Samsung Galaxy A80
outlaw
Uzvišen
CPU & Cooler
AMD Ryzen™ 7 5700X w/ AMD Wraith Prism LED RGB Cooler
Matična ploča
MSI B450 Tomahawk Max
RAM
16GB (2x8) DDR4 3200MHz A-DATA AX4U32008G16A-ST50 XPG
GPU
GeForce RTX™ 3070 Ti GAMING OC 8G
Storage
ADATA XPG SX8200 Pro NVMe SSD 512GB M.2 2280 PCIe & WD Red Plus WD40EFPX 4TB CMR
Zvuk
Creative Sound Blaster Z
PSU
BeQuiet Pure Power 12M 750W ATX 3.0
Kućište
NZXT H5 Flow w/ 4x Arctic P12 PWM PST A-RGB 0dB & 2x Arctic P14 PWM PST A-RGB 0dB circus
Monitor
Samsung SyncMaster 2443BW 24" 1920x1200
Miš & tastatura
Logitech G502 Hero & Logitech K740 Illuminated Keyboard
Mobilni telefon
Samsung Galaxy S24 Ultra
Pametni uređaji
Samsung Galaxy Watch4 Classic 42mm
GoPro HERO12 Black
Pristup internetu
  1. Kablovski internet
Samsung’s Galaxy A80 is an automated notchless slider with a rotating triple camera
Samsung has announced the Galaxy A80, a new midrange phone with a camera that not only slides up from the rear of the device, but also automatically rotates so it can function as both a selfie camera and a rear-mounted camera. That novel camera allows this to be the first phone to feature Samsung’s “New Infinity” display, which it announced last year.
The A80’s automated pop-up mechanism contains a triple-camera array consisting of a main 48-megapixel f/2.0 camera, flanked by an ultrawide 8-megapixel f/2.2 camera, and a third ToF (time-of-flight) sensor. The sliding camera mechanism means there’s no sight of a notch or a hole-punch in the phone’s 6.7-inch FHD+ (1080 x 2400) Super AMOLED display.
We’ve seen swiveling cameras and slider mechanisms used in smartphones before, but never together like this. Oppo’s 2014 N1 smartphone had a rotating 13-megapixel camera, although both orientations produced similarly underwhelming photos. Pop-up cameras have also appeared on a number of notchless devices over the past year, including the Vivo Nex and Oppo Find X. More recently, slider phones have also made a comeback on devices like the Honor Magic 2 and Xiaomi Mi Mix 3.
Along with its camera setup, the Galaxy A80 also includes a 3,700mAh battery that supports fast charging at 25W. It also has 8GB of RAM, 128GB of onboard storage, and it includes an in-display fingerprint scanner. The phone is available in three colors: gold, white, and black.
The Galaxy A80 will launch on May 29th.
Video: https://youtu.be/NWW0JRY3ktY
Za instagramuse dusu dao. Verovatno najbolja "prednja" kamera na trzistu.
Svidja mi se i kombinacija SoC+baterija, uz verovatno dobar ekran imace dobru autonomiju.
Biće na s11 verovatno. Moguće da ovakav sistem ne može da se pravi dovoljno brzo tako da su rešili da smaraju narod sa pilulama
Коју цену очекивати за овај фон на огласима тамо негде у јулу-августу?
Хвала на конструктивном одговору.
Nema na čemu, tu smo da služimo narodu. Hoćeš i da predvidim cenu Bitcoina tamo za jul-avgust kad sam već tu?
Хвала на понуди, али ипак не бих од особа са таквим аватаром узимао било какве финансијско-економске процене. [emoji6]
@Migrant Отприлике сам тако нешто и ја очекивао, само нисам био сигуран колико А серија држи цену. Занимљив уређај свакако за узети у обзир.
U HR operateri ga vec nude, kad ce kod nas i il vredi čekati
Sent from my SM-G928F using Tapatalk
Ko ima para kupice S seriju tj dodaće, a ko nema uzeće A50. Cena od 80.000 je paprena i ne znam odakle im palo na pamet da tako pozicioniraju telefon.
Slazem se u potpunosti. Po mom misljenju bolji izbor bi bio A70, ako samo Samsung dolazi u obzir. U nekim stavkama i bolji od A80 a dosta jeftiniji. Na KP ima odlicnu cenu. [emoji4]
A80 u ruci deluje dosta ozbiljnije, moćnije. HW jeste malo jači, tu je cool efekat njegove kamere, leđa telefona nisu plastična...i baterija 17-18 procenata slabija. Kad uzmeš da je razlika u ceni (pričam o regularnim MP cenama, ne malim oglasima) skoro 30.000 RSD - da, delim mišljenje da je A70 bolji izbor.
Pozdrav drustvo,dali je neko kupio a80 posto ga planiram uzeti,utisci i tako to.
Imas na jerryrigseverything lep video.
Meni je jeza ako udje pesak ili nesto slicno u slajder mehanizam, zato bih ga izbegao.
Gesendet von meinem CLT-L29 mit Tapatalk
Danas sam ga probao u mts uzeo bi ga kao drugi telefon,kvalitetniji uredjaj u ruci nisam drzao nisam verovao kako je odradjen.
Pozdrav drustvo uzeo sam a80,moze li mi samo neko nesto.Telefon dolazi sa imx568 sonijevim senzorom,on je u 48mpx al slika u 12mpx,al kod a80 postoji mogucnost slikanja u 48 dok ja mislim kod na primer one plus 7 pro sa istim senzorom ne moze u 48mpx?
