Telekom Srbija i cloudflare DNS problemi
poglavicas
CPU & Cooler
Ryzen 5 9600
Matična ploča
MSI Pro B650-S WIFI
RAM
64GB DDR5 5600MHz
GPU
AMD Radeon RX6600 8G
Storage
1TB PNY CS3030 + 1TB Kingston NV2
PSU
LC6550
Kućište
Deepcool Matrexx 30
Monitor
AOC Q3279VWFD8
Miš & tastatura
Redragon Apas K535-KR
Laptop
Lenovo ThinkBook 14 G3 AMD 4700G
Mobilni telefon
Poco F6
Pristup internetu
  1. Optički internet
Već neko vreme imam problema sa CloudFlare DNSom na svim telekom mrežama, ADSL/VDSL, mobilni, Exe...
Sa svih ovih mreža ne radi DNS na 1.1.1.1, radi samo onaj na 1.0.0.1 i to sa cloudflare servera u Beču.
Ono što je još čudnije je što ping do 1.1.1.1 navodno radi, ali ima jednu izuzetno čudnu stvar, a to je TTL (Time to live).
Ping iz ExeNet mreže:
Kod:
ping 1.1.1.1 -c 4
PING 1.1.1.1 (1.1.1.1) 56(84) bytes of data.
64 bytes from 1.1.1.1: icmp_seq=1 [B]ttl=249[/B] time=11.0 ms
64 bytes from 1.1.1.1: icmp_seq=2 [B]ttl=249[/B] time=10.9 ms
64 bytes from 1.1.1.1: icmp_seq=3 [B]ttl=249[/B] time=10.7 ms
64 bytes from 1.1.1.1: icmp_seq=4 [B]ttl=249[/B] time=12.3 ms
--- 1.1.1.1 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 10.739/11.239/12.279/0.607 ms
Ping sa Telekom VDSL:
Kod:
ping -c 4 1.1.1.1
64 bytes from 1.1.1.1: icmp_seq=1 [B]ttl=250[/B] time=11.0 ms
64 bytes from 1.1.1.1: icmp_seq=2 [B]ttl=250[/B] time=10.9 ms
64 bytes from 1.1.1.1: icmp_seq=3 [B]ttl=250[/B] time=10.7 ms
64 bytes from 1.1.1.1: icmp_seq=4 [B]ttl=250[/B] time=11.2 ms
4 packets transmitted, 4 received, 0% packet loss, time 3005ms
rtt min/avg/max/mdev = 10.681/10.927/11.153/0.169 ms
Dok ping ka drugoj adresi istog cloudflare servisa radi normalno, i sa normalnom TTL vrednošću:
Kod:
ping -c 4 1.0.0.1
PING 1.0.0.1 (1.0.0.1) 56(84) bytes of data.
64 bytes from 1.0.0.1: icmp_seq=1 [B]ttl=58[/B] time=17.5 ms
64 bytes from 1.0.0.1: icmp_seq=2 [B]ttl=58[/B] time=17.4 ms
64 bytes from 1.0.0.1: icmp_seq=3 [B]ttl=58[/B] time=17.7 ms
64 bytes from 1.0.0.1: icmp_seq=4 [B]ttl=58[/B] time=17.9 ms
--- 1.0.0.1 ping statistics ---
rtt min/avg/max/mdev = 17.392/17.638/17.936/0.206 ms
Na osnovu latencije se vidi da je 1.0.0.1 dalje u odnosu na 1.1.1.1 (1.0.0.1 je konkretno u Beču), a 1.1.1.1 je negde u Srbiji.
Sa drugih mreža ping do 1.1.1.1 i 1.0.0.1 je identičan, sa identičnim TTL i vremenom odziva, kod njih nema problema:
Vip:
Kod:
ping 1.1.1.1 -c 4
64 bytes from 1.1.1.1: icmp_seq=1 [B]ttl=53[/B] time=61.3 ms
64 bytes from 1.1.1.1: icmp_seq=2 [B]ttl=53[/B] time=71.7 ms
64 bytes from 1.1.1.1: icmp_seq=3 [B]ttl=53[/B] time=72.9 ms
64 bytes from 1.1.1.1: icmp_seq=4 [B]ttl=53[/B] time=97.6 ms
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 61.332/75.887/97.624/13.330 ms
Telenor:
Kod:
ping 1.1.1.1 -c 4
64 bytes from 1.1.1.1: icmp_seq=1 [B]ttl=57[/B] time=51.8 ms
64 bytes from 1.1.1.1: icmp_seq=2 [B]ttl=57[/B] time=48.4 ms
64 bytes from 1.1.1.1: icmp_seq=3 [B]ttl=57[/B] time=40.6 ms
64 bytes from 1.1.1.1: icmp_seq=4 [B]ttl=57[/B] time=40.7 ms
rtt min/avg/max/mdev = 40.621/45.367/51.801/4.869 ms
Moja pretpostavka je da je neko u Telekomu podesio rutu ka adresi 1.1.1.1 i da paketi poslati na tu adresu uopšte ne završe kod cloudflare-a, već stignu do nekog računara ili rutera u telekomu. Samim tim, iz bilo koje telekomove mreže nije moguće koristiti 1.1.1.1 DNS.
