The design is practically identical to the original MDR-3 from the 1980s. I do not have all the details yet, but supposedly the model will come with two sets of earpads, blue and orange, and might use USB-C rather than 3.5mm for the connection.
Price I was told is around 55-60€.
Samo što to nije krajnja cena vrv.Poklon. Slušalica jede živu decu. Uzdravlje ko naruči.
Ja imam originalne s početka osamdesetih, i ako je zvuk ovih novih isti ili sličan - bolje da se preskoče 🙂
Ili Fiio EH11 sada su dvadesetak evraIma Philips bluetooth slušalice sličnog dizajna za 30 evra.
Slusas ne da bi voleo, nego da bi cuo manu u mixu.critical listening, šta god to bilo
Ja sam ih imao nekoliko meseci i prodao. Preteske, a i ne volim zatvorene slusalice.Videh po forumu da je par ljudi koristilo ili koristi Audeze Maxwell. Vredi li to neki 250e, mogu sa ih uzmem polovne, manje vise kao nove su? Interesuje me latencija na 2.4ghz i generalno kvalitet zvuka (bass freak).. Pored njih imam Scullcandy Crushers ANC2, i lomim se da li da uzmem Audeze ili da sačekam kraj godine da mi ortak iz inostranstva donese X2HR. Malo vise vucem ka Audeze jer imaju wireless opciju. Imam DAC.
Kako si došao do ovih đokica koji štrče?
Takođe sam kreirao blagi V i strava zvuče. Ja ih od maja slušam na KA15 (u kome je i PEQ) i ne mogu da verujem šta ljudi prave za ove pare.
With a sensitivity of 114dB/V (efficiency = 100dB/mW) and low impedance (48 Ω measured) the DT900 Pro X can be used directly from a phone and reach high enough levels for listening at loud levels.
The power rating is unusually low for a PRO headphone. 30mW continuous and 100mW peak power is kind of asking for blown drivers. With normal home usage this isn’t an issue but in studios headphones can be lying on a desk and when the volume is turned up accidentally you might end up with blown drivers.
This headphone can be used in studios and will work great for monitoring and maybe even mixing.
One thing that one has to take in mind in a studio. The driver is easily blown up due to its low power rating. Accidentally increasing the volume while it is lying around can kill this headphone.
Koliko sam razumeo, bolji je obican koji nije R2R. Nesto su ga kilavo implementirali.Koliko bi FiiO K11 R2R bio dobar izbor i da li neka jeftinija dac/amp rešenja dolaze u obzir?
Gde ima da se nabavi? Korstio bih to direktno povezivanjem na desktop.Za te Beyer ne treba ti nista bolje od TRN Black Pearl. Ili, ako je izaslo nesto u medjuvremenu sto je ili bolje po istoj ceni ili isto, ali jeftinije.
