Kućna multimedija Koje slušalice od ovih??
Koji TV, projektor, zvučnike, soundbar i ostale multimedijalne komponente kupiti?
vylota
CPU & Cooler
RYZEN 5 5600X, WRAITH
Matična ploča
GA B450 DS3H
RAM
2X8 GB DDR4 3200
GPU
ASUS GTX 1660
Storage
M2 SAMSUNG 980 EVO PRO 512, WD GREEN SATA II 1TB
Zvuk
INTEGRISAN
PSU
LC POWER 600W 2.31
Kućište
COOLER MASTER
Monitor
SAMSUNG TV/MONITOR T27D390EW
Dvoumim se između sledećih slušalica , ako imate neki predlog da vidimo ;), uhnapred hvala!
AKG K702
Sennheiser HD 599
Hifiman HE 400se
cene su slične, od 120 - 140e
To su verovatno cene na KP.
Hifiman se nije proslavio sa kontrolom kvaliteta ni u klasi flagship slušalica, pa ne znam koliko je pametno kupovati njihov početni model na KP. Inače su dosta dobre za te pare.
https://diyaudioheaven.wordpress.com/headphones/measurements/hifiman/he400se/
HD 599 su klasične Sennheiser (udobne, i sa toplim zvukom), ali zvučno nisu baš u rangu odličnih HD 58X, HD 6XX. Ali su i dalje dobar izbor po toj ceni.
https://diyaudioheaven.wordpress.com/headphones/measurements/brands-s-se/hd599/
AKG K702 su dobre (bright/neutral, zahtevaju EQ), ali mogu da budu veoma neudobne (ako je u pitanju verzija sa starim headband-om, koji je mnogima smetao):
https://diyaudioheaven.wordpress.com/headphones/measurements/akg/k702/
AKG K612 Pro su malo bolje od K702, bilo ih je za 16500 din. u jednoj domaćoj prodavnici, ali je pitanje da li ih još imaju na stanju.
https://diyaudioheaven.wordpress.com/headphones/measurements/akg/akg-k612/
The K612 is probably one of the underexposed headphones in the AKG line. The K612 is a good sounding headphone that may well best the K7** series. Comfort is quite good.
It isn’t a very sensitive headphone so needs a decent amp. Together with some EQ in the lows and an amplifier that can supply enough voltage (it doesn’t require a lot of power) the K612 sounds impressive.
One can expect the elastic bands for regulating the headband height to loose it’s tension after a few years.
Not easy, but possible, to replace.
Ali i one su neutralnog zvuka, pa je pitanje da li će ti se to svideti. Ali fabrički bolje zvuče od K702 i HD 599, uz EQ bi verovatno mogle da prođu i kod onih koji vole malo topliji zvuk.
Na KP je bilo i Beyerdynamic DT 880 Edition za 160€, sada su verovatno i one poskupele.
https://diyaudioheaven.wordpress.com/headphones/measurements/brands-a-i/dt880-250ω/
AKG K702
Sennheiser HD 599
Hifiman HE 400se
Video sam u drugoj temi da bi koristio te slusalice sa Fiio X3 dap-om.
Isto sam video da si pisao da ti grado srh60/80 zvuce super i da ti je jedina zamerka bila kvalitet izrade.
Iz toga zakljucujem da ti super zvuce otvorene slusalice koje su anemicne sa basom, za vecinu usiju ispod 60 godina reprodukuju "vrishtave" vokale i imaju dobar stejdz.
HD599 nije ta prica. Ima nepostojeci sub bas, nekarakteristicno za otvorene slusalice Sennheiser-a poprilicno podebljan mid bas i najnize srednje tonove. Stejdz je ok. Moze da ih gura X3 bez problema, cak i sa ozbiljnijim EQ-om.
Akg su za to sto si rekao da ti se dopada zvucno u tvom fazonu, mada kako god da zvuce postane nebitno zbog tvrdog (neelasticnog) rajfa koji pritiska lobanju i postanu neudobne za nosenje na vecini glava posle npr. pola sata-sat. Isto moze da ih gura X3.