Da li možete proveriti iz drugih mreža (SBB, Beotel, Orion, sa nekih Supernova mreža...) da li vam radi Cloudflare dns?
Naj lakši način je da u browseru otvorite https://1.1.1.1/ - ako se otvori web stranica ovog servisa, onda je uredu, iz telekomovih mreža jednostavno ne može da se otvori.
Drugi način je da u terminalu (cmd) pingujete 1.1.1.1 i ako je TTL manji od 64 onda verovatno paketi stižu do cloudflare-a, a ako je preko 200, onda na ping odgovara neki drugi server ili ruter.
sa sbb radi normalno
Sent from my Mi 9T Pro using Tapatalk
Ovde samo možeš da juriš neki napredni lejer Telekomove podrške. Ovi na početku neće ni znati šta im pričas (verovatno). S toga, kreni mail-ovima da ih "mračiš" da srede rutiranje ili šta su već neadekvatno podesili. Kažem mail-ovima jer je lakše mail da se prosledi nekome ko ima veća ovlašćenja, nego da dobiješ od tehničke podrške "javiće Vam se neko iz napredne podrške" i naravno ne javi se.
Sad sam 100% siguran da ruter/server koji odgovara na 1.1.1.1 iz telekomovih mreza nije u cloudflare-u.
Telekomov bgp looking glass servis kaze sledece:
Kod:
flags destination          gateway          lpref   med aspath origin
I     1.1.1.0/24           212.200.233.98     100     0 i
A za 1.0.0.1 kaze:
Kod:
I     1.0.0.0/24           212.200.5.7         70     0 13335 i
I     1.0.0.0/24           193.203.0.195       70     0 13335 i
Za 1.1.1.1 uposte nema AS path, sto znaci da je interna ruta.
Mlacenje prazne slame, nece sigurno samo tebi otvoriti saobracaj po toj adresi.
Podesi 8.8.8.8 i 8.8.4.4 i uzivaj.
Sent from my MI 9 using Tapatalk
BeotelNet ISP Looking Glass - show ip bgp 1.1.1.1
Router: c7609_IGW
Command: show ip bgp 1.1.1.1
BGP routing table entry for 1.1.1.0/24, version 112710987
Paths: (1 available, best #1, table default)
Advertised to update-groups:
1
Refresh Epoch 1
13335, (aggregated by 13335 172.68.152.1), (Received from a RR-client), (received & used)
195.252.96.235 (metric 20) from 195.252.96.235 (195.252.96.235)
Origin IGP, metric 0, localpref 220, valid, internal, best
Community: 6700:200 6700:2011
rx pathid: 0, tx pathid: 0x0
Serbia BroadBand Looking Glass - show ip bgp 1.1.1.1
Router: Beograd
lg#
lg# show ip bgp 1.1.1.1
Paths: (5 available, best #5, table Default-IP-Routing-Table)
Not advertised to any peer
13335, (aggregated by 13335 162.158.84.1)
80.81.194.180 (metric 3) from 89.216.15.205 (89.216.15.205)
Origin IGP, localpref 210, valid, internal
Community: 13335:10071 13335:19020 13335:20050 13335:20500 13335:20530
Last update: Thu Aug 13 06:19:50 2020
185.1.27.61 (metric 3) from 89.216.7.254 (89.216.7.254)
Last update: Wed Jul 15 05:02:37 2020
13335, (aggregated by 13335 172.68.48.1)
193.203.0.195 (metric 3) from 89.216.15.193 (89.216.15.193)
Community: 13335:10114 13335:19020 13335:20050 13335:20500 13335:20530
Last update: Fri Jun 19 23:07:10 2020
193.203.0.195 (metric 3) from 89.216.15.192 (89.216.15.192)
Last update: Wed Jun 10 04:40:07 2020
185.1.27.61 (metric 3) from 89.216.7.253 (89.216.7.253)
Origin IGP, localpref 210, valid, internal, best
lg#
Kod Beotela i SBB-a je sve uredu - imaju AS path na 13335 (Cloudflare).
Ne verujem google-u. Koristicu 1.0.0.1 ili nesto svoje. Poenta je da je saobracaj ka 1.1.1.1 nemoguc.
Zatvorili su ga iz nekog razloga. Imas druge poznate koji nisu guglovi, pa probaj njih 🙂
Eto kolko je trebalo, dodje ponedeljak, neko u telekomu procita ovo i sada servis 1.1.1.1 radi sasvim normalno na njihovom internetu.
Sto znaci da ovo nije bilo uzalud.
Bravo.
