macOS 16 (26) Tahoe
mare037
Monitor
Hisense 55U7QF
Ostale periferije
PS5 Slim Digital Edi
Tablet
iPad Pro 11 M2
Mobilni telefon
iPhone 16 Pro
Pametni uređaji
Galaxy Watch 5 44mm
Steam
PSN: mare037
Pristup internetu
  1. Kablovski internet
  2. Mobilni internet
GsX-9o6aEAA9xwO
Po svemu sudeći naredni macOS dolazi pod nazivom Tahoe i do sada sa najvećim redizajnom još od Big Sur-a.
Apple will announce macOS 26 in a few days, which is expected to focus on a major redesign instead of bolstering any front-facing additions. Apple typically selects a new name for macOS every year and this time around, we have heard little to no details on what the company will call its next big update. A new report has emerged, suggesting that macOS 26 will be called macOS Tahoe, named after Lake Tahoe in California.
Apple will release macOS 26 'Tahoe' in a few days, which will be the company's most significant redesign since 2020​
Mark Gurman writes in his latest Power On newsletter that the next iteration of macOS will be called 'macOS Tahoe', named after Lake Tahoe, which is situated between California and Nevada in the United States. The name will reflect the company's first major redesign of macOS since the release of Big Sur in 2020. Gurman states that macOS 26 will be the company's third major update since it started using California-based names and, since it will be a bigger update than originally expected, the company wanted to make it special.
It was recently uncovered that Apple will be using a new naming scheme for its forthcoming software updates. This means that iOS 19 will be called iOS 26, macOS 16 will be called macOS 26, and the same goes for the rest of the updates. The company is minimizing the confusion with the new naming scheme and opting for a year-based solution, which will end the confusion in the minds of the customers and developers.
The company is seemingly using the same approach as automakers with car models named for the following year. It could spark a debate among users and the community as a whole if the company used the current or the following year to name its software updates.
Other than this, macOS 26 Tahoe will focus on a big redesign, a shift from a feature-focusedupdate. However, this does not mean that the company will not release any new features, but it will surely not be the highlight of the update. Gurman also claims that the company is working on a new version of the Shortcuts app, which allows users to create actions with Apple's foundation models. However, there will be little to no updates for Apple Intelligence, according to the analyst.
Ujedno i poslednja verzija za Intel, Apple objavio zvanično.
Ja sam mislio da će da otkače Intel sa ovom verzijom macOS, pogotovo sad kad su prešli na novu klasifikaciju.
Kako god, mene boli uvo za šminku, bitno mi je da je to i dalje stabilan i funkcionalan OS…a kako će da se zove, da li će da ima ovakve ili onakve ikonice, nije mi važno. Na kraju, smatram da je OSX Snow Leopard jedna od najboljih iteracija do sada.
Meni se novi dizajn baš sviđa, buljim u postojeći dizajn 10ak godina i realno je krenuo da smara.
Jedva čekam da se poigram sa lokalnim LLMovima (neki od poznanika već iznose prve utiske sa Developer buildom i kažu da je potrošnja energije i do 20x manja nego kad se gađaju open source modeli kroz Ollama, kapiram da je Apple nariktao brdo MLX optimizacija koje tek treba da open sourcuje) i Containerization framework, koliko vidim moći će da se potera bilo koji OCI-compliant image što je fantastično u najavi.
Meni sa slika na internetu izgleda jako, jako slabo. Postoje delovi koji mi se sviđaju, ali vidi se da je na dosta mesta ovaj novi dizajn baš promašaj, pogotovo na Mac-u:
Pogledajte samo finder:
A sa druge strane novi context meni mi izgleda odlično:
Šta ćeš, tako smo pričali i za prošli redizajn kad su stizali prvi Apple Silicon čipovi pa smo se navikli, tako ćemo i sada
Redizajn je prakticno beznacajan u odnosu na svojevremeno OS X El Capitan / iOS 7 redizajn kako se piskaralo po internetu za Tahoe da ce da bude.
Koristim public betu neko vreme, samo jedna promena mi ide na živce - tabovi u Safariju. Više nisu gore kod address bar-a, već se pojavljuju ispod address bar-a i bookmarks, i kada imaš više od jednog taba otvoreno, smanjuje se browsing prostor za tu jednu liniju. Apsolutna glupost, submitovao sam im feedback i nadam se da će barem dati opciju da bude kao pre. I da, nema više compact tabova, mada to nisam ni koristio.
Ta promena na Mac platformi se desila sa OS X Yosemite. A što se iOS-a tiče, meni je sve pre iOS-a 7 bilo lešpe, imao je neki svoj šarm.
Bilo bi najbolje kad bi šmekerski napravili u nekoj od sledećih verzija iOS-a da u Settings-u ima opcija da se sve ikonice i dizajn prebaci u retro stil, tačnije pre iOS 7 stil, skeuomorphic dizajn 😃 Izvinjavam se za off topic za temu 😃
Bilo bi al nema šanse, to kao kad bi dozvolili da na MacBooku umeste svetleće jabuke staviš pulsirajuću bananu.
Sve novine
