The Expanse: Osiris Reborn
  • Začetnik teme Začetnik teme Alex
Alex
CPU & Cooler
AMD Ryzen 7 9800X3D | Silent Loop 3 360
Matična ploča
B850M AORUS ELITE WIFI6E ICE
RAM
Fury Beast 2x16GB DDR5 6000MHz CL30
GPU
GeForce RTX 5080 WINDFORCE OC SFF 16G
Storage
2x KINGSTON 1TB KC3000 SKC3000S/1024G
Zvuk
HyperX Cloud 2 | AltecLansing 2.0 Curved
PSU
Corsair SF1000 ATX 3.1
Kućište
Lian Li DAN A3
Monitor
Gigabyte FO27Q2 | Dell S2721DGFA
Miš & tastatura
G502 X Lightspeed | Keychron K8 Pro
Ostale periferije
LG 65G3, Q990C, PS5
Mobilni telefon
Galaxy S23+
Pristup internetu
  1. Optički internet
The Expanse: Osiris Reborn is a story-driven sci-fi Action RPG. You play as a Pinkwater Security mercenary whose brief shore leave on the asteroid Eros spirals out of control. Trapped in a deadly lockdown and drawn into a solar system-wide conspiracy far beyond your control, you’ll have to adapt, survive, taking command of the most advanced ship in the whole of the solar system. Gather a crew and find your own path through the web of lies to leave your mark on the solar system.
Ova vest me je baš obradovala. U ozbiljnom sam iskušenju da odradim preorder. 😄 Na osnovu onoga što zasada može da se pročita, izgleda obećavajuće.
Your merc, or the Captain, has three backgrounds to choose from (Earther, Martian, or Belter), different abilities depending on their class, and is playable in a third-person perspective while issuing squad commands to two teammates in combat.
Izvor: Gizmodo
Evo i jedan zanimljiv intervju:
Treba se malo strepeti. Ni jedna Owlcat igra nije izašla bez gomile bugova. Sva sreća sve oni to pokrpe ali posle nekog vremena.
Na sve to ovo je nov žanr za njih. Nadam se da će ga savladati kako dolikuje.
Jedino ne znam ovo oko vremena dešavanja igre, parelelno je sa stvarima iz knjiga/serije.
Da, prati dešavanja prve dve knjige. Inače, The Expanse je u početku trebalo da bude igra, MMO, ali je to na kraju otkazano, pa su autori napisali knjige.
Osiris Reborn takes place amidst the first two books in The Expanse series or the first two and a half seasons of the excellent Syfy/Prime Video TV series.
Pa to, nisam baš siguran koliko je to dobro. Da mnogo ne ograniči igru, ili opet, da ne ode u nekom suprotnom pravcu, pa umanji ono što se dešavalo u knjizi, tipa sve to bude zbog stvari koje je igrač uradio.
Ne verujem da će događaji u knjizi biti posledica odluka u igri, to baš ne bi imalo smisla. Već su rekli da će ovo biti zasebna priča koja se odvija uporedo sa Holdenovom. Logičnije mi je da događaji u knjizi/seriji utiču na igru, na primer kad daju brod Mesečar pinkvoterovcima na Ganimedu. Ima tu postora dosta za nove priče koje ne utiču na glavnu.
"You will be seeing with your own eyes the repercussions of Holden's actions, all the situations like The Canterbury, and how it affects people in the belt, people in the inner planets," Mishulin said. "You will be having your own adventure with your own goals, choices, consequences in the same universe [with] all the major events unfolding in this universe alongside your story."
Izvor: https://www.cnet.com/tech/gaming/th...ke-cues-from-mass-effect-souls-games-and-more
Ne znam, i dalje sam skeptičan kako će sve to da uglave.
Pogotovu kada se pominje i ovaj deo "taking command of the most advanced ship in the whole of the solar system." to mu dodje jedan od onih stelt brodova? Nisam siguran da je je ijedan preživao. I gde su dokovali za gorivo, municiju, popravke...
Ali ajde, nadam se najboljem 🙂
Neki od glumaca iz serije će davati glasove svojim likovima u igri.
Ako budu recimo Mao ili Dresden, eventualno neko iz OPA, to bi mi bilo OK, ali ako tipa budu Holden ili Avasarala, nisam baš siguran.
I dalje nisam baš načisto sa tim što će biti paralelno sa knjigama/serijom. Ali OK, možda grešim, nadam se da grešim 🙂
I ajde bre Džefe Bezose uradi i ostale knjige, hoćemo još sezona serije 🙂
Eh, a ja bih baš volela da se pojavi Rosi ekipa i Avasarala koja je apsolutna legenda. 😄 Videh da je Ves (Ejmos) okačio sliku sa Bobi, Naomi i Holdenom i napisao nešto kao ponovo na okupu, iza kulisa. Možda rade na igri, ne znam, nagađam. Ne verujem da smo te sreće da dobijemo 7. sezonu. Moguće je da budu i Mao i Dresden, i OPA, ipak igraju veliku ulogu.
