D
Deleted member 9456
Guest
Sletela plasma 5.13.2 u Neon, po random principu plasma-dicover update ne radi, tu je apt koji uvek radi.
Dolphin ce ponovo dobiti mogucnost rada u root modu pise autor ali mora da se ceka u verziji 18.08.0. Ja na to kazem nista mi nije jasno jer Kubuntu tek razvija aplikacije pod kodnim brojem 18.04, istoi Debijan u experimentalnoj grani.
Kako kazu kod mene bice to jednog daba a mozda i dan ranije....
https://bugs.kde.org/show_bug.cgi?id=179678
--- Comment #59 from Nate Graham <[email protected]> ---
Bo, See the "Version Fixed In" fields on Bug 387974 and Bug 387973. The fix
will be in the versions of Dolphin and Kate from KDE Applications 18.08.0,
which hasn't been released yet. You can always ask the Dolphin and Kate
Packagers for Kali to backport the change (which is small and low-risk) to the
currently-released version if you want it now.
