i9 13900kf i Z790 AORUS ELITE AX DDR4 cpu trotluje
darkbaron
Poštovan
CPU & Cooler
i9 13900kf Arctic Liquid Freezer II 360
Matična ploča
gigabyte aorus elite ddr4 z790
RAM
g.skill 32gb
GPU
rtx 3090ti zotac
Storage
2x ssd 2x hard drive
PSU
cobra power 1000w
Kućište
Cooler Master MasterBox
Miš & tastatura
red dragon wireless
Mobilni telefon
samsung s22 ultra
Pazario sam novi hladjenje Liquid Freezer II 360 i dalje imam problema u odredjenim igrama cpu trotluje za sinteticke testove vec da ne pricam zakuca 100 stepeni za 2 sek.E sada dajte neki savet sta bih jos mogao da probam.
Skini cooler i proveri kako naleze na CPU.
Vidim po netu da je to furuna, slabo pratim Intel u poslednje vreme. Mozda neka podesavanja u biosu za voltazu?
Limitiraj potrošnju procesora i pašće temp. Samim tim će i taktovi biti niži.
Pomoglo smanjio CORE VOLTAGE OFFSET sada je su temperature ok u sitetickim testivima ne prelazu 95-96 sto sasvim prihvatljivo nema trotlinga.
Evo postavki koje dobro rade:
We will try to do this using just the loadlines.
So let set the folowing:
  • Enforce All Limits (If you desire you can remove all limits) *
  • LLC#4
  • DC_LL = 1.02
  • AC_LL = 0.2
  • IA VR Voltage limit = AUTO (or 1700 if you desire) *
* Here I need to make an explanation:
  • Depending on your CPU quality (SP number for P-cores and E-Cores) Enforcing All intel Limits may cause your CPU not to reach the desired frequencies, since intel only guarantees the default frequencies.
  • The voltage limit of this processor is 1720mv and there is no problem in letting the CPU itself do this control.
  • As a security measure you can set a limit of 1700mv. Lower values will cause frequencies that require a value greater than the stipulated to be capped. This process, if not very well adjusted, can bring instabilities to the system.
Dobar tekst na ovu temu https://www.overclock.net/threads/a...-13900k-a-tuning-guide-for-beginners.1801569/
@darkbaron
Sa Liquid Freezer II 360 13900KF radi sa temperaturoam ispod 95c u CinebenchR23 testu ?
Treba ohladiti skoro 6GHZ a i sta ce ti toliko GHZ u igricama dosta ti je 4.5-5GHZ
