Ja koristim ovaj sajt i app: https://www.heavens-above.com/Jel moze neka aplikacija ili web stranica za praćenje?
Imao sam nesto, mislim da je bila neka web stranica, ali se sad ne secam sta je bilo u pitanju.
...India’s Moon Lander Misses Wake-Up Call After Successful Mission
The Chandrayaan-3 mission did what it set out to do, but its lander and rover could not be roused after entering the cold lunar darkness two weeks ago.
Izvor: https://www.nytimes.com/2023/09/22/science/india-moon-landing-chandrayaan-3.htmlThe hope was that when sunlight again warmed the solar panels, the spacecraft would recharge and revive. But that was wishful thinking. Neither Vikram nor Pragyan were designed to survive a long, frigid lunar night when temperatures plunge to more than a hundred degrees below zero, far colder than the electronic components were designed for. The spacecraft designers could have added heaters or used more resilient components, but that would have added cost, weight and complexity.
Imas aplikaciju find starlinkJel moze neka aplikacija ili web stranica za praćenje?
'Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.'Objavljen je najdetaljniji snimak naše galaksije Mlečni put (10TB) koji sadrži impresivnih 3,32 milijarde nebeskih objekata.
Snimak je napravljen pomoću kamere za tamnu energiju na Čileanskoj opservatoriji Cerro Tololo kao deo programa NOIRLab.
Pogledajte prilog 409915
Ovo je samo mali isečak:
Pogledajte prilog 409914
Vastness of space je neverovatan, mislim brate pogledaj ovo.. Nema šanse da smo sami bukvalno.
Ja sam ubeđen da nismo sami, ali smo toliko mladi kao civilizacija da nismo ostavili nikakvog traga kako bi nas druge starije civilizacije primetile.'Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.'
Vastness = prostranstvoA zašto misliš da ovo parčence space-a gde se mi nalazimo nije wasted, a neki drugi delovi gde nema nas i nama sličnih jesu protraćeni prostor?
Da, baš tako. Uprkos nadama futurologa i SF entuzijasta, mož' biti da je brzina svetlosti zaista nepremostiva, da je utkana "u sistem" i da se ni sa kakvim napretkom civilizacije zapravo ne može nadmudriti. Samim tim, više civilizacija razbacanih po svemiru (ali previše udaljenih), čine to da je to što postoji više njih zapravo potpuno irelevantno, ako kontakt ili bar detekcija nisu mogući.Pitanje je koje su uopšte mogućnosti za savladavanje velikih razdaljina. Naša fizika koju poznajemo ograničava nas u istražvanju svemira jer brzina svetlosti nije dovoljna za putovanja u svemirskim razmerama. Možda drugi postoje milijardu godina ali ako nisu rešili problem putovanja kao npr warp drive zakucani su za svoje dvorište.
Na celom snimku se vidi samo 3.3 milijardi zvezda, a procenjuje se da ih ima 100-400 milijardi ukupno u našoj galaksiji.Vastness of space je neverovatan, mislim brate pogledaj ovo.. Nema šanse da smo sami bukvalno.
Zato sam okacio Weinsteinov video gde je lepo objasnio sta kako i zasto se ne gura to polje vec decenijama.Pitanje je koje su uopšte mogućnosti za savladavanje velikih razdaljina. Naša fizika koju poznajemo ograničava nas u istražvanju svemira jer brzina svetlosti nije dovoljna za putovanja u svemirskim razmerama.
To bi bio najtuži scenario, još kad uzmemo u obzir da se svemir širi i galaksije udaljavaju jedna od druge...Da, baš tako. Uprkos nadama futurologa i SF entuzijasta, mož' biti da je brzina svetlosti zaista nepremostiva, da je utkana "u sistem" i da se ni sa kakvim napretkom civilizacije zapravo ne može nadmudriti. Samim tim, više civilizacija razbacanih po svemiru (ali previše udaljenih), čine to da je to što postoji više njih zapravo potpuno irelevantno, ako kontakt ili bar detekcija nisu mogući.
Zbog tog širenja mnoge galaksije koje sada vidimo su već predaleko odmakle da bi ih ikada sustigli jureći ih čak i brzinom svetlosti jer se udaljavaju brže.
Tesko da se udaljavaju brze od svetlosti.Zbog tog širenja mnoge galaksije koje sada vidimo su već predaleko odmakle da bi ih ikada sustigli jureći ih čak i brzinom svetlosti jer se udaljavaju brže.
Tesko da se udaljavaju brze od svetlosti.![]()
akademik lepo objasnio...Tesko da se udaljavaju brze od svetlosti.![]()
Bob Lazar has spoken!Element 115 ce biti, drugo do sada, najznacajnije otkrice u istoriji civilizacije.
