Magic6 Series 1.29GB update for CN Version (8.0.0.130), in Global we are on 8.0.0.127
Update log:
Dear users, this update adds custom wake words, one-step gesture split screen, and a front-facing beauty function. It improves the camera, wallpaper, trust ring, suspension window, and call function experience. It also repairs performance and power consumption problems in some scenarios, improves system stability, and integrates security patches. We recommend you update to this version.
\[YOYO Assistant\]
* Added a new custom wake word function for voice wake-up to meet your diverse needs. Experience it by going to: Settings -> Smart Assistant -> YOYO Assistant -> Voice wake-up -> Wake-up word -> Custom wake-up word.
\[Lock screen wallpaper\]
- Added "Double Fantasy" template to play personalized custom lock screens. Experience it by going to: Lock screen interface, two-finger pinch -> Lock screen style -> Magic lock screen -> Double Fantasy.
- Added support for searching and switching historical lock screen styles. Experience it by going to: Lock screen interface, two-finger pinch -> Lock screen style -> My lock screen.
\[Split Screen\]
* Added a one-step gesture split screen function. Swipe from the bottom to the top left corner on a full-screen application, then click on another split screen supported application to enable split screen mode.
\[Suspension Window\]
* Mini window now supports moving and hovering anywhere on the phone's desktop.
\[Camera\]
- Portrait mode now has a front-facing "beauty" function, supporting "daily," "workplace," "Chinese," and other beauty styles. It also allows you to customize the style.
- Optimized the HDR imaging effect in some scenarios.
- Improved photo and video experience in certain scenes.
- Enhanced capture accuracy in some moving scenes.
\[Smart Capsule\]
* Some system services now support capsule switches to meet users' independent settings needs. Experience it by going to: Settings -> Notification and Status Bar -> Smart Capsule.
\[Performance\]
- Optimized an issue causing lag with the lock screen dynamic effect.
- Improved performance and fluency in some scenarios.
\[Power Consumption\]
* Fixed abnormal power consumption in certain scenarios.
\[Ring of Trust\]
* Optimized unstable connection issues in some device coordination scenarios for a smoother trust ring experience.
\[Communication\]
* Improved the call experience in some scenarios.
\[System\]
- Enhanced system stability for your phone to run more reliably.
- Integrated the latest security patches.
