- AMD Ryzen 5 5600 & AG400
- Gigabyte B550 Aorus Elite V2
- Kingston Fury 32GB Renegade DDR4 3600MHz
- Asus Dual 4070
- Kingston SKC3000S1024G
- SEASONIC Focus GX 650W
- Thermaltake S300
- Monitor
- Dell U2414H
- Miš & tastatura
- MX Vertical & K350
- Ostale periferije
- Epson EH-TW6700
- Mobilni telefon
- Xiaomi Mi8 9.6.27
- Kablovski internet
Moglo bi da bude, info sa jednog trackera(možda ima još neku grešku):Nisam ulazio u problematiku da li je do qbittorrenta (prilicno sam siguran da nije), do trackera (opet cenim da nije) ili do HDD.
If you use qBitTorrent and have several interfaces open to the internet, make sure to disable multi-homed feature in the qBitTorrent, set preferred interface so it doesn't announce on all of them. This is a problematic feature, it's basically cheating, it sends the same data several times, tracker receives it in parallel and processes it and adds the amount multiple times to download and upload.
Go to Options - Advanced - Network interface (3rd option) and change the value "any interface" to your primary interface (only needed if you have several active connections like LAN and Wifi at the same time).
