Multisplit je idealno rešenje sa parapetnim jedinicama, ne mogu da se porede zidne sa ovim.
Ko nije probao, naravno tvrdi drugačije i lepše i bolje mu je da kači 5 kutija oko kuće, nego samo jednu ali vrednu 😉
Parapetne su takodje bolje kao zasebni uredjaji, nema nikakve razlike izmedju zidnih i parapetnih, osim u poziciji unutrasnje.
Ko nije imao servis bele tehnike 30 godina, naravno da tvrdi drugacije i kada mu crkne nesto, saznace zasto mu je neko pricao da se multi uzima samo ako je jedino resenje 😉
A pored toga, manje efikasan uredjaj i skuplji za ugradnju.
Imam 10 klima u jednoj kuci, u trosobnom stanu u kom zivim imam 4 klime, ukupno kada saberem, trenutno imam 25+ klima, ni jedan jedini split 🙂
Naravno, sve osim jedne vikendice sa TP, grejemo klimama.
Nadam se da nemas klimu u hodniku od 5m2 i u kupatilu?
Bas u kuci i jeste lakse imati vise spoljasnjih, bukvalno nemas limit, dok si u stanu cesto ogranicen.
There are three issues here, which system is better, which system is more energy-efficient and which system is more reliable.
The first issue encompasses all aspects and involves a priority ranking which only you can do.
An issue not brought up by anyone else is the installation. Do you have room for 3 outside units? Does it matter if more space is used or would you prefer to use that space for landscaping or something else?
What about electrical power? Will the installer need to run 3 circuits, one for each compressor? Does your existing breaker panel have the room for 3 circuits?
Another installation consideration: which system is easier to run the linesets (tubes which carry the liquid and gas freon) for?
I expect 3 compressors to cost more than one big compressor. Have you gotten any price quotes?
The one big compressor, assuming it is capable of variable speed, will certainly be more significantly more efficient under anything less than full load because the condenser of a single outdoor unit system has three times the cooling area of a single condenser in a 3 unit system which means the compressor motor doesn't have to work as hard.
The major factor in power consumption is turning the freon back into a liquid and that depends on how fast/easily the condenser can cool it off. All else being equal, a bigger condenser is better (removes the heat faster).
The faster you condense the freon, the less back pressure on the compressor and the less work for the motor.
Most of the time you will not be running full load or all indoor units at once. Even during full load, the big unit will never be less efficient.
The last question is reliability and available. One answer correctly claims that a 3 unit system will be more available but neglects to mention that it will also be more prone to failure because you have more units to fail and each unit is more likely to be run at full capacity while the big unit will usually be running well below its full capacity. Imagine the lifetime of two cars, one run at 90 MPH and one run at 30 MPH.
Assuming an equal load at the evaporator, the larger condenser will allow cooler refrigerant. If two condensers are made of the same material and construction, then the surface area determines the thermal resistance and a larger area means less resistance.
Deluje da ko ima multi bi uvek isao na multi i obrnuto
10 klima na kuci! hahah..au bre
Na kuci kojoj sam naveo sistem tipa multi sa 3 unutrasnje po etazi bi resio sve.
Grejanje i hladjenje. Umesto 6 singl
Da, kamena vuna jeste najbolje rešenje, ali dosta skupo rešenje.
Slični rezultati se postižu i sa debljim stiroporom, tako da je upitno ulaganje u kamenu vunu, pogotovo što su zime kod nas sve slabije.
Kad kažem deblji stiropor mislim na 10-12cm.
A u potpunosti se slažem da ulagati u bilo koji vid toplotne pumpe bez dobre izolacije je bacanje para.
Pa onda je bacanje para i grejanje na pelet i drva i ugalj. Nebitno koji vid grejanja, bez izolacije se svaki ogrev koristi vise, nebitno da li su to drva, pelet ili struja i ta drva kostaju, ugalj, pelet. Po vasoj logici bez izolacije onda da se ne grejemo uopste. 😄
Nista od gore napisanog za multi vs single nije tacno, niti ima logike 🙂
Za pocetak da je jedna klima sa 5 unutrasnjih i 15 puta vise cevi, manje opterecena od 5 klima...totalna nebuloza 🙂
Takodje da je vise efikasna je tek nebuloza, isto s obzirom da ima 15 puta vise cevi u proseku.