HE400Se su kao superiornija varijanta Grado-a, aka. anemican bas, piskave odredjene frekvencije i neudobne na dobrom procentu glava (jer su dosta teze od slusalica sa dinamickim drajverom, gde glavni oslonac bude na rajfu, a ne ravnomerno rasporedjen izmedju jastucica i rajfa), ali je sve kvalitetnije, bolje, brze jer je planar magnetic drajver. Jedina losija stvar u odnosu na Grado koje si probao je stejdz na HE400SE. Sa fabrickim jastucicima i fabrickim resetkama je klaustrofobcan. Mozda cak i gori nego na HD6**.
Drugi problem je sto X3 ce ih gurati da zvuce dovoljno glasno u svim frekvencijama, osim basa. Za bas je potrebna snaga, tj pojacalo koje trpi vece oscilacije u voltazi. Sto znaci na tom dap-u ce biti jos anemicnije nego sto vec jesu kada bi se slusale na nekom pristojnom pojacalu.
Sto se tice kupovine HE400SE i tu postoji polu-nauka.
Prvo su izasle u Kini i samo tamo bile dostupne npr. godinu dana pre nego bilo gde drugde u svetu. Ta verzija koristi regularne (staromodne) magnete na drajverima isto kao i obicne HE400 i 400i i 4xx itd itd itd.
Druga verzija koja je izasla koja se prodavala po celom svetu je sa "Stealth" magnetima. Ta sa stealth magnetima je ona koju americki tjuberi hvale i one su zahtevnije sto se tice snage pojacala.
Obe i dalje postoje, obe se i dalje proizvode i uporedo prodaju.
Koju od njih prodaju na KP, ne znam.
Ako se odlucis za njih, gledaj da je prodavac iz tvog mesta/grada, posto QC/QA kontrola na Hifimanu kao sto ti je kolega @hsv.stoned rekao je, da budemo politicki korektni "diskutabilna".
U slucaju lose funkcionalnosti dobro bi bilo da mozes da vidis zenicu prodavca.
Hvala na iscrpnom odgovoru. Mada mi tek sada nije jasno šta činiti. Možda da izbegnem Hifiman jer nije sigurna kupovina.
Koliko sam razumeo 599 treba zaobići. A AKG ima problem sa rajfom ali je zvuk ok?
Kakva je situacija sa HD560s? Malo su skuplje (30e) od 599.
Jel imate neki drugi predlog? Npr dosta hvale zatvorene AKG 612 pro?
Ako su ti se dopale Grado SR60/80, verujem da ce ti 560s biti super.
Meni nisu legle, jer sam svilen. Imaju par nekih vrhova u visim frekvencijama koje su mi smetale.
Ali bez problema mogu da kazem iako su meni bile naporne, zvuce prirodno i imaju lep stejdz.
Zvucno im je mana nedostatak sub basa (kao i na vecini otvorenih slusalica) i par tih vrhova u visim frekvencijama.
Druge mane su sto dok se ne razglave stezu malo jace lobanju i sto su im jastucici potrosniji materijal nego kod drugih marki.
Dobre su za narucivanje posto sennheiser je savladao copy/paste.
Jako su retke devijacije od jedinice do jedinice.
@Bocko Bockovic
Odlični postovi.
E sad, čini mi se da je vylota imao i NAD VISO HP50, SL HD681 Evo, Pioneer A1000, sad čitam da mu je i Grado zvuk bio ok, tako da bih rekao da mu ne odgovara samo jedna signatura.
@vylota
K612 Pro su potpuno otvorenog dizajna, neutralnog su zvuka i zahtevaju dobro pojačalo. Zvučno su malo bolje i udobnije od K702. Mana je što sve pomenute AKG imaju fiksni kabl.
Stare verzije AKG K702 imaju ''nazubljen'' headband, koji praktično svima smeta, samo zbog toga nisu udobne. Novije serije mislim da imaju ravan headband, kao i K612 Pro, ali ipak treba ovo naglasiti jer je moguće da neka domaća prodavnica (ili KP preprodavac) ima na stanju verziju sa starim headbandom.
K702 imaju malo naporniji i obojeniji zvuk od K612 Pro, koje su neutralnije i manje naporne za slušanje, zahtevaju i manje korekcija preko EQ.
Slično važi i za DT 880 Edition, takođe imaju fiksni kabl i zvuk koji je dobar ali ipak mora malo da se koriguje putem EQ. Beyerdynamic imaju najbolji kvalitet materijala i izrade od svih pomenutih slušalica.
