jddipqd
Imam čudan problem sa pristupom DNS-u kroz Wireguard VPN.
Topologija je ovakva:
Peer 1 - WG Server - Peer 2 - LAN
WG je namešten da radi sa subnetom 192.168.66.0/24
LAN je u subnetu 192.168.10.0/24
WG Server je na Ubuntu 20.04 sa uključenim ufw
Unutar LAN-a iza Peer-a 2 se nalazi DNS server (192.168.10.8)
WG server može da pinguje DNS server i da uspešno radi nslookup
Peer 1 može da pinguje DNS sever, ali ne može da uradi nslookup
Ufw setup je:
Ima li neko ideju šta je ovde pogrešno?
Pretpostavljam da je ufw problem (tj neki njegov default) pošto sam ranije imao sličan setup gde je WG server bio na CentOS-u i nije bilo ovakvih problema.
Kod:
ping 192.168.10.8
PING 192.168.10.8 (192.168.10.8) 56(84) bytes of data.
64 bytes from 192.168.10.8: icmp_seq=1 ttl=63 time=45.9 ms
Kod:
nslookup www.google.com 192.168.10.8
Server: 192.168.10.8
Address: 192.168.10.8#53
Non-authoritative answer:
Address: 216.58.212.36
Address: 2a00:1450:4017:805::2004
Kod:
ping 192.168.10.8
64 bytes from 192.168.10.8: icmp_seq=1 ttl=62 time=217 ms
Kod:
;; connection timed out; no servers could be reached
Ufw setup je:
Kod:
sudo ufw status
Status: active
To Action From
22/tcp ALLOW Anywhere
51820/udp ALLOW Anywhere
22/tcp (v6) ALLOW Anywhere (v6)
51820/udp (v6) ALLOW Anywhere (v6)
53 ALLOW OUT Anywhere
53 (v6) ALLOW OUT Anywhere (v6)
Anywhere on eth0 ALLOW FWD Anywhere on wg0
Anywhere on wg0 ALLOW FWD Anywhere on eth0
Anywhere (v6) on eth0 ALLOW FWD Anywhere (v6) on wg0
Anywhere (v6) on wg0 ALLOW FWD Anywhere (v6) on eth0
