SMOS Linux Plug-In & Mine - The simplest mining OS based on Linux
@coldej, hvala na odgovorima
Pošto u rigu imam 2x gigabyte 1060, 3x asus 1060, da li neko zna kako da proverim koja mi je karta na kojoj poziciji? Šta da kucam kada se konektujem preko ssh? Ili koji fajl da pogledam u sistemu?
Novi SMOS 3.0 u potpunosti novi.
Sve pitanja sugestije pisite.
SMOS Version 3.0
Release date: 06.25.2018.
Download Link:
https://mirror1.smos-linux.org/SMOS-Linux-3.0.zip
Change Log:
  • The minimum requirement USB for installation is 8GB
  • Remote control access from any location
  • Easy user interface with Light and Dark theme
  • Miner log, System log and Errors output for each machine
  • Telegram and E-mail notifications
  • Profiles improvement and history
  • BIOS Control
  • Activity logs and Access logs
  • Advanced graph statistics (temperature, hash rate, shares, watts)
  • New NVIDIA drivers
  • PCIE Detector
  • Kernel 4.17.2 with hwmon improvements
  • AMD Undervolting (~20% less power consuming)
  • Auto Rig restart on failure of software/rig and display of errors
  • New Software: Claymore 11.8, dstms 0.6.1, xmr-stak Alloy 2.4.5, bminer 9.0, xmr-stak 2.4.4, noaminer 1.0, ccminer KlausT 8.21
Rio, dodate je PCI-e detector, mozes da utvrdis koja je koja karta.
SMOS Version 3.0.15
  • Fixing boot issue caused by CONIFG partition (thanks to @Wizard, @nospam, @Six Litr for reporting the issue)
  • Updating CUDA files for newly compiled ccminer's
  • Cleaning lock file when lock is stacked without changes. The lock will be cleaned after 5 minutes if no changes
  • Update counter fixed
  • EWBFs Cuda Equihash Miner 0.2 integration runtime fixed
  • Removing rig from display fix
  • Improved search logic at dashboard
  • Added EWBFs Cuda Equihash Miner 0.2
  • Fixed bugs reported by users in SMOS CC
  • Added auto replacement of Worker name with Rig Name - Read More
  • Fixed issue with wrong config description
  • Fixes in profile edit updates
  • Fixed Claymore (ZCash, BTG) API - Added custom tracker of hash rate per GPU and total hash rate
  • Improved overclocking and software scripts
  • Added error message if there is a problem while changing to the new software
  • Added lolMiner-144.5 v0.38 miner
Sve predloge pisite ovde ili ako zelite privatnosti putem privatne poruke.
SMOS 3.0.16 - 07.29.2018.
Rebooting issue stack fixed if you overclock cards too high
SMOS CC 1.7
Added ccminer alexis
Added xmrig-amd 2.7.3 - donation level 0.0
Added xmr-stak 2.4.7 - donation level 0.0
Mobile/Tablet responsive optimization
SMOS CC speed up improvements and optimizations
Some of same colors on graphs are changed
Allowed _ character in profile name
Shares on Dashboard renamed LAST to AGO - to avoid confusion
SMOS CC 1.6
Added Claymore 11.9
Added Notification tab
Rigs on dashboard set to be sorted by rig name
SMOS CC 1.5
Added xmr-stak 2.4.5 - donation level 0.0
Lolminer 0.4, može? :)
SMOS CC 1.9
Dashboard redesign (Improved search, Added IPs, Profiles at Dashboard)
Improved deleting of rigs
Added search in Rig List by Name, ID, IP and Profile
Added Auto complete instant of dropdown menu in Live Status
Added dates in clock logs
Added GPU Preset (saved clock settings) can be created and assigned chosen number of rigs without manually change settings each of them
Replaced dropdown menu with auto search suggestion. Type rig name and select from suggestion menu rig for more details
Added GPU Preset Document - Read More
Added Donation Button
Uocen je problem kod nekih od AMD serija sa undervoltingom i takodje out of memory u Claymoru, radi se od danas na tome :)
Download URL: https://mirror1.smos-linux.org/SMOS-101v5.4-20.10a-455n.tar.xz
ALL SUPPORTED GPU’s:
nVidia GTX cards:
1050, 1050ti, 1060, 1060ti, 1070, 1070ti, 1080, 1080ti, P102-100, P104-100, P106-090, P106-100, 1650, 1660, 1660ti, 2060, 2070, 2080, 3080, 3090
AMD RX cards:
460, 470, 480, 560, 570, 580, 590, Radeon VII, RX 5500, RX 5500 XT, RX 5600, RX5600 XT, RX 5700, RX 5700 XT
SMOS Linux v101 Released 18.10.2020.