Da, stelt brodovi. Koliko se sećam, trebalo bi da su svi uništeni. Objavili su već kako izgleda brod:
Iskreno, sto se mene tice, ispricali su svoju pricu, neka ostane na tome.
Ono sto mozemo da budemo sigurni je da sigurno nece angazovati istog glumca za ulogu Alexa. Iskreno, taj "preokret" u seriji mi je bas nekako lose legao.
Pa zato što je debilna priča iza toga, classic cancel culture na delu.
Otpustili su ga zbog raznoraznih optužbi. Pitanje šta je istina, šta nije, ali bolje da su ga zamenili kad su već odlučili da ga otpuste.
Nisam ispratio sta se posle sve desavalo, ali koliko se secam bila je neka ozbiljnija optuznica, u smislu brdo zena ga prijavilo za "seksualno uznemiravanje" ili sta vec.
Problem je sto je danas (tj u poslednjih 5+ godina, mozda i 10+) dovoljno da te jedna osoba optuzi za nesto i odma svi dizu ruke od tebe bez provere cinjenica.
Vidim da lik posle toga skoro nista nije snimao. Da li je kriv, nije kriv, pojma nemam, ali je bezveze sve ispalo.
Da, mnogo njih ga je optužilo sa navodnim dokazima poruka koje im je slao i slično. Opet, mi ne možemo znati šta je istina, ali baš mi je bilo žao kad su ga izbacili, Aleks mi je bio jedan od omiljenih likova. Možda ne bi bilo loše da su ga jednostavno zamenili, ali gotovo je sad...
Kontam ja što nisu, ubacili su tu scenu pošto je cela 5. sezona snimljena, a u planu je bilo i samo 6 epizoda u poslednjoj, šestoj sezoni - nije bilo računice da se zameni lik tek tako.
Autori su već izjavili da oni ovo vide kao pauzu i da postoji mogućnost da se nastavi u budućnosti, tako da su i mogli da ga zamene ili da izmisle neki razlog zašto se ne pojavljuje u 6. sezoni. Realno su mogli i celu postavu da zamene u 7. sezoni pošto je skok 30 godina, sasvim je lepo to funkcionisalo u Kruni, ali verovatno čekaju da ovi dovoljno omatore.
Ček, nisam ispretio - biće nastavak? Ja sam razumeo da je serija gotova kao takva, a i knjige.
Knjige su gotove, serija nije jer nisu završili priču sa protomolekulom. Možda bude nastavak jednog dana, barem su tako autori knjiga nagovestili.
Isto sam to pomislio, nego zaboravio da iskomentarisem.
Sto se nastavka tice, ne znam zasto bi cekali da ostare glumci kad im i 10 godina cekanja nece mnogo znaciti ako je 30 godina razlika koju treba da predstave. Svakako bi morali da ih "vestacki" ostare u slucaju da su isti glumci u pitanju. Inace, nisam ni ja znao da ima price o nastavku, ali videcemo svakako sta ce biti od toga.
Za sada, eto imamo ovu igru, a kad smo kod nje, trebalo bi da odigram Telltale verziju.
EDIT: doduse, sad vidim da je medju losije ocenjenim Telltale igrama.
Baš tako, svakako će morati ili da ih veštački ostare ili da ih zamene. Možda im je bilo i previše skupo da sad ekranizuju poslednje tri knjige, ko će znati.
Tačno, nisam ni ja još Telltale odigrala, nikako da dođe na red. I još malo da skrenem sa teme, na čekanju su mi i stripovi, a u septembru bi trebalo da izađe novi strip A Little Death čija se radnja odvija između 6. i 7. knjige, a jedan od koautora je Ves iliti Ejmos.
Ovaj podatak nisam znao. The Expanse serijal zaista ima potencijal za kreiranje dobre i atmosferične video igre, a kao veliki fan serije zaista se nadam da će priča i gejmplej biti napravljeni korektno.
Level art je ovde vrhunski odrađen koliko vidim. Svaka čast za osvetljenje i 3D elemente. Nažalost bloom efekat je previše nakokan za moj ukus usled čega scene dobijaju tzv. razliveni izgled, što je nešto što se naročito primećuje u ovim mračnijim deonicama. Pitam se čemu to kad imaš ovako divno zaokružene 3D elemente koji će u ovoj postavci čini mi se samo izgubiti na izgledu. Bilo bi lepo kada bi nam to ostavili da sami podesimo... Osim ovoga, animacije NPC-ova deluju mi malo jeftino.
Novi info o posadi.
Sutra će biti još novosti na Xbox prezentaciji.
During Xbox Partner Preview, you’ll get an in-depth look at Ryu Ga Gotoku’s new project, Stranger Than Heaven, an update on S.T.A.L.K.E.R. 2: Heart of Chornobyl, plus new looks at The Expanse: Osiris Reborn.
Uvek se obradujem kad pročitam da neka igra izlazi za GoG 👌
Nema degradacije performansi kao sa Denuvom
Meni ovo dobro izgleda, definitivno uzimam kad krene pretprodaja na Steam-u. Još i Exodus izlazi u otprilike isto vreme, ali će se prvo ovo igrati.
