Stock
Objašnjenje za v2 patch:
Dakle nova verzija Pixel IMS će biti isto sve, samo sa mogućnošću izbora i grafičkim interfejsom 🙂
In short, here's the complete v2 patch that implements my proposed bypass. It enables all features and is used in the same way as before. There's no UI implementation, so if there's any configuration I've missed, feel free to ask me to add it or modify the APK yourself.
For those of you who may be confused by these configurations, here's a complete explanation of what the v2.0 patch does:
Every time Shizuku service is activated, the patch applies the following configurations to each SIM card:
- Enable VoLTE, enable supplementary services, and enable video calling
- Enable backup calling
- Enable VoWiFi, enable VoWiFi roaming, enable VoWiFi Wi-Fi-only support, and display the VoWiFi icon
- Enable enhanced 4G (LTE+)
- Enable 5G (including NSA and SA), and enable Vo5G
Since Shizuku already supports automatic startup of the Shizuku service, this patch will work every time the phone is turned on. This is a set-and-forget, long-lasting patch.
If you prefer manual configuration and customization, please wait for the next Pixel IMS release, which will use the same method as this patch to bypass restrictions.
