Beam [BEAM] (Equihash 150,5)
outlaw
Uzvišen
CPU & Cooler
AMD Ryzen™ 7 5700X w/ AMD Wraith Prism LED RGB Cooler
Matična ploča
MSI™ B450 Tomahawk Max
RAM
32GB DDR4 3200MHz Kingston™ Fury Beast RGB KF432C16BB12AK2/32
GPU
Gigabyte GeForce RTX™ 3070 Ti GAMING OC 8G
Storage
ADATA XPG SX8200 Pro NVMe SSD 512GB M.2 2280 PCIe & WD Red Plus WD40EFPX 4TB CMR
Zvuk
Creative Sound Blaster Z
PSU
BeQuiet Pure Power 12M 750W ATX 3.0
Kućište
NZXT H5 Flow w/ 4x Arctic P12 PWM PST A-RGB 0dB & 2x Arctic P14 PWM PST A-RGB 0dB circus
Monitor
Samsung SyncMaster 2443BW 24" 1920x1200
Miš & tastatura
Logitech G502 Hero & Logitech K740 Illuminated Keyboard
Mobilni telefon
Samsung Galaxy S26 Ultra
Pametni uređaji
Samsung Galaxy Watch6 Classic 43mm
GoPro HERO12 Black
Pristup internetu
  1. Kablovski internet
BEAM is the first coin to launch that incorporates a version of the MimbleWimble protocol.
There is a lot of information about this protocol but the main points are:
- Increased Privacy
- Scalability
- Reduced blockchain size
Beam is using the Equihash 150,5 protocol, is written in C++ and is open to allowing ASICS at some point.
You might have heard about GRIN, which was the second cryptocurrency to come out with a version of the MimbleWimble protocol. Beam is a lot different in architecture of the system, compared to Grin. The main differences from the users perspective is Grin allows for IP, file and address based transactions, while beam uses temporary ID’s that help wallets communicate with each other, and has the ability to create permanent ID’s since regular ID’s change after each connection to a wallet, to increase privacy.
Vodič za kopanje BEAM coina, instalacija, podešavanje i korišćenje walleta, poolovi za kopanje, podešavanje majnera za nVidia i AMD karte, kalkulator isplativosti, itd.
https://blockonomi.com/how-to-mine-beam-coin/
Da ne bismo zatrpavali druge teme, ovde možemo da diskutujemo o ovom coinu, koji je uz Grin za kratak period uzdrmao mining svet posle dugo vremena i za sada se čini da ona čuvena mantra "uvek će biti nešto da se kopa" ponovo ima smisla 🙂
P104 na Win i lolminer ~20-20.5 jel to ok score?
pa s obzirom da meni rx580 daje 11-12 mislim da je to super.
koji pool koristite ?
Koliko sam video po netu 1070 daju 16-18 tako da bi trebalo da je to to, još i bolje 😉
Odlično. Što više coin-a sa privatnošću transakcija, to bolje.
Pojma nemam, nakacio sam se bukvalno na prvi koji sam nasao.
A to za kraduckanje vazi za sve poolove, a kolko kradu ili se mi tripujemo i to ne znam.
Prica je bila da Leaf prijavljuje kako ima veci hash na svom poolu nego sto ga zaista ima, pa procentualno kada dobijas isplatu , dobijes oko 15-tak procenata manje.
S obzirom da je od dvojice ljudi koji su stari mineri, verujem da je istina.
Koliko daju zelene zna li ko ?
Послато са SM-G935F уз помоћ Тапатока
GMiner:
Equihash 150,5:
Palit GTX 1060 Super JetStream 3GB ~11 Sol/s
Palit GTX 1060 JetStream 6GB ~13 Sol/s
Palit GTX 1070 Ti JetStream 8GB ~23 Sol/s
MSI GTX 1080 SEA HAWK EK X 8GB ~24 Sol/s
Gigabyte 1080 Ti AORUS Waterforce WB Xtreme Edition 11GB ~33 Sol/s
MSI RTX 2070 Armor 8GB ~23 G/s
MSI RTX 2080 DUKE 8GB ~30 G/s
Nova verzija 1.25 podrzava i 3gb verzije 1060
Hvala, a za crvene najbolji lolminer ?
To ce morati neki crvendac da odgovori. 😀
Evo za one koji hoce da kopaju beam:
Kalkulator:
https://crypt0.zone/calculator/deta...ted_exchange=42&cur=USD&average=3h&exchange=0
Pool + miner
https://beam.leafpool.com
https://github.com/Lolliedieb/lolMiner-preview/releases
Podesavanja imate u majneru, vase je da unesete wallet, rig i mail po zelji kao notifikaciju ako rig ode offline. Sve ostalo imate napisano za gore navedeni pool. Adresu drzim sa menjacnice.
Menjacnica sa beam/btc/eth/usdt
https://www.hotbit.io/register?ref=332725
Rx 470 8-10 sol
rx 570 9-12 sol
rx 580 8gb 11-13 sol
Podesavanja klokova drzim iste kao za eth.
Dacu paritet, 1250mhs na eth-u ili 412 na beam.
Da prijavim da za nvidia trenutno gminer sa verzijom 1.25, bar kod mene, daje veći hash nego lolminer. U pitanju je 1060 3gb sa hynix mem.
Kod mene je upravo obrnuto iskustvo, probao sam leaf i spark po 36 sati, uzevsi u obzir diff varijacije spark mi je dao citavih 20% MANJE nego leaf, tako da ono...cisto jos jedno iskustvo orjentira radi...
Sto je bilo, bilo je, Nicehash je dodao BEAM, sad ce da ga zajase, od zarade ostace mrvice... Prica koja se ponavlja...
Da li ima još neko problem sa pucanjem lolminera (alpha 2 verzija) ili zna zašto se dešava? Lolminer exe has stopped working...
Nije sigurno do nestabilnosti riga jer se desilo apsolutno na svim rigovima i to u identično vreme, nakon što je okvirno kopalo 10ak sati bez problema. Ne zakuca rig, samo majner izbaci tu grešku, kad ga zatvorim i pokrenem ponovo nastavi normalno.
Lolminer i kod mene pucao sa 1060 3GB, i ver 3 i ver 4, bar dva-tri puta u 24h, sad sam na gminer i za sad je sve ok.
Ja polako pakujem kofere, isplativost se vec srozala a sad kad krene nicehash silovanje to ne zelim ni da gledam..
Bolje i asici da zajasu nego ogavni nicehash
Ja cu jos da cekam, posto i dalje se vise isplati nego eth. Iskreno, eth je malo skocio diff mu pao, svi ce preci opet na eth. Ja sam ethom imam mesecno 430 a ovde 500.
Moze li neko da napise kako pravilno startovati i podesiti lolminer, pokusavam preko ovog primera, i cim pocne miner masina blokira / restartuje.
lolMiner.exe --coin MNX --pool stratum.minexpool.eu --port 9999 --user XQZoBeGPZJoLhTdkcF8bScsNH5Wyesd9g4.lolRig --pass x
Kao prvo ovo gore ti je za Minex coin. Ako zeliz Beam onda imas ovo:
lolMiner.exe --coin BEAM --pool beam-eu.sparkpool.com --port 2222 --user adresa.rig