Evo nesto malo realnije, da ne citiram ceo tekst od kilometar:
Slažem se, svaki vid grejanja koji god da je, se više troši ako nema izolacije, ali....
Toplotne pumpe su nisko-temperaturna grejanja i za njih je potrebna dobra izolovanost objekta da bi se takav vid grejanja uopšte isplatio, recimo toplotna pumpa sa radijatorskim grejanjem troši više struje od podnog i mnogi inženjeri je ne preporučuju iako je objekat dobro izolovan.
Inverter klima kao TP vazduh-vazduh takođe traži dobro izolovan objekat, posebno kod grejanja, jer u suprotnom biće mnogo skuplje grejanje i pitanje je da li će uopšte moći da ugreje objekat koji nije izolovan!
Postoje mnogi tekstovi za i mnogi protiv, ali da je obična inverter bolja od multi, pa i toplotne pumpe vazduh voda bi postojale za svaku sobu posebno, zar ne!
Gornji tekst je veoma ubedljiv, sa činjenicama, e sad to što se nekome ne sviđa je druga stvar.
Naravno da je ekonomičnije preterati 25 tona robe jednim šleperom, nego angažovati preko 20 kombi vozila za isti teret itd.
@Xepoj87 da li si gledao mozda specifikacije za spoljne multi? Ili multi komplete.. Mislim na efikasnost..
Nekako mi sve deluje bolje
Uff, ne ide ti analogija bas 🙂
Ubedljiv mozda nekome ko se ne razume, ali je sve pogresno napisano.
Slicne tekstove ovom sto sam ja postavio mozes naci i na stranicama drugih ozbiljnih firmi za klimatizaciju, a i nekih proizvodjaca.
Procitaj malo vise tekstova, a ne samo ovaj amaterski koji odgovara tvom narativu 🙂
Ja sam pre par meseci stavio 8 Flexus Plus klima u kucu dok smo renovirali, mogao sam i multi split, nista mi nije znacilo jedno ili drugo, ali je opste poznato da je multi nuzno zlo.
Kao sto sam rekao, videces kada budes u sred sezone zvao majstore za multi split, pa te 3 servisa odbiju jer "nemaju vremena", a 4. ti uzme za ruke kao da je popravljao 4 klime, pa te deo kosta kao za 4 klime, a onda i dostupnost dela i vreme isporuke istog dolazi na red...a tebi cela kuca gori na 40c.
Evo, ja skinuo jutros klimu iz moje sobe, u sobi mi je prijatnih 25c bez vlage, iz kuhinje mi siba druga klimica.
Ne moze klima koja gura gas i ulje kroz 15m cevi biti efikasnija od one koja to radi kroz 3m.
Dodatno te cevi gube energiju, sto je veca duzina, vece je rasipanje energije.
Ako klima ide do recimo 25% svog kapaciteta, mini split od 12k btu daje 2.4k btu, a multi od 30k btu nikada nece moci da radi ispod 6k btu.
Cisto rasipanje energije kada ti ne treba 6k btu recimo.
I nemoj mesati toplotnu pumpu vazduh/voda sa multi splitom, nije ista stvar.
Evo jos jednog teksta ako vas mrzi da citate onaj duzi, mada ovde nije sve pokriveno, ovo je takodje povrsno napisano:
Gde je veća potrošnja struje,tri zasebne 12-ice,ili jedan multi u tom kapacitetu.pri istoj spoljnoj i zadatoj temperaturi?
Koliko košta redovan servis za mutli, a koliko za one gore tri 12-ice?
Koliku spoljnu buku generišu tri spoljne ,naspram jedne?
Stan ili kuća,nije isto.
Mora da postoji neki neoborivi matematički dokaz,koji bi išao na jednu ili na drugu stanu.
Tako je, to je sustina. Neizolovan objekat koji se greje putem radijatora ili podnim grejanjem daleko manje rasipa energiju od istog takvog koji se greje klima uredjajem ili sa ta pec, odnosno teze je zagrejati takav objekat sa klimama. Kuca 80m2 prve dve sezone potrosnja 4t po sezoni, treca sezona uradjena izolacija potrosnja 2.5t, pa to je samo za dve sezone baceno po tadasnjim cenama skoro 1000 evra.
