Evo da odgovorim samom sebi [emoji1] U pitanju ne bio "P sensor" koji je morao da se resetujeJe l imao neko problem da svetlo na telefonu nece da se ugasi u toku razgovora? Sve vreme je upaljeno ne znam u cemu je fora?
Sent from my HTC U11 using Tapatalk
HTC U11 has an IP67 rating and is dust, splash and water resistant up to 1 meter of freshwater for up to 30 minutes and tested under controlled laboratory conditions. Normal wear and tear may decrease splash and water resistance over time. Do not attempt to charge or otherwise use the USB Type-C port on a wet HTC U11. For drying instruction and tips on maintaining water resistance, consult the user guide, support site, or the Help app on the device. Liquid damage may not be covered under warranty.
Mislis da je resenje da tastaturu prebacim na swiftkey?Baš sam probao kad sam pročitao tvoju poruku i prebacio na htc sense keyboard. Iskače to I meni. Na swiftkey jok.
Kad kliknem na link, izbacuje neki nebulozni portal. Da nisu fasovali kroz tastaturu neki hijack ili neki tupavi redirect ili ko zna šta
Edit: Vidim da u podešavanjima tastature ima neki šuntavi "Trends" pa izgleda da odatle vuče te portalske vesti. To je "feature" Sense tastature [emoji16]
Jel ti na Gboard ne stoji?Prebacio sam se na Gboard. Bice malo privikavanje ali dobro sta da se radi.
Ne. Bio si u pravu. Hvala tiJel ti na Gboard ne stoji?
