Ubrzajte vas firefox!
nIce Cream
How To Speed Up Firefox (Helpful Vanity)
Posted on 12/12/2004 12:45:50 PM PST by KoRn
Here's something for broadband people that will really speed Firefox up:
1.Type "about:config" into the address bar and hit return. Scroll down and look for the following entries:
network.http.pipelining network.http.proxy.pipelining network.http.pipelining.maxrequests
Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.
2. Alter the entries as follows:
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
Set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once.
3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it recieves.
If you're using a broadband connection you'll load pages MUCH faster now!
Isprobah, i stvarno se oseti veliko ubrzanje.
Kod moox-a su sve navedene vrednosti vec na true, jedino ovo poslednje nedostaje...
Probao stvarno je puno brze...
uf... ovo mi je trebalo.. evo vec sam se par dana bio vratio na operu zbog toga sto brze otvara stranice...
stvarno mnogo brze radi sa ovim...
Radi brze, ali sada mi ne prikazuje dva bitna sajta kako treba. Pokusao sam i sa vracanjem postavki na originalno stanje i reinstalacijom, ne pomaze.
A jeste li probali sledece:
about:config
browser.turbo.enabled---->>switch to true
Koliko sam ja citao od ovog tweaka beneficija imaju samo korisnici sa brodbandom ili slicnim vezama. Modemashi mogu da prodju jos gore ako ovo enableuju.
Znam, ali se ovde svi zaredjase i kazu kako im sve radi do j@j@ dobro. Nisam znao da u Srbiji toliko ljudi ima broadband :)
delimir je napisao(la):
upravo, zato sam i napisao da je mozzda bolje da se stavi manji broj konekcija ( u svom thread-u, tj.,))..
svako ko malo razmisli docci cce do slichnog zakljuchka - mnogo istovremenih konekcija mozze da zagushi vezu i dovede do kontra rezultata
Dusan K je napisao(la):
http://www.tweakfactor.com/articles/tweaks/firefoxtweak/3.html
na ovom linku kazu da ako neshto zabrljash u configu treba samo da obrishesh fajl user.js u Mozilla profile folderu [C:\Documents and Settings\[User Name]\Application Data\Mozilla\Firefox\Profiles]
MIslim da bolje radi, ali ne nesto mnogo. Cini mi se da samo brze prikaze teks na datoj stranici, i naravno linkove, ali da se i dalje pati sa slikama i ostalim stvarcicama. Mada ne mogu da bas potvrdim ovo sto sam napisao zato sto mi je upravo nestalo vremena za net i nisam mnogo testirao, a 041 po meni nije merodavan. Tako da kada kupim vreme i probam jos malo potvrdicu ili poreci svoje misljenje. Pozdrav :wave:
aj jos jednom da pitam:
kako se u firefoxu ubrzava skrolovanje?
da li moze u about:config dijalogu?
A kako da se FF uspori? Meni mnogo brzo ovako :)
I dalje furam 041, zato sto me osakati ovaj 8 mart, nisam imao kes da uplatim sebi vreme zbog doticnog razloga. Nego zanima me da li postoji opcija da FireFox lepo sacuva ime stranice koje pise u titleu nego da ja kucam svaki put.
Pomoć!!!!!!!!!!!!
Dovde sam razumeo ali ovo ne razumem: :type:
Jel moze neko da mi pojasni. Please!!!
Uspeo sam.:banana:
Da li postoji neka extenzija koja pamti ova podešavanja za različite tipove veze kao što SwitchProxy menja proxyje sa jednim klikom?
