Zabrana pristupa neprikladnim sajtovima lokalno
gmlale
Mobilni telefon
063626864
Pristup internetu
  1. Optički internet
Potreban mi je savet za blokadu pristupa u prvom redu porno sajtovima ali lokalno na svakom racunaru ponaosob, a ne na nivou mreze (ne na ruteru).
U pitanju je 5-6 laptopova koje koriste stariji osnovci za rad, ali ih koriste i povremeno bez nadzora. Potrebno mi je nesto sto ne bi mogli lako da uklone sa racunara, ili pak nesto sto je kao proces neprimetno. Najcesce koriste Google Chome kao browser.
Dobar nacin svidja mi se, e sad koliko bi im se usporio net promenom dns servera to je pitanje i da li bi mi to stvorilo kakve probleme u funkcionisanju mreze. Mislim kakvo je vreme odziva DNS servera i sl.
Mozes i da pratis koje gledaju sajtove u Chrome pa ih ovde blokiras:
Postavi u hosts fajlu
redirect za te sajtove na localhost...
127.0.0.1 pornsite.com
Windows/system32/drivers/etc
Prekopiraj taj fajl na svim računarima i to je to...
Sent from my HTC U Ultra using Tapatalk
Znam za to u host fajlu, ali se bojim da ne mogu sve moguce varijante da pobrojim i ubacim u taj fajl.
Trenutno imas besplatnu licencu na sajtu za program HT Parental Controls:
The best way to keep your children safe online and manage their activities
HT Parental Controls provides parents with an easy way to set up your rules for all computer activities and protect children from all harmful and inappropriate content.
It lets your children navigate online safely. You can see what they view or play, block access to websites and apps or limit certain websites in a friendly way. HT Parental Controls helps concerned parents shield children and prevent them from accessing inappropriate websites.
The program contains many superior features that make the software great for parents. Our real-time internet filter automatically blocks all harmful and inappropriate content to protect your children.
Complete the simple installation and start controlling your family’s online activity.
Block inappropriate content
Block any social media sites
Block specific websites
Allow only white-listed websites
Block installed application
View reports with all attempts
Remote access
Emailed log reports
Difficult to Circumven
A sada sledi "zackoljica":
Terms and Conditions
This is a 1-computer 6-month license, for noncommercial use
You get free updates for six months
You get free tech support
You must redeem the license key before this offer has ended
May not be resold
Bacio sam pogled na ove fajlove, interesantna stvar. S obzirom da ima veliki broj unosa u hosts fajl da li ce to pretstavljati problem netu (usporavanje).
Vi mislite da klinci koji znaju da nadju porno sajtove ne mogu da zaobidju takve zabrane?:)
Cak i da nisu Admins.
nema nikakvih usporavanja niti problema. moze samo biti bolje jer je prekinuta svaka veza sa raznim glupostima. ja ovo koristim par meseci pre svega da onemogucim pristup svim socijalnim mrezama iako samo ja koristim komp.
ako nesto hoces da dozvolis, mozes lako rucno da zakomentarises...
Super onda dodavacu ove zabrane u hodts fajlove, a sto se tice prvog predloga Zekovic mi je postavio tutorijal u kome se menjaju primarni i sekundarni DND server:
Primarni DNS 208.67.222.123
Sekundarni DNS 208.67.220.123
Varijanta je jednostavna, ali ne znam koliko je ucinkovita i sta mogu ocekivati.
nisam isprobavao sa tim DNS adresama... odaberi sta ti se vise svidi ali ja ne bih radio obe stvari zajedno pa probaj prvo sa jednim resenjem i vidi kako ce da se pokaze.
napisao sam ti za ove host adrese jer ih i sam koristim bez ikakvih problema.
Sa DNS varijantom na računarima je potrebno da promeniš DNS. A na njihovom sajtu je potrebno da kreiraš nalog i definišeš koje grupe sajtova su blokirani. I to je to... DNS onda sam odrađuje resto. Postoje i opcije da se neki sajtovi manuleno blokiraju ili odblokiraju preko naloga...
baci pogled na ovo pa ubaci neku od lista koja ti treba. blokirace ti sve sto hoces:
https://github.com/StevenBlack/hosts#readme
Evo male olaksice za ovaj pristup!
Preuzmi aplikaciju sa linka
- portabilna aplikacija VEOMA korisna
Potom odaberi opciju TOOLS - UPDATE HOST FILE - pri dnu imas opciju DOWNLOAD AND INSTALL UPDATE LIST (.TXT)
Pojavice se pop-up u kome ces navesti stranicu za preuzimanje host.txt fajla a ispod imas opciju da dodelis naziv tog host fajla radi lakseg prepoznavanja u listi.
hvala za ovaj alat, isprobacu ga kad budem za kompom. uvek mi je bilo mucno da cackam po windowsu.
na macOS-u koristim GasMask a nije mi bio problem ni rucno da dohvatim host fajl.
@pekicp
hvala jos jednom, odlicna alatka. ovo mnogo olaksava patnju sa windowsom :)
samo da javim da sam batalio ovu alatku jer je prespora i malo konfuzna. dobitna kombinacija je Notepad++ i rucno odradim sve sto mi treba za par sekundi.