Nije mi jasno čemu to lično sada "odgovara tvom narativu"
Drzi se teme nisam tebe uzimao da licni etiketiram da si ovakav ili onakav .
Amater jesam i ne bavim se klimama. Amater sam kao mnogi koji se bave klimama jer njihovo je da izbuse rupu u zidu, vakumiraju, provere da li radi i ide na sledeću ugradnju.
Koliko vidim najveći problem su majstori / serviseri i njihova volja da rade multi.
Ne znam cemu taj ekstrem od 15m, ne stavljaš klimu u suprotan kraj kuće vec u blizini prostorija.
5-6m bi većinom zavrsilo posao.
Citati sa linkova koje si slao:
While multi-split units are often the best choice for cooling multiple rooms with different climates, they need to have a sufficient BTU rating for the largest room to cool efficiently without stressing the outdoor unit.
Though multi-split units offer versatility and high performance for multiple spaces, they require longer pipe lengths, which puts more stress on the outdoor unit, resulting in significantly decreased efficiency compared to single split units. Performance Multi-split units have the edge in terms of overall performance and versatility. While single split ACs only have one indoor unit to cool whatever space or spaces they’re connected to, multi-split models use multiple indoor units, allowing them to cool a whole floor effectively off of one outdoor unit without cluttering the appearance of the outside of a home.
Znaci bolje performance ali smanjenje efikasnost zbog duzine cevi..
E sada da li je zakon u celom svetu isti kao kod nas da mora 3m cevi ili moze kao sto je pre bilo da crevo moze da bude koliko je debeo zid.. Pa se ovaj članak odnosi na singl 3m vs 5m multi.. Ili je kod njih (tamo odakle je ovaj clanak) crevo sto kraće..tu se slažem da sigurno ima razlike izmedju 1m vs 5m.
Po obom tekstu ako bi multi dohvatio sve na 3m dužine, bilo bi isto kao split sa boljim performansama.
Fizičke osobine objekata se ne menjaju od nacina na koji se greje. Blok je i dalje blok i njegovo prenošenje toplote je isto. Jedino sto čvrsto gorivo dostiže vece temperature od klime.
Na to sam mislio ali se nisam dobro izrazio ☺
Jeste da ce neizolovan objekat teze zagrejati, utrositi vise energije na klimu nego sto ona moze da ustedi ako je izolacija. Ali opet ce manje potrositi za mes dana nego sto kosta metar drva😄
Inace ja na prostoriji planiram izolaciju 5cm mozda i 10 cm iznutra da odradim dva spoljna zida i na tavanu na ploci da stavim takodje vunu
Baš su Ing. glupi kad su napravili te multi split klime i još uložili milione u razvoj uređaja.
Saznacemo u sredu 🙂
Dolaze u 9 momci iz Steelsoft-a da instaliraju, a sutra treba nekoga da iscimam da mi mice vise ovu nesrecnu Fujitsu 🙂
Inace, uzeo sam VG2 verziju LN klime, to je novija, a imaju i dalje i VG verziju, pa da zna neko ako uzima.
A posto sam ulazio u magacin da nadjemo klimu, videh da ipak i kod nas imaju vgHZ(ali nemaju vg2hz) verziju ili ti nordic verziju LN klime, koja je dosta skuplja, ali zadrzava 100% nominalnog kapaciteta, svih 4kW do -20c.
Opet, retko kome to treba, sa nasom klimom je svakako suvisno, otprilike kao i Amber Premium.
Hteo sam crvenu/bordo, ali na kraju ipak odigrah na sigurnu boju...
Evo malo sto sam isfotkao na brzaka:
Zar steelsoft prodaje Haier?
Poz. Nisam baš čitao temu i ne razumem se u klime a prvenstveno bih uzeo neku koja bi mogla normalno da greje. Nemam izolaciju, mada uradiću spušteni plafon gde ću staviti vunu. grejao bih oko 24m2 što nije puno, ali ne znam šta bi tu najbolje vršilo posao a da nije preskupo. Čisto sumnjam da bih mogao da izdvojim više od 70.000.
Svaka pomoć i savet su dobrodošli.