New system release with drivers 20.10 AMD and 455.23.04 nVidia for newest cards
SMOS CC v20 Released 18.10.2020.
Live counter of rigs available in SMOS CC
Total sum of Rigs, GPUs and kWs in Live Status
Upgraded reCAPTCHA to 3v
Improved speed on Dashboard and Pages
New design of preview
Speeded up interface
Redesigned profiles
Charts integrated in Preview Page (new page)
Added GPU W/F/T - Highest value per GPU for Watts, Fan, Temperature per Rig
Sum of profiles hashrate in Live Status
Online, Offline and Issues counter in Live Status
Added Rig Notes
Public IP added - on click shows full IP
Added live issue counter
Added alert counter of issues in Rig Preview page
All Rigs are now listed at Dashboard until you delete it from Rig List
Added debugging log and miner log output to monitor. (Use monitor only in motherboard - don't put it mining GPU)
Jump to page issue on Profiles and Presets fixed
Preset summary redesigned
Use Monitor in motherboard only. There is availability now to see output log from Miners and System changes
Added CPU Temperature, Avg load on server and kernel version
GPU Preset redesigned and bug fixed.
Profiles redesigned
Added GPU Preset by GPU type
Added additional command line to execute softwares like rxboost, amdmemtweak etc.
Added amdmemorytweak
Fan values changes with target fan
Overclocking from rig settings deleted. Overclocking just trough GPU Preset.
Payment system set on 1$ per Rig/Month. 1 rig is free forever! Bonuses on deposit 5%, 10%, 25% and 50%.
Estimate earning per Rig and GPU for Ethereum, based on your Hashrate, Watts
Dark theme updated
Join to our Slack channel if you have any question or suggestion
Ako neko ima pitanja, pisite :)
Ako neko ima veliku farmu razlicitih rigova, moze se javi za testiranje, dobice besplatnih kredita.
da li ovo znaci da je ponovo aktuelan razvoj ovog SMOS linux sistema nakon 2 godine pauze :)
upravo to, da li sada imaju update-ovane minere i da li se redovno azurira?
Da, redovno se azurira i dodaju mineri. Sve zelje se ispunjavaju, a ovo su trenutno neke od njih:
SMOS Linux v103v,v104 Released 25.10.2020.
Fixed NVIDIA names detecting issue
Fixed Preset NVIDIA issue
Enter only one value the value will be replaced for the rest of GPU instant spending time on counting and replacing with comma
Detect GPU on the motherboard by clicking on the PCI-E ID. The selected GPU will set the max fan 100% for GPU chosen. Others will be at 0%
Added refresh and home icons shortcuts
Added Wallets Address in User Settings. You can define new wallet name and wallet address -> assign to profile and it always replace your address with your custom name
Added three different color for rig statuses/legends (before we had two green/gray)
SMOS Linux v106 Released 28.10.2020.
To avoid misunderstandings, we delete the account wallet and left just the Mining wallet. All credits are automatically assigning to the Mining wallet after payment.
Redesign of dropdown menus
Tweaked fan control for AMD and NVIDIA
Added SRBMiner-Multi 0.5.4
New names detection for AMD
Added Auto Rig Detection - to avoid renaming config file with your email, just put Rig in the same local area network with your device, which is logged to SMOS CC. That's the one condition, and the second is to enable in User Settings - Rig Auto-Detection. After that, rigs will automatically show up in your dashboard. In the case of the remote location, there is a field to put Remote Location IP. In that case, Remote Location IP will be a priority.
