NETWORK Technology
GSM / HSPA / LTE
LAUNCH Announced 2019, February
Status Available. Released 2019, March
BODY Dimensions 158.5 x 74.7 x 7.7 mm (6.24 x 2.94 x 0.30 in)
Weight 166 g (5.86 oz)
Build Front glass, plastic body
SIM Single SIM (Nano-SIM) or Dual SIM (Nano-SIM, dual stand-by)
DISPLAY Type Super AMOLED capacitive touchscreen, 16M colors
Size 6.4 inches, 100.5 cm2 (~84.9% screen-to-body ratio)
Resolution 1080 x 2340 pixels, 19.5:9 ratio (~403 ppi density)
Protection Corning Gorilla Glass 3
PLATFORM OS Android 9.0 (Pie)
Chipset Exynos 9610 (10nm)
CPU Octa-core (4x2.3 GHz Cortex-A73 & 4x1.7 GHz Cortex-A53)
GPU Mali-G72 MP3
MEMORY Card slot microSD, up to 512 GB (dedicated slot)
Internal 64/128 GB, 4/6 GB RAM
MAIN CAMERA Triple 25 MP, f/1.7, PDAF
8 MP, f/2.2, 12mm (ultrawide)
5 MP, f/2.2, depth sensor
Features LED flash, panorama, HDR
Video 1080p@30fps
SELFIE CAMERA Single 25 MP, f/2.0
Features HDR
Video 1080p@30fps
SOUND Loudspeaker Yes
3.5mm jack Yes
Active noise cancellation with dedicated mic
COMMS WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
Bluetooth 5.0, A2DP, LE
GPS Yes, with A-GPS, GLONASS, GALILEO, BDS
NFC Yes (market dependent)
USB 2.0, Type-C 1.0 reversible connector
FEATURES Sensors Fingerprint (under display), accelerometer, gyro, proximity, compass
ANT+
BATTERY Non-removable Li-Po 4000 mAh battery
Charging Fast battery charging 15W
MISC Colors Black, White, Blue, Coral
SAR EU 0.27 W/kg (head) 1.39 W/kg (body
Kupih ga pre neki dan i mogu vam reći da sam se prijatno iznenadio ovim modelom.
Verzija je 4/64 Black i fercera besprekorno. Uživo pleni na prvi pogled.
Jeste plastikaner (plastična poleđina telefona) ali tu plastiku nosi dostojanstveno. Ekran je odličan i telefon jako dobro leži u ruci. Baterija je 4000mAh i meni, kao ne zehtevnom korisniku, izgura 2 dana (Face, Messenger, Viber, Twitter).
Obzirom da je u pitanju Exynox (neki čipset u 10nm) i da je 3 cores grafika, što se tiče upotrebe telefona, sve teče glatko i bez lagova što mi je, generalno, i bitno. Zvuk sagovornika u slušalici je odličan (a i mene čuju odlično), zvono je glasno i vibracija takođe (jako vibrira tako da nećete imati problema sa notifikacijama i pozivima.
Šta reći, sem da će vreme pokazati svoje...
