ZOROG project
nessa78
New year, new projects! I'm back again with the good stuff :D I hope you'll all enjoy in this project! Big thanks to all the sponsor companies!
First I will present you Asus RTX graphic card and Thor 1200w PSU, stunning build and performance :)
First video of this project and my first video on English language is uploaded, enjoy!!!
Here are some photos that accompany the video...
Odlican hardver,odlicne slike neso, e tako sam ja montirao kod mene EK 360 od 6cm debljine a, nije fabricko mesto super ispalo malo modovao. Ps: Papuce su top :d
Asus x399 Zenith Extreme and AMD TR 1920x for this project :)
Smorio sam se koliko je dobro :D
Work on the new aluminum elements for case, and I will used existing c700p I/O panel on a different place :)
Checking the measurements of new aluminum parts, everything fits perfectly :)
New video about project ZOROG is UP, enjoy!
Plastifikacija metala je zavrsena, sve je spremno za ugradnju i montazu na sasiju :)
I must cut some corner and plate of the mask :)
Coper tube has arrived
Paint job :D
Pitanjce:
Da li stavljas neki prajmer ili samo farbu?
TuturuTu on 6X
Super, hvala!
TuturuTu on 6X
ADATA XPG RAM and SSD has arrived. Thank you for support! :)
Some EKWB detail and work on the mask, holder :)
Novi video o ovom projektu je uploadovan, hvala sto pratite, uzivajte!