Nisam tebi odgovorio uopste, vec na post iznad tvog, od clana gaga75, valjda vidis da je povukao analogiju sa sleperima i da je poredio tp voda/vazduh i multi-split, o cemu ti uopste nisi pricao 🙂
Nisu bolje performanse, jer ces i single uzimati u odnosu na prostor, da se ne opterecuju. Cak sta vise, na nekim minusima sam siguran da ce se multi split vise opteretiti ako grejes svim UJ, jer se retko kada uzima prejaka SJ, obicno se uzme ono sto je po spec potrebno, dok split kada ugradis i saberes, sve imaju debele rezerve.
Sta ces da pokrijes sa 3-5m na multi splitu? Pa ako hoces na sprat, a spoljasnja ti stoji u dvoristu, samo do sprata imas jedno 7m, plus po 3-10m po prostoriji.
Ja na single imam 5m instalacije jer mi unutrasnja stoji na sredini sobe, a ti bi na multi da ne prelazi 3-5m nigde u kuci 🙂
Nemamo mi zakon za 3m cevi, to su proizvodjaci stavili u svoja uputstva i to se svuda u svetu primenjuje.
Nije samo do duzine cevi, cinjenica je da jednu 36k btu multi ne mozes da nateras da radi na 100W kada ti treba za hladjenje jedne sobe, vec ce da trosi min 500W.
Nije nista od ovoga nesto novo, to su cinjenice o multi-splitu, ali da, najveca mana je sto ako crkne spoljasnja, crkava sve, a servisa i delova ces da se nacekas.
I onda kada se napokon smiluju da ti poprave i da ti nabave delove, naplate ti to kao da su 3 klime popravljali, a i delovi su tako muski.
Pa sama ugradnja je dovoljno komplikovanija da moraju da salju ozbiljnije majstore i naplate vise.
Nije multi nesto sto si se zeznuo ako si uzeo, samo je prosto losije u odnosu na individualne klime i to je to.
Svako ima nesto sto mu je prioritet i ne postoji savrseno resenje za sve.
Prednost splita je to sto zauzima znatno manje prostora i elegantnije je resenje, kao i to sto bude tise jer nemas spoljasnje jedinice svuda po kuci vec jednu u dvoristu.
Takodje ne busis fasadu i ne poruznjavas kucu. Pa kome je sta bitno.
@aleksa.ue Prodaju oni sve zivo.
Necu sigurno, ceo zivot u kuci, navikao da imam psa, dvoriste leti za rostiljanje i druzenje...ali ko te pita.
10 klima na jednoj kuci? Gdje ih nasadi toliko... Jel sve od jednom rade? Ja dve i treca od lokala izbacena.
    163.8 KB · Pregleda: 78
Da, 2 su u potkrovlju i po 4 18ice po spratu, kuca ima ~450m2, od cega se terasa od 80m2 i ispod nje, greje sa podnim. Dodatno je 300m od Dunava, pa je i vlaga povelika.
    319.7 KB · Pregleda: 75
Ma nema grejanja neizolovanog objekta klima uredjajima to je poenta. Cim izadjes iz prostorije gde radi klima odmah ti je hladno, jer nije isto grejanje klima uredjajima i centralnim grejanjem, pojedinih delova i celog objekta. Svi bi na dugme ali ako mogu nesto da preskoce, a kada dodje zima onda vide da su se zeznuli ali im sujeta ne dozvoljava da to priznaju sebi i drugima. Ako budes radio samo iznutra onda ces stvoriti hladne mostove pa ces dobiti vlagu. Ti da vidis kako izgledaju kuce na termo kameri gde je uradjena samo unutrasnja izolacija, nikada ne bi razmisljao o tome. Izolacija se radi spolja i iskljucivo za ceo objekat u suprotnom nastaje velika razlika u temperaturi zidovi koji automatski postaju hladni mostovi, a koji vec postoje na spojevima razlicitih materijala, primera radi cigla-blok. Zato kuce na kojima je delimicno uradjena izolacija tamo gde je nema dobiju vlagu posle samo 2 godine.
2 12ice su bez problema grejale 80-90m2 u PVC-u i to Mission 2 Midea, ne neke azdaje.
Problem kod nemanja izolacije je najvise sto ce oscilirati temperatura u defrostu vise nego sa izolacijom i sto ce racuni biti veci, ali nije to nebo i zemlja, tek bude problem kada se dodje do crvene zone.
