Chrome prestao da radi...
savior
Cenjen
Juce mi je google chrome radio sasvim normalno,klasicno sam ugasio racunar,i sada vise nece da se upali,odnosno javlja google chrome has stopped working svaki put kada pokusam da ga pokrenem.Ni ne udje u aplikaciju,vec se odmah desi ovo.
Rec je win 7,najnoviji chrome,pa ako neko ima predloge.. poludeo sam od googlanja,verovatno cu uzeti lepo reinstalirati windows i zavrsiti :)
Zasto bi reinstalirao Windows? Reinstaliraj Chrome.
Resetuj profil za Chrome i verovatno će sve proraditi.
Exit Google Chrome completely.
Enter the keyboard shortcut Windows key +E to open Windows Explorer.
In the Windows Explorer window that appears enter the following in the address bar.
Windows XP: %USERPROFILE%\Local Settings\Application Data\Google\Chrome\User Data\
Windows Vista/ Windows 7/ Windows 8: %LOCALAPPDATA%\Google\Chrome\User Data\
Locate the folder called "Default" in the directory window that opens and rename it as "Backup default."
Try opening Google Chrome again. A new "Default" folder is automatically created as you start using the browser.
If you wish, you can transfer information from your old user profile to your new one. However, this action is not recommended, since a part of your old profile may be corrupt. With that in mind, to transfer your old bookmarks, copy the "Bookmarks.bak" file from the "Backup default" folder to your new "Default" folder. Once moved, rename the file from "Bookmarks.bak" to "Bookmarks" to complete the migration. All other browser data will remain in the "Backup default" folder, but you won't be able to transfer it to your new profile.
probao sam sve zivo pa i gore navedeni predlog,nije pomoglo... sta god uradio nema nikakve promene,uvek ista greska...
Tema je stara a moj komp još stariji 😁. Prestao je da radi prezraživač goglechrom, kada hoću da ga pokrenem zaglupi se ceo komp, isto neće ni opera. Samo ie otvara ali on je beskoristan.
Komp je baš star, ram je 2 gb. U njemu je win 7.
Izgleda da je odradio svoje ili ima leka.
Instaliraj mozilu firefox, win 7 nema odavno podrsku za chrome
Šta kaže pretraživač kada otvoriš YouTube?
Na firefoxu radi normalno. A posebna YouTube app koja ide preko chroma nije htela ni ona da radi.