Odgledaj/preslušaj oba poređenja.
Sličan tjuning zvuka (kao 612 Pro) imaju i HD 560S, odlične slušalice u toj klasi, a prednost u odnosu na AKG je mogućnost lake zamene kablova. Oba modela mogu fino da se srede preko EQ (posebno HD 560s), odnosno da im se malo ''utopli'' zvuk.
https://diyaudioheaven.wordpress.com/headphones/measurements/brands-s-se/hd-560s/
Na DIYAH sajtu imaš testove i grafike za sve navedene slušalice, čak i za NAD koje si koristio, pa to može da ti bude referenca.
a Philips Fidelio Slušalice X2HR ?
Dobre, ali treba obratiti pažnju na ovo: https://diyaudioheaven.wordpress.com/headphones/measurements/brands-philips/fidelio-x2hr/
The difference between L and R driver driver matching is an issue and shows Philips does not perform any post production measurements or quality control. Most likely they just mount some drivers coming from an assembly line without taking an effort to match drivers. So whether you have a good or lesser one may be a lottery ticket. In one case the L-R differences were audible.
Kupio sam na kraju Sennheiser HD 560S, na akciji (mislim da još traje u 4A i G). Koristio sam ih na tri načina, pa evo mojih utisaka...
Probao sam ih na telefonu OnePlus Nord2, sa usbc-3.5mm dongle-om, eto tek da čujem kako i da li rade. Bez problema, spotify,
zvuk na oko 70-80%, plus EQ app zbog basova. Sve ok, ali ih naravno neću koristiti na telefonu :).
Fiio X3 je bio sledeći, uhlavnom FLAC fajlovi, odličan zvuk, malo sam pojačao basove jer mora. Mislim, basovi su tu, ali volim kad su malkice "vidljivijii" od normalnog.
Jačina oko 90 od 120 max. Neke pesme sam slušao glasnije, neke ispod 90, zavisi od žanra.
A iznenađenje je bila kombinacija sa Fiio E7 pojačalom, na koje sam iskreno zaboravio da imam :). E7 sam kupio polovnog pre X3, a povezan mi je na PC i koristim ga kao eksternu zvučnu karticu. Zakačen obostranom čičak trakom za fioku od tastature. Na E7 nema nekih podešavanja, zvuk se pojačava od 0-60, koristio sam jačinu od oko 35-40, a ima još jedno podešavanje samo za bas, 0-4. Tu sam stavio na 1. Pustio spotify na kompu, i tad je bio definitivno najlepši zvuk.
Stvarno prelep zvuk, i visoki i srednji i niski tonovi, kristalno čisti, prelepi vokali, gitara Mark Knopflera fantastična, vatrene kočije - vangelis, itd... uživancija...
Tako da je krajni utisak, lično moj (jer nemamo svi iste uši i iste preference), 560S su sjajne slušalice, jako sam zadovoljan.
Kvalitet izrade je dobar, nisam očekivao ko zna šta, udobne su, posle oko 3 sata me nije ništa bolelo.
:) Juče sam došao sa posla, ručao pa otišao da pustim malo muzike, mrzelo me da dohvatim 560s pa sam uzeo Q30 iz fioke... ajd da baš ne preteram, ali, nebo i zamlja... kao igraćku da sam uzeo. Zvuk je odličan i na Q30, ali...
E7 je jedan od prvih FiiO uređaja, poznat po toplom i nenapornom zvuku (Wolfson DAC, ako se dobro sećam), zato je dobra sinergija sa HD 560s slušalicama. Da si ih upario npr. sa nekim sterilnim i hladnim Toppingom, zvuk bi bio otvoreniji ali dosadniji i naporniji za slušanje.
HD 560s mogu još bolje da zvuče, ako se upare sa nekim DAC/AMP koji takođe zvuči toplo, ali uz bolju separaciju, otvoreniji zvuk i veći stejdž (npr. iFi Zen DAC V2 ili FiiO K5 Pro AKM, FiiO K7).
Sve je na strani HD 560s, posebno out of the box tjuning zvuka, ipak su to ozbiljne studijske sluške.
A Q30 zahtevaju korišćenje EQ profila, otprilike kako je Oluv to prikazao, inače ne zvuče ništa posebno dobro.
