Elden Ring
DeRadicci
VIP član
Cross-gen, izlazi 21. januara 2022.
ELDEN RING is FromSoftware's largest game to-date and is set in a sprawling realm steeped in a rich and bloody
history crafted by Hidetaka Miyazaki – creator of the influential and critically acclaimed DARK SOULS video game
series; and George R.R. Martin – author of The New York Times best-selling fantasy series, A Song of Ice and Fire.
OOOOOOOOO, The Elden Ring !!!!
Malo više detalja.
  • hub confirmed
  • catacombs, castles, fortresses, mini dungeons etc.
  • confident that Elden Ring will arrive on its release date
  • character creator
  • multiple endings
  • much higher degree of freedom than before
  • optional bosses
  • Battle arts from DS3 return but are not fixed to a weapon (~100 techniques)
  • Spirits can be collected and equipped apparently (summons)
  • different types of spirits (use them for assaults, as decoy, for defense etc)
  • Spirits can be improved apparently
  • There are also rather useless spirits with other traits
  • multiplayer support during exploration on the open fields (but you are not able to ride your horses in multiplayer apparently)
  • ER is more "manageable" due to the many different options the player has but there are still many tough enemies
  • fall damage is low to keep explorers motivated
  • there is a world map
  • the actual dungeons do not have a map
  • crafting system with materials
  • Miyazaki guesses playtime is maybe at 30 hours "without too many side trips"
  • Asynchrous multiplayer elements return; you can apparently set up groups (with friends for example) and give their messages/dead bodies etc. higher priority (keyword system, no limit on group size)
I pomereno. Ništa posebno doduše.
Grafika kao da je PS3...
Vise kao ps4 (za koji ce i da izadje, a i za ps5), ali to u ovim vremenima kada covek ne moze da dodje do pristojne grafe i te kako ima smisla.
Druga stvar - souls igre se ne igraju zbog grafike.
gomila ljudi igra betu na twitchu, fromsoft je izgleda dozvolio streaming, pa ko zeli... link
Meni se nekako ovaj open world ne svidja, bar po ovome što sam video. Nigde nema neko selo, gradić, ili kamp gde su neki prijateljski NPCevi. Neki preživali ili šta već te neke nazovimo apokalipse koja se desila.
Grafika je tu negde 2013-2014.
Težina igre deluje "pristupačno svima" tj nije teška ko Dark Souls.
To su mi prvi utisci nakon trejlera.
Fromsoftove igre su uvek kaskale par godina (I više) po grafici, uvek je bilo i problema sa performansama I latencijama. Na PC su uvek udarali lock na 60fps.
Ali sve to je postajalo nebitno posle pet minuta. Kad se izgubiš u njihovom svetu, kad te navuče kvalitet gejmplej mehanike, sve ostalo više ni ne primećuješ I postaje nebitno.
neka dobra pitanja i konkretni odgovori, konacno neko u ign ko poznaje materiju o kojoj prica, ovaj se naigrao fromsoftovih igara
šta znam, nisam baš nešto oduševljen, dizajn neprijatelja mi se uopšte ne dopata, a i svet deluje nekako prazno, bezveze.
Igra neće imati podršku za ultrawide i biće zaključana na 60fps, izgleda...mašala.
Plus nista inovativno do sad nisam video, mogla je da izadje i 2017. ovako..
solidarnost sa gamerima koji ne zele da kupuju overpriced gpus 🙂
From Soft pravi igre i za PC već deceniju. Ako im 11 godina (prvi Dark Souls za PC je izašao 2011.) nije bilo dovoljno da nauče da ne zaključavaju framerate i da ne vezuju fiziku u igrama za framerate, treba da se stide i treba ih prozivati. Više ne mogu da se pravdaju uobičajenim "JP dev, nisu navikli na PC", ne nakon 11 godina.
Možda treba da ih branimo sa "pls understand, u Japanu još nisu čuli za tu magičnu, još neviđenu, space age tehnologiju zvanu ultrawide monitori"? Ako nisu, za internet jesu, mogli su da ih vide na netu. A čak i u Japanu znaju za monitore sa više od 60 Hz...
Godina je 2022, rade sa PC-jem više od deceniju, nemaju opravdanja za 60 fps lock na PC-ju, tačka.
Da, ljudi ne znaju. To je zbog toga. Uzmi igraj nesto drugo. Resen problem.
Kad napunis 11 godina, bice ti jasnije neke stvari.
Slobodno nas prosvetli, premudri.
Anyway...na Steam stranici su na kratko objavili minimalne HW zahteve (navodno) ali je ubrzo povučeno i sada stoji TBD:
MINIMUM:
OS: Win10, Win11
Processor: Intel Core i5-8400 or AMD Ryzen 3 3300X
Memory: 12 GB RAM
Graphics: NVIDIA GeForce GTX 1060, 3 GB or AMD Radeon RX 580, 4 GB
DirectX: Version 12
Storage: 60 GB available space
