less ugly.
Characteristic *lookup_phenotype(Identifier *i);
...and so on.
[ Note that God uses three-space tabs ]
lol indeed :d :d
Au... ala se neko potrudio da ovo smisli...
Lmao :D
ql cod lol
Pobogu pa bog pravio svet u C++u :D
Btw mene bash zanima kako se "zapisuju" podaci u mozak. Kako npr. ja znam da se zovem kako se zovem i tako neke stvari... Mora nekako da se to "zapishe" u mozak, bash bih voleo da dozivim taj dan kada ce te stvari biti objasnjene :)
Ako bude, update-ovacu post :)
Poz
mislis ako izadje neka nova verzija :D lol
Nova verzija je vec tu :)
* 6006-05-01 12:45 2.2 Made thumbs more efficient for SMS typing
