Motorola Moto X30 Pro
  • Začetnik teme Začetnik teme nitro5
nitro5
Cenjen
Prava mala masina za 550e, nadam se da ce se pojaviti na EU trzistu sa dobrom cenom.
Motorola Moto X30 Pro Specifications​
BASIC INFO
BrandMotorola
ModelMoto X30 Pro
StatusComing soon
Release Date2022, December
BODY
Dimensions163.6 x 75.6 x 8.5 mm
Weight194 g
ColorsWhite, Black
Body MaterialGlass front, glass back (Gorilla Glass 5)
SIMsDual SIM (Nano-SIM, dual stand-by)
Water & DustWater-repellent design
DISPLAY
Size6.67 inches
TypeOLED, FHD+ 144Hz
Resolutions1080 x 2400 pixels, 20:9 ratio
PPI393 ppi density
Multi touchYes
Protection-
NETWORKS
2GGSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2
3GHSDPA 850 / 900 / 1800 / 1900 / 2100
4G1, 2, 3, 4, 5, 7, 8, 12, 17, 34, 38, 39, 40, 41
5GSA/NSA
SpeedHSPA 42.2/5.76 Mbps, LTE-A (CA), 5G
GPRSYes
EDGEYes
CAMERA
Rear Triple200 MP, f/1.9, (wide), 1/1.55", 1.0µm, Dual Pixel PDAF, OIS
50 MP, f/2.2, 114? (ultrawide), 1/2.76", 0.64µm
2 MP, f/2.4, (depth)
FeaturesDual-LED flash, panorama, HDR
Videos4K@30fps, 1080p@30/60/120/240fps, 720p@960fps, 10-bit HDR10+, gyro-EIS
Front60 MP
HARDWARE
OSAndroid 12
ChipsetQualcomm Snapdragon 8+ Gen 1 5G
CPUOcta-core (1x3.00 GHz Cortex-X2 & 3x2.50 GHz Cortex-A710 & 4x1.80 GHz Cortex-A510)
GPUAdreno 730
RAM8GB / 12GB
Storage128GB / 256GB / 512GB
Card SlotNo
BATTERY
TypeLi-Po
Capacity4550 mAh
RemovableNon-Removable
Talk TimeN/A
Stand ByN/A
ChargingFast charging 125W
COMMONS
SoundYes, with stereo speakers
SensorsFingerprint (side-mounted), accelerometer, gyro, proximity, compass
Ready For support
Bluetooth5.2, A2DP, LE
GPSYes, with dual-band A-GPS, GLONASS, BDS, GALILEO
USBType-C
Wi FiWi-Fi 802.11 a/b/g/n/ac/6, dual-band, Wi-Fi Direct, hotspot
NFCYes
Negde proičitah da će cena biti 800-900 eur
Nije mala masina, vec cigla...motorola bas ne zna da napravi kompaktniji telefon...imaju odlicne telefone, ali sve su cigle... 🙂
Pa i nije da nije...6.5 ekran i 160mm visine nije kompaktan fon...u sustini, oko 5.5-6" je taman...bar za mene.. 😀
6,7 inca je mozda veliko ali nista preterano, bar za mene😁 Samo da bude povoljan ili bar slican ceni kao u Kini, bio bi hit, ako bude 800-900e bice previse.
Gledam ovu mučenu telephoto kameru od 12mp sa 2x optičkim zumom i pitam se, čemu to uz glavni senzor od 200mp? Ili se negde varam?
Takođe, uz senzor veličine 200mp, realno bi bilo videti slot za sd karticu ili proširiti internu memoriju.
Onda, skok na bateriju: 4500mAh? Hm, bojim se da je ovo, bez obzira na odličan procesor, premalo.
Stvar je ličnog ukusa izgled kamera, ali "prelivajući" ekran nije. Imam edge+ i verovao sam da se više neće vraćati na to, ali... Avaj.
Ipak, sve u svemu, kvalitetan telefon, bar na papiru, ako izuzmemo ove manice i moram priznati da bih ga rado pazario u Kini, jer cena tamo baš obećava. Bojim se napumpane cene u Evropi kad stigne.
U ovoj klasi su tri kamere jednostavno obavezujuće. Manje je bitna svrha. Na edge 20 pro su stavili 5x optiku, ali su zahebali sa senzorom i posebno sa softverom koji menja rezoluciju sa izvornih 8 na 12 Mpix. E to je Motorolin problem. Lepše izgleda fotografija sa 10 - 50x uvećanjem kada napravim snimak ekrana, nego kada fotografišem jer softver usere sve.
Ja se dvoumim izmedju njega i Realme GT 2 Master Explorer Edition. Nema naznaka kada ce se pojaviti globalno...
Malo su pojacali cenu, u Kini je verzija 12/256GB oko 600e. Ako bude nekih poklona, bice to fina kupovina🙂
Veoma interesantno. Ne znam samo UI kakav je..
Ima skoro pa cist Android, po meni najbolja opcija. Gledam sada u EU je preporucena cena 900e i obecali su da ce biti 2 velike nadogradnje i 3 godine sigurnosnih zakrpa.
Pojavio se u Yettel-u, cena uredjaja uz najmanju tarifu je 116k, a bila je prica da ce biti 100k... Nadam se da ce uskoro i kod drugih operatera i da ce cena biti malo razumnija.
Yettel odavno ne treba uzeti u razmatranju tarife sa telefonom. Znači,zlatno pravilo. Uređaj za keš i ako baš mora kod njih,tarifa sa 50% umanjenja kod njih i vozi
Interesantan telefon. Jedina zamerka što nema IR port. Ostalo mi sve odgovara. Uvek mora nešto da fali😕
Probao neko telefon?
Vidim na KP su oko 600e
Na papiru deluje odlicno
Nema ga jos na KP, ovo je kineski X30 Pro ili za globalno trziste Edge 30 Ultra.
P.S. Admine bih zamolio da promene naslov u Motorola Edge 30 Ultra/Fusion/Neo. Hvala🙂
da sad vidim da je ovo na kp obican x30..mada osim osveljenje ekrana (koje jeste bitno).. ne vidim neke velike razlike..i obican je opasna masina
Razlika je velika, tj. ovaj ima SD 8+ Gen 1 koji je odlican procesor a obican X30 ima SD 8 Gen 1 koji je krs od procesora!
Pojavila se i u MTS-u.
P.S. Admini dodajte u nazivu Motorola Moto X30 Pro/Edge 30 Ultra.
