molim pomoc oko kupovine integrisanog stereo pojacala...posedujem par zvucnika Jamo E770 150w komtinuirane snage, 220w peak, 6ohm, osetljivost 90db...osnovna dilema je snaga pojacala...povoljniji cenovni rang, ali i manja snaga su marantz pm6007, yamaha as301, arcam radia a5...svi otprilike 45/50w deklarisane snage...skuplje i snaznije varijante koje gledam su arcam radia a15, yamaha as501 ili as701, cambridge audio cxa81 mk2...to je neki izbor koji imam...pitanje je pre svega da li npr marantz koji mi je nekako prvi pik moze da pogura dobro te zvucnike pa onda i neke vama poznate prednosti i mane pojedinih navedenih modela...hvala unapred svima na diskusiji...
## Jamo E 770 Speakers with Marantz PM 6007 Amplifier
The combination of
Jamo E 770 speakers and the
Marantz PM 6007 amplifier is well-regarded in the audio community for delivering a high-quality sound experience. Let's explore the synergy between these components.
### Key Features of Each Component
| Feature | Jamo E 770 Speakers | Marantz PM 6007 Amplifier |
Type | Floor-standing | Integrated amplifier |
Power Handling | 100 W (140 W short-term) | 45 W per channel (8 Ohms) |
Impedance | 6 Ohm | Supports 4-8 Ohm speaker loads |
Frequency Response | 35 Hz - 20 kHz | N/A |
Total Harmonic Distortion (THD) | N/A | 0.02% at rated power |
Inputs | N/A | Multiple: RCA, Phono (MM), Aux |
Dimensions | 39.5 cm x 99.8 cm x 32 cm | 43.5 cm x 31.6 cm x 10.5 cm |
### Compatibility and Performance
#### Sound Quality
Cohesive Soundstage: Pairing the
Jamo E 770 speakers with the
Marantz PM 6007 amplifier provides a
cohesive and dynamic listening experience. The amplifier's power output complements the speakers' capabilities, allowing for deeper bass and clear highs without distortion.
Impedance Matching: The E 770 speakers are rated at
6 Ohms, which is within the
PM 6007’s operational range of
4-8 Ohms. This compatibility ensures optimal power transfer and sound performance.
#### Musical Versatility
Genre Adaptability: The amplifier's versatility and the speakers’ wide frequency response allow them to handle a variety of genres, whether you're listening to classical orchestras or modern rock.
Clear Dialogues: For home theater use, this combination excels at reproducing clear dialogues and sound effects, thanks to the E 770's impressive mid-bass and treble response.
### Aesthetic Harmony
Both the
Jamo E 770 and the
Marantz PM 6007 feature modern designs that can complement any contemporary living space. The brushed aluminum of the amplifier and the elegant wood finish of the speakers create a visually appealing setup.
### Conclusion
The
Jamo E 770 speakers paired with the
Marantz PM 6007 amplifier create a balanced, high-fidelity audio setup suitable for both music enthusiasts and home theater aficionados. This combination promises rich sound quality, robust performance, and aesthetic appeal, making it a strong option for anyone looking to enhance their listening experience.
For optimal setup, ensure proper speaker placement and consider cable quality to maximize potential.
Ja u poslednje vreme proveravam ovakva pitanja uz pomoc Ai, google ai npr.
Postavim pitanje npr ove tvoje zvucnike paired with pojacalom tim i tim...
Pa cak postavim i da mi uporedi npr moje pojacalo sa dva/tri para zvucnika. Pa onda kad sam odabrao zvucnike; onda sam sve to zadavo pitanja za koji vufer; i tako sam uz pomoc ai odabrao sistem