Preuvelicava se sve oko izolacije. Da, dosta je bolje, ali ne znaci da je bez nje nemoguce.
Ako niste probali, nemojte napamet pricati.
Do crvene zone ce se doci bez ikakvih problema kada se koristi vise uredja u zimskim mesecima, a svi su na jednom brojilu. Bez klime jedna cetvoroclana porodica trosi oko 450 kw, sa 4 uredjaja za vec spominjanu kvadraturu posle nemalo 20 dana preci ce se limit od 1500kw ako ne i pre. Dovoljan je pokazatelj potrosnja peleta i gubitak od gotovo 1k evra, ne znam sta vise treba. Ali najjace je sto stav o grejanju klimama neizolovanih objekata brane iskljucivo oni koji imaju izolovane objekte.
Koju klimu od ove 2 uzeti prvenstveno za grejanje
FTXC35C
ASYG12KMCE
Ovako, nisam termoinzinjer ali ako sam dobro racunao to je ovo za kucu od 145m2 bez izolacije , puna opeka, blok + malet ima bolje karakteristike jer temp moze da se prenosi samo gde ima materijala a ne kroz supljine
na 15c da nam u kuci bude 24c bez izolacije imamo oko 8kw toplotnih gubitaka tj toliko nam toplote treba da bi odrzavali tu temp od 24c.
Jedan stepen vise ili manje je ogromna razlika. Nekome ce biti dovoljno 22c
Posto klima na 15c ima super efikasnost grejanja i lagano moze da pravi 8kw toplote od 2kw struje 2x24x30=1440kw
Sa blokom je 1100kw mesecno
plus ostatak potrosnje ulazi najverovatnije u crvenu zonu pa sam stavio 1800kw.
Manje od 1t peleta
na 10c da u kuci bude 24c
Ovde mozemo da racunamo 3kw x24x30 = 2160kw za mesec dan
Sa blokom je 1500kw mesecno
mesecna cena za grejanje sa ostalim racunima oko 300e = 1 tona peleta (koliko pojede objekat bez izolacije peleta to tek treba izracunati)
na 5c da bi imali 24c u kuci
ovde je pitanje da li je moguce racunati da klima baca 1:4 jer dosta klima ima racunanje na 7c u specifikacijama, tako da racunam 1:3 struja:kw
5*24*30=3600
Sa blokom je 2800kw mesecno
dodamo jos 10k za ostatk kuce
Oko 2.5t peleta
Od 0 stepeni neizolovan objekat jede struju i tada bas nije isplatovo.
Svi se hvataju -15stepeni i bez izolacije.
Posto sam imao klimu i pre izolacije koristio sam je na tajmer od 7-14h jer kotao nije mogao da izvuce noc.
Nesto najgore je kada se probudite a vama je u kuci 18-20c. Zenama bude bas hladno.
Klima je radila u dnevnoj preko dana dok se neko ne organizuje i zalozi kotao.
Nekome ce biti dovoljno da klima radi samo 6 sati uvece od 18 -24h kada je temp 15c napolju
Poenta je da nije 29c leto i odmah zima sa nula stepeni.. do te nule ima dosta dana koji se krecu u rasponu od 5-20c kada je u kuci hladno/hladnjikavo bez grejanja.
U tom periodu klime su solidan izbor ako planiramo da stavimo izolaciju za 2-3godine .
prosecno srednja vrednost za feb je 2.5c, za novembar 7.5c i iz toga mozemo da predpostavimo da feb ce tesko izvuci klima bez izolacije ali nov je ok.
Moramo da se grejemo pa moramo. Ako planiramo promenu grejnog tela, ne vidim veliki problem da se uzmu klime pa izolacija nakon.
Pitao sam ljude koji rade profesionalno izolaciju, nema nikakve vlage sa vunom jer vuna dise. Vlaga se pojavljuje kada se izolacija radi sa stiroporom jer zidovi ne disu. Inace nakvec gubitak toplote je oko prozora i na plafonu jer topao vazduh ide na gore, tako da je bitno staviti vunu preko ploce na tavanu.
Ako lozim na 3 mesta po 2m drva a klima mi po prostoriji nece pojesti sigurno vise od 4000-5000din.