SMOS Linux v105 Released 26.10.2020.
GPU Detection set to 2 minutes
Added GPU Detection logs when is started/finished
Fixed issue with clocking with miner restart
SMOS Linux v107,8,9,10,11 Released 01.11.2020.
Coldreboot added to miners
Added transfer credits to others SMOS miners
Redesigned Activity Log to Activity Log dropdown
Rig Action assignment: Each time you act on Rig, it will show up in green box +1. When Rig assigns change from SMOS CC the number will decrease. If there isn't any action, the green box will show zero - 0. Also, you can clean your activity log at any time.
Added mV for each GPU (VDDGFX)
Ako bilo kome treba neka pomoc tu smo. Takodje ako treba vise rigova da testira moze da dobije kredita sto raznovrsnije karte ima :)
SMOS Linux v112,113,114 Released 05.11.2020.
Added T-Rex 0.18.5
Added GMiner 2.29
Added WildRig Multi 0.28.1 beta
Added XMRig 6.5.0
Added XMRig AMD 2.14.6
Added lolMiner 1.12
Tweaking reboot clocking
Jedno pitanjce,da li je mozda neko probao Simple Mining ali da rig ide na onaj mobilini 4G net (Telekom,Telenor)...? Ili je WLAN only?
Pa to je sjajno! Hvala :)
Sent from my OnePlus 8 using Tapatalk
SMOS Linux v115 Released 19.11.2020.
Issue detection - monitoring and suggest of detected issues (low Hashrate, low Fan or broken Fan, high Temp on CPU/GPU, High Load, Network Unstable etc.).
Mobile optimization
Redesigned Preview Page - better preview and tweaked up interface
Custom Miner - add direct URL of your miner (zip only). In same cases you will not be able to see the dashboard, but you will see the output in Miner Log
Network Stability - There are 5 points of stability 1 to 5. If you have 5 points that means your network is stable to Pool or DNS. If you have less than 5 that means you maybe loss some shares during mining.
Extended logs for Miner and System to 50 lines.
Tweaking Dashboard speed.
Tweaking clocking and profile saving performances
Added timeout limit if API is unavailable
Added multiple commands from SMOS CC
Added Miner restart after renaming Rig name (to reflect changes on Pool)
Added lolminer 1.15
Added PhoenixMiner 5.2d
Added NBMiner 33.4
SMOS Miners Released 22.11.2020.
Added PhoenixMiner 5.2e
Added SRBMiner-Multi 0.5.6
Added GMiner 2.30
Added NBMiner 33.6
Added T-Rex 0.18.11
SMOS CC v221 Released 20.11.2020.
Improved GPU preset interface
Mobile optimization (less information on preview page for better UI/UX)
Dropdown optimization
SMOS CC v222 Released 28.11.2020.
Added three more options for deposit of Credits (Ripple, ETC, Raven)
API has been upgraded
Tweaks on the system to prevent any conflict in monitoring checks
Added GPU counter on the boot
Added NBMiner 34.0
Added GMiner 2.33
Added Team Red Miner v0.7.17
Added XMRig 6.6.1
Added SRBMiner-Multi 0.5.7
Added Phoenix Miner 5.3b
SMOS Image v117 Released 28.11.2020.
SMOS Linux updated to latest version
SMOS CC v222 Released 26.11.2020.
2FA Pin replaced with 2FA OTP
Added accordion dropdown for Issues and Errors on Dashboard for better preview
Added Network Traffic
Kolega, jel dodata podrska za 5700XT karte?
Sent from my CLT-L29 using Tapatalk
Hvala na info. Poslao sam PM.
SMOS CC v223 Released 15.12.2020.
Added easy BIOS Flash from SMOS CC Dashboard
Added Memory Temp for Navi cards
Added Phoenix Miner 5.4b
Added Team Red Miner v0.7.20
Added NBMiner 35.0
Added SRBMiner-Multi 0.5.9
SMOS Linux v118 Released 15.12.2020.
Added auto-assign profile and GPU preset after refreshing the SMOS Linux system image.
