Xiaomi Redmi Note 17/17 Pro/17 Pro Max
Stock
Da, naslov je dobar - Redmi Note 17 Pro Max menja Redmi Note 15 Pro Plus - spontano i originalno 🙂
Redmi Note 17 Pro Max: New specs emerge for Xiaomi's next mid-range champion
Xiaomi Redmi Note 17 Pro Max is also expected to feature a 9,210 mAh battery globally and a 10,100 mAh equivalent in China
Redmi Note 17 Pro Max 16/512
    49.1 KB · Pregleda: 98
    79.6 KB · Pregleda: 94
Shit. Ako Redmi Note 17 Pro Max bude imao tu bateriju + identičan Titan durability kao 15-ica (dakle neuništivost otprilike), malo ću se iznervirati što uzeh Note 15 Pro+ (5G).
Mada s druge strane, kolika god je baterija, nekad mora da se puni. I kod ovog mi traje oko 2 dana moje upotrebe u proseku, ali 9k+ mAh bi bilo možda i 3-4 dana. 😳
Pazi stvarno, nisam se udubljivao u razliku u kapacitetu Kina vs Europe do sada, sad vidim da EU ima neku zastarelu regulativu. Bezveze baš.
    57.6 KB · Pregleda: 60
Još guraju ove 4G verzije. 🙂
Xiaomi Redmi Note 17 5G (6/256 GB): 400€
Xiaomi Redmi Note 17 Pro 5G (6/256 GB): 500€
Xiaomi Redmi Note 17 Pro Max 5G (8/256 GB): 600€
Redmi Note 4 koji je izašao 2016. godine je imao 4GB/64GB.
10 godina kasnije izbacuju i Redmi Note 17 4G koji ima 4 GB/128 GB
Dobrodošli u svet inflacije i nestašice.
Sutra stiže global verzija
A spominju i 27.8.
Ako ce biti i u ostalim zemljama ovo sto daju uz telefon, bice to solidna kupovina.
On the inside, each packs a 7,700mAh Silicon-carbon (Si-C) battery that supports 45W charging and 22.5W reverse wired charging.
Both phones are IP65-rated, and both run Xiaomi's HyperOS 3 with a promised 6 years of security support.
The Redmi Note 17 Pro has an 8,340mAh Silicon-Carbon battery. The increased capacity is paired with a faster 67W HyperCharge system
The Redmi Note 17 Pro Max is the same size as the Pro – the “Max” here refers to the larger 9,210mAh battery. Speaking of which, the Max has the same 100W HyperCharge.
Both phones launch with Xiaomi’s HyperOS 3 and will receive 6 years of security updates.
10000 mah powerbank telefoni 🙂
